Question about Indesit W 123 Front Load Washer
Washing machine fault
Hi i have a indesit wil 103 washing machine there is a red light that keeps flashing it is near a picture of a padlock is there a fault with the door and is that why the machine wont work. many thanks Debbie
Hi mine flashes when you are aloud to open the door so i cant see this as been part of you problem sorry cant help more
Posted on Jan 08, 2009
  • Indesit Master
  • 3,463 Answers
Usually indicates door is not closed properly.
If it is shut securely, and still does not work, then you could have a faulty door lock.
Another possibility is the control unit could be faulty.
Posted on Dec 09, 2008
When i Press start the washing machine clicks a few times then red padlock light comes on. Door interlock changed but still happening. Any help appreciated.
I gather that the interlock has been replaced and now the padlock symbol lights up plus some clicking. I think the clicks are the door lock engaging and the padlock just shows this. Do the clicks continue? Does the door stay locked? If so I believe you have a fix.
May 19, 2015 | Indesit Washing Machines
My indesit washing machine 12 hundred keeps flashing blue and red lights and won't do anything
Possible that the suspect could be the controller board, you can switch the machine off power for sometime, check the power outlet for the correct voltage. If not the front panel must be removed to check on the board and a possible fault of the processor or memory.
Feb 03, 2013 | Washing Machines
Indesit washer wil 103
Check your water inlet valves. Seems like the valves have went away. Also check the computer board and inline fuse to make sure everything is correct. Inlet valve are located behind the supply line hoses. Please rate. Thank you
Feb 14, 2009 | Indesit W 123 Front Load Washer
Indesit wil 103 door won't open...
Welcome to Fixya.
Try holding the Start/cancel button in for at least 2 seconds.
If there is another lamp flashing at the same time as the door lamp, then you will have to call an engineer.
Dec 18, 2008 | Indesit W 123 Front Load Washer
Indesit wil 113
this is a cold fill only machine as nearly all machines today are designed that way to save energy , as you only heat the water that you need
Mar 28, 2008 | Indesit W 123 Front Load Washer
Indesit
hi there first of all check your filter located at the front of the machine for blockages as this is a comon fault, failing that next time the dial clicks round count the amount of times the red light flashes before it does a pause then starts again, and let me know how many flashes it does as this corasponds to a fault code
murdozzz
Dec 09, 2007 | Zanussi WJD1667W Front Load Washer / Dryer
Red light padlock symbol? what does it mean
the padlock led indicates that bthe door is open or poss interlock fault, however since you said it now trips fuses, IF you are not electrically minded call an expert something could of become disconnected or moisture could of got into the machine and blown the module
Jan 09, 2007 | Indesit WA 125 Front Load Washer
Indesit W 123 Front Load Washer Logo
773 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
