Question about Frigidaire GLER642A Electric Dryer
E68 reading, Lights flashing & lots of bleeping
Gallery Series
Model GLGO2152ESO
  • adventurerin Nov 29, 2008
    I just paid online for some assistance but NOTHING has been resolved!!!
    PLEASE assist NOW as the E68, flashing & bleeping continue!!!
    I have a GAS DRYER NOT AN ELECTRIC DRYER!!!!
    What does E68 mean? I am in Central America (Panama)where the unit was purchase but I have NO idea where to go or whom to contact for service. ANY lists there for Panama & service numbers?
    Scholar:
  • 91 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} E68 Key (button) Struck Fault One of the keys (buttons) is stuck closed (active).
Enter function test mode and perform key (button) test to determine
which button is at fault. Carefully free the button and perform the test
again. If button is free but the key struck code still exists, replace
electronic control.
Here's a link to the Frigidaire Dryer Use & Care Guide. Page 9 and 10 should be helpful.
http://74.125.95.132/search?q=cache:-R-iug5WPi8J:https://consumerswarehouse.com/shop/cwcspecs/FRG/GLGQ2152ES.pdf+error+code+e68+on+Frigidaire+Model+GLGQ2152ES&hl=en&ct=clnk&cd=3&gl=us&client=firefox-a
Please let me know if this helps, Thanks, Binary Bob
Posted on Nov 29, 2008
  • 10,515 Answers
E68 means one of the buttons is stuck. Try pressing the buttons lightly, or disengaging them with a small tip.
The link for the service centre :-
http://www.frigidaire.com/support/support.asp
Thnx.
    Genius:
  • 1,447 Answers
HI
Try to push the door little harder when closing it.
Hope this help
    Genius:
  • 3,422 Answers
6 beeps / E68 - Push button does not function
Cause:
Push button held too long or wedged in the control panel.
Solution:
Press buttons lightly and release.
Disengage button.
Try doing that first if the error code still shows up, then you'll likely need a new control board assembly.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
On most Frigidaire Dryer, the error code "E68" indicates a mixed control signal condition. Based on this corrective measure would involve:
  • checking the buttons for any sticking or stuck into a position;
  • at one time or prior to the incident, several buttons were pressed simultaneously;
  • worst case scenario, defective a defective control assembly.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
    Sergeant:
  • 291 Answers
Unplug the machine from the main power outlet for sometime then replug it and check out.
  • jamesrated Nov 29, 2008
    check out if any of the buttons got stuck in the frontpannel.if stuck up then make it proper to resolve the problem.
    and also try opening and closing the door of the dryer if that sensor of the door gets stuck up or the sensor is dirty it gets stuck up and shows this error.
    try opening and closing the door several times.
    it will help.
  • Frigidaire Master
  • 19,396 Answers
I think you need to replace the control assembly.
  • 2 more comments
  • Ginko
    Ginko Nov 29, 2008
    E68 is a control assembly problem.
    Try first unplugging the power cord for ten minutes.
    If that does not work, then do the following:
    Disengage button.
    If still no luck, then the control assembly is defective and must be replaced.
  • Ginko
    Ginko Nov 29, 2008
    I am giving assistance do not be rude, the model number that you gave does not return anything.
    enter model number here to get replacements., call them at the number listed if you cannot find the model number.
    I report my previous comment:
    Disengage button.
  • Ginko
    Ginko Nov 29, 2008
    That is the first thing I told you, E68 is ' control fault'. I wonder if you can read my comments.
    Disengage button.
  • Ginko
    Ginko Nov 29, 2008
    Here is a list of repair services in Panama:
    Reparacion de Lavadoras Refrigeradores Secadoras Centros de Lavado
    Servicio, Refacciones, Reparacion de Lavadoras, Refrigeradores,
    Secadoras, Centros Lavado, Whirlpool, Frigidaire, White Westinghouse,
    Maytag, Mabe, ...
    http://www.serviexcell.com.mx/
    WHIRLPOOL REPARACION DE REFRIGERADORES LAVADORAS SECADORAS Y ...
    Centro de Servicio Especialista Whirlpool, Reparaci
    http://www.serviexcell.com.mx/whirlpool....
    REPARACION DE REFRIGERADORES EN MEXICO
    Servicio, Refacciones, Reparacion de Refrigeradores Whirlpool,
    Frigidaire, White Westinghouse, Maytag, Mabe, Easy , GE, Iem, Kenmore.
    http://www.serviexcell.com.mx/reparacion...
    LINEA BLANCA
    Maytag, Mabe, ...
    http://www.serviexcell.com.mx/linea_blan...
    SERVICIO TECNICO GENERAL ELECTRIC
    Centro de Servicio Especialista General Electrci, Reparaci
    http://www.serviexcell.com.mx/servicio_g...
    SERVICIO TECNICO WHIRLPOOL
    http://www.serviexcell.com.mx/servicio_w...
    WHITE WESTINGHOUSE REPARACION DE REFRIGERADORES LAVADORAS ...
    Centro de Servicio Especialista White WestingHouse, Reparaci
    http://www.serviexcell.com.mx/whitewesti...
    KENMORE REPARACION DE REFRIGERADORES LAVADORAS SECADORAS Y CENTROS ...
    Centro de Servicio Especialista KENMORE, Reparaci
    http://www.serviexcell.com.mx/kenmore.ht...
    EASY REPARACION DE REFRIGERADORES LAVADORAS SECADORAS Y CENTROS DE ...
    Centro de Servicio Especialista EASY, Reparaci
    http://www.serviexcell.com.mx/easy.html
Dryer gallery series e68
Good Morning Friend,
I understand you want to know how to replace the board on your Frigidaire dryer, model# GLEQ2152ES, due to receiving an E68 code. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your particular appliance, and should be able to replace the board with ease. Hope this is helpful.
-Best Regards-
WP
Jun 27, 2014 | Frigidaire Dryers
Faulty warning flashed and beeped, side light and fog lights faulty, but all are working how can I stop this and switch off the warning and bleep noise driving me mad on citroen c3 2006
That is a very rare car these days. I would go to a Citroen forum like this one to ask the question plus find lots of other information.
http://citroenc3owners.com/citroen-c3-help/
May 11, 2014 | Vehicle Parts & Accessories
Have a Frigidaire Gallery Series front loading dryer and it keeps giving me an error(?) code, E68. When I start the dryer, it runs for a couple of minutes and then It starts beeping and flashing this code...
Sorry to read about your problem. this should be your E68 problem
You have a defective button on the control board.
The best thing to do is go into the diagnostic mode.
Turn the dial to Normal. Press and hold the Select and Pause/Cancel keys for 6 seconds, or until the Drying/Cool Down/Press Saver/Clean Lint Filter lights come on.
Then press the Start and Pause/Cancel Buttons 4 seconds. This puts you into the diagnostic mode to check the keys. Now, turn the dial 4 O'clock position, or 75. This will allow you to check all your buttons. As you press each key, it will light all the lights above it. When you press a key and it does nothing or the lights above any certain key stays on without pushing it, this button is stuck. If you can't clear it, you probably have to replace the control board.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 21, 2010 | Frigidaire Dryers
My dryer when to begin to work stop and show E68 the dryer is gallery series thanks for help me
Dec 21, 2010 | Dryers
PLEASE HELP! Dryer cuts off and gives an E68 code.
e68 code
this is a fault code that means there is a stuck key on the board you may have to remove the control panel and check the keys if this does not work you may have to replace the panel or control board
Good luck
Oct 05, 2009 | Frigidaire Dryers
Error Code E68 stuck button?
expensive it is....if you have them side by side I think you can do it and save lots
Aug 15, 2009 | Frigidaire AEQ7000ES Dryer
Scooter motor does not operate
are you sure its in gear. I had the same problem and I pushed the nob on top of the motor towards the front of the machine and it worked!!!
Apr 03, 2009 | Health & Beauty
E68 readout on the panel
frigidaire dryers have problems with the computer boards,i've seen the affinity dryer start by itself,it will start to beep and then i can start up,but that error is telling you one of the buttons are stuck,if all the buttons check good you have a bad computer board.hope this helps you out.
Feb 13, 2018 | Frigidaire GLGQ2152ES Gas Dryer
Receiving an E68 readout on the time screen & lots of bleeping
Disengage button.
Nov 29, 2008 | Frigidaire GLER642A Electric Dryer
Frigidaire GLER642A Electric Dryer Logo
476 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
