Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
How do I get rid of this startup dialog box
When I start up my PC a message box appears saying "cliktext can't be open". The title bar of this message box says ddschk.
Does anyone know what this is and how to get rid of it.
Thanks
Dom
  • domp8 Nov 29, 2008
    Hi everyone,
    Found out the answer. It was a DLL file ran by the Belkin All In One Print Server. Re-installing the software for this solved the problem.
    Dom
I was deleting some stuff to make space on my hard drive and i deleted this cliktext by mistake and im getting the same startup dialog box. Now i cant find the software i need to reinstall. Im not even sure what i need to reinstall exactly.
Posted on Jun 08, 2010
    Problem Solver:
  • 7 Answers
Start->run->type msconfig, click ok
a dialog box appears
click startup tab
there u can view all details about all programs that start with windows xp...
Posted on Nov 29, 2008
Canon MP340 won't scan
The printer "black ink low" message has nothing to do with scanning. You don't have to disable the ink monitoring or do anything else with printer - to scan!
The printer is" waiting" for you to CLOSE a "Paper port 11" dialog box on your PC screen. If the dialog box is not open, check the task bar (bottom of screen) for anything with "MX340" in title, click on it then close it.
good luck
Lumir
www.inkbank.com.au
Mar 09, 2014 | Canon PIXMA MP240 All-In-One InkJet...
Why does this come up? There appears to be an error with your installation. Please reinstall the application. Always pop up everyone I
If this error appears every time you start the computer, then there is a program in your system start up that isn't properly installed. I can't tell you which program without more information. A quick search shows that this is a common problem with DriverCure and FileCure. Uninstall/reinstall them if you have one of these programs.
If you don't know which program it is, then you need to go through your startup programs one by one.
Press "windows key + R" to bring up the run dialog box.
Type in "msconfig" and click "OK."
If the UAC dialog box comes up, click "Continue."
Click on the "Startup" tab.
It will display a list of every program that runs when your computer boots. Uncheck the first box for the program that you think might be causing the problem and then click "OK."
A box asking if you'd like to restart your computer will appear. Click "Restart Now."
A dialog box will appear notifying you of changes to your startup, click "OK" and msconfig will reopen.
If the error reoccurs, then uncheck the next item on the startup tab and repeat until you find the one causing the error. Make note of the name of the last thing you unchecked and uninstall/reinstall that program.
To get rid of the startup notification box, simply check "Don't show this message..." before clicking "OK"
Oct 22, 2012 | Computers & Internet
Interactive services box keeps coming up after installing google chrome and can't get rid of it
Unfortunately,the question you had asked is persisting issue in Google Chrome and the developers at Google are yet to fix it.They have not provided the workaround. But you can stop this interactive dialog box by following these steps:
1. Open Services.msc by Start->Run->services.msc
2. Double click on the entry 'Interactive Services Detection'
3. Click Stop button(if it is enabled) and change startup type to Disabled.
You can find this raised as issue in Google Code page here
You can see people discussing this in Google Forums here
Cheers!!
Nov 22, 2011 | Google Chrome
Text is too small and difficult for me to see
On the Start menu:
  • Select Control Panel
In Control Panel:
  • Be sure you are in Classic View (all Control Panel icons are showing).
  • If not, under Control Panel in the left pane, select Switch to Classic View.
  • Select Display.
In the Display Properties dialog box:
  • Select the Appearance tab.
  • Select a Windows and buttons style from the list.
  • Select a Color scheme from the list.
  • Select a Font size from the list.
For more customization:
Under Windows and buttons:
  • Select Windows Classic style.
Under Color scheme:
Select the color scheme you want from the expanded list of options
To change individual desktop elements such as title bars, icons, menus, and scrollbars:
  • Select the Advanced button.
In the Advanced Appearance dialog box:
To choose the screen element you want to change:
  • Select it from the Item list.
To choose available size, color and font styles:
  • Select from the attribute lists.
When you are finished with selections:
  • Select OK twice to close the dialog boxes.
To close Control Panel:
  • Select the Close button.
Control Panel: Display: Appearance tab: Advanced button
Control Panel: Display: Appearance tab: Advanced Appearance dialog box
To open the Ease of Access Center, select:
  • Start.
  • Control Panel.
  • Ease of Access.
  • Ease of Access Center.
Under Explore all settings, select:
  • Make the computer easier to see.
Under See also, select:
Personalize appearance and sound effects
In Personalize appearance and sounds, select:
  • Display Settings.
  • Under Resolution:
  • Select a resolution between Low (screen elements appear bigger) and High (screen elements appear smaller).
  • Select OK.
Apr 19, 2011 | Computers & Internet
Hi all, when ever i re-start my computer it keeps coming up with the following error message with regardis to Egis update: "programme operation error, please re-start and try again" , it also displays this...
Simply go to Start / Run type in msconfig, select startup and untick all programmes except antivirus and any others you do want osee in lower right task bar. It will ask for restart, do so and add tick in the box that appears on startup. This will also speed up your startup.
Nov 30, 2009 | Acer Aspire 5610-4648 Notebook
A bos "Yahoo Update Manager" constantly appears on my computer screen with the message "The Yahoo update server cannot be accessed at this time." Each time it appears there is a dinging noise. How can I...
go to start --- run
type msconfig -- press enter
on the screen that appear select startup
uncheck everything that relates to yahoo.
press apply -- ok
Computer asks for restart. Restart. A dialog box may appear. check the box and continue.
Dec 17, 2008 | Computers & Internet
Shutdown
Manual steps to perform a clean boot in Windows XP
Step 1: Start the System Configuration Utility
Click Start, click Run, type msconfig, and then click OK.
The System Configuration Utility dialog box appears.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box.
5. Click the Services tab.
6. (VERY IMPORTANT DON'T MISS THIS) Click to select the Hide All Microsoft Services check box.
7. Click Disable All, then Click on the startup tab and click on Disable All Button and then click OK..
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. Log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK:
You have used the System Configuration Utility to make changes to the way Windows starts.
The System Configuration Utility is currently in Diagnostic or Selective Startup mode, causing this message to be displayed and the utility to run every time Windows starts.
Choose the Normal Startup mode on the General tab to start Windows normally and undo the changes you made using the System Configuration Utility.
Step 4: Optional step to disable features
This step temporarily disables Microsoft features such as Plug and Play, networking, event logging, and error reporting. Also, this step permanently removes the restore points from the computer. The System Restore feature uses restore points to restore your computer to an earlier state. If you remove the restore points, you can no longer restore Windows to an earlier state.
1. Click Start, click Run, type msconfig, and then click OK.
2. Click the General tab, click to clear the Load System Services check box, and then click OK.
3. When you are prompted, click Restart to restart the computer.
Steps to configure Windows to use a Normal startup state
2. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
Aug 14, 2008 | Dell Dimension 8200 PC Desktop
I have a Lexmark x5470 and evertime i start my computer now i get an error message which says im32fax.dil not found. How do i stop this from occuring.
Please follow the instructions below.
Click Start menu, click Run, type msconfig, and then click OK.
2. Click to clear the Load Startup Items check box.
3 When you are prompted, click Restart to restart the computer.
After restarting system.
Note: Doing this startup programmes will not run in the background however you can start the programmes later from start all programmes.
Please feel free to get back to me If you need any further assistance.
Regards,
Mohammed.
Aug 05, 2008 | Computers & Internet
SSCIVHOST.exe
chelepoy:
What antivirus are you using? How about any other protection, like spyware, firewall, etc.? I answered one of your other posts, and it appears that you somehow got the attention of several destructive processes.
I have seen this type of problem occur with another PC. Even though the virus is gone, it planted a reference in your startup configuration to call that file on opening Windows. Therefore, Windows goes and tries to open it each time it starts.
The file needs to be removed from startu process - and NO you do not have to reformat. Go to the Start button and select Run. Type in msconfig and hit OK. This brings up a window titled System Configuration Utility. Click on the Startup tab at the far right. You will see a list of all programs that are automatically being called to open at Windows startup, and all that are active are checked. In that list you will find the file that is being mentioned in the dialog box. Click on the checkbox to clear the checkmark to disable. (It would probably be a good idea to check the others listed and make sure you recognize them, and they are all actually items you want to run at startup.) Then click OK, which will close the window. Restart and the message should not appear again.
You can also search for the file name just to make sure that it is really gone, and I would use some part of it with an *, e.g., SSCI*.* in the search, as many of these types of malware will alter their own names as they go in an attempt to avoid being eradicated by antivirus software. (It should be gone, since Windows is telling you it can't find it at startup - but there could be a related, slightly renamed version lying there unidentified yet.)
By the way, a google on that file name gave me only one result, which was a forum post unlike yours, and no virus definition files seem to include it. In regard to defrag, no, this should not have any relationship to a defrag process. What diskeeper program are you using, and have you tried the basic MS defrag process? If it won't work, often it is because the hard drive does not have enough free space. However, that is a separate issue which we can deal with more fully in another session - let's make sure your startup irritation is gone first!
Please let me know how this goes, and if you receive a dialog box from Windows re the startup process when it restarts, I will help you understand this. It will require downloading, installing, and running Windows Defender (one more way MS makes sure they get their products on our machines).
I am certain you are going to be corrected! Thanks for rating FixYa!
May 04, 2008 | Microsoft Windows Xp Home Edition Sp2...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
401 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
