Question about Heidelberg Linoscan 1400 Flatbed Scanner
All my scans come out black
Hi no matter what i do everything i scan just comes out as a black any ideas thanks
I don't have the same scanner but the same problem and I unplug the scanner from the back of it and waited 1 minute and plugged it back in and it worked. It just might need to rebut itself.
Posted on Jan 26, 2009
Sharp AL-1551CS Scan Problem
hi do u have set tha adf limet for 8"x14" just set the corect size of origlan from adf
thanks
May 11, 2010 | Sharp AL-1551CS Copier
My HP C4480 scanner only returns a black image (on
Did you repaired old drivers? if so first uninstall your products drivers and also its folders from program files, then uninstall "wrong update" and reinstall scanner. sometimes built in scanning modules comes wrong but everything works with original scanning software, use different software to scan and some of them may work perfectlly.
Feb 20, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
My Braun 3650 is scanning everything RED, I changed computers and is still scanning red, any idea why it's doing that?
See previous fix for black lines problem is likely the same i.e fractures in the flexible cable between the scanning head and mother board, changing this cable will likely cure this fault.
Oct 05, 2009 | Braun MULTIMAG SlideScan 4000
Black line down the right hand side of everything I scan
it is problem your copier scaner mirror is derty
clean it
Jul 22, 2009 | Brother MFC-9440CN Laser Printer
try reloading the scanner have you the disk. or if that does not work contact manufacturer. when removing the scanner first close it down the computer then reinstall scanner.
Mar 18, 2009 | HP Photosmart C3180 All-In-One InkJet...
Everything I scan, the result is black
Hello Lucie,
From your brief description it sounds like the Scanner Lamp is faulty/blown do you see a bright light that travel up the bed of the glass under the lid when closed if open be careful as very bright if it comes on when scanning.
If you do then you may need to reload the driver for the scanner.
Good Luck!
Paul 'W'
Onyer~EDson(:0)~[>< U.K.
Jan 08, 2009 | Umax Astra 3400 Flatbed Scanner
Pixma mp970 scans everything to be black
You don't state what Operating system you're using.
Start by following this link and then download any new updates/drivers according to your OS platform.
Dec 02, 2008 | Canon PIXMA MP750 All-In-One InkJet...
LiDE 600DF - Unable to scan
Hi Peter
Have had the same problem, seems to come and go a bit... Quickest & easiest fix is to go to CanoScan toolboox > Settings then press the 'defauls' button at bottom... this sets everything back to factory settings and should fix your problem. Cheers.
Jun 08, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Heidelberg Linoscan 1400 Flatbed Scanner Logo
386 people viewed this question
Top Heidelberg Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Heidelberg Office Equipment and Supply Expert? Answer questions, earn points and help others
