Question about Pioneer Audio Players & Recorders
PIONEER MODEL = XD-Z55T TAPE DECK TURNTABLES NOT REVOLVING AND BELTS ARE NEW, SEAMS AS THOUGH BREAKS ARE BEEN HELD ON.IT WILL REWIND BUT IN PLAY MODE THE TURNTABLES ARE LOCKED. sEAMUS
  • 518 Answers
SOURCE: Tape deck not working
Sounds like a motor problem. Try turning the motor by hand to see if it's bound up.
Geno
Posted on Feb 27, 2008
robotek
  • 1512 Answers
SOURCE: TEAC V770 3head tape deck.
Hi saabangerman
The unit sounds like it has a take up clutch or takeup idler problem. Check all the drive assemblies in the unit. Remove the cover from the front of the transport inside the cassette well, and check the condition of the idlers and reel base drives. The counter belt can also gatherup and prevent the takeup reel from working correctly, or fire the auto stop mechanism preventing it from playing, although that sounds to be ok in this case as the unit will FF and REW ok. The takeup drive is supplied by a different drive idler as it requires much lower and more controlled torque. This unit was always considered to be a great tape deck and is well worth a bit of attention for restoration. You can get a new belt kit for $19.00 from here
I am more than happy to answer any other questions you may have about it, just give me a hoy :) Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on May 29, 2008
dunnbiker
  • 8546 Answers
SOURCE: Can't get a signal from my Turntables to record on my tape deck. I'm running turntables through RX 206 Amplifier and don't understand the RCA ins and outs.
Connect them to a receiver with a phono preamp.
Posted on Apr 12, 2009
dunnbiker
  • 8546 Answers
SOURCE: I have a pioneer CT-F900
The take-up reel is dragging or the belt is stretched or broken. No surprise on a deck this old. Try Fast Forward. Try Rewind. Same result?
If it still doesn't work, and it happens with only one cassette, rap the cassette's flat side against a solid flat surface to loosen it. Try again.
If you're really an old-school deck user you probably know how to cheat the transport with no tape resent to make the capstans engage for cleaning. Try that. The two reels should spin opposite as if maintaining tension. If the right one is stationary or lethargic (try to feel how strong it pulls compared to the left one), there's a loose or broken belt.
Next step. Get out the can opener, go inside and see what's wrong. Good luck.
Posted on Dec 26, 2010
robthedesign
  • 7 Answers
SOURCE: denon DR-M44HX cassette deck play
http://www.fixya.com/support/t12006246-ive_got_denon_drr_m30_keeps_poping_back
The solution from AlecBrown133 above fixed the same problem for me. The only comment that I would add is that the same repair can be done with a normal rubber band. I used one to fix the same issue with my Denon drr-m30 and it is significantly cheaper than the 10 pound option.
Posted on Jan 03, 2014
I took my Pioneer SX-450 Receiver and Pioneer CT-1040W Tape Deck apart to move it. Put it back together. Now can't get a tape to play.
After putting a known good tape in the deck, push play, if the tape doesn't move, try rewind and FF. If nothing happens, the deck has a problem. I assume this is a cassette deck. If so, I always try the thrift stores for a new(used) one. There are good bargains there.
Dec 22, 2016 | Pioneer Audio Players & Recorders
Pioneer deck powers on but won't play, just flashes 0000 on both timers
Units that sit do not exercise the belts and this causes some belts to become deformed and then other to just decay to like a tar. Look inside the unit to see if the motors are turning. If they are you will see it needs new belts. If the motors are not turning then the likely cause is Electrolytic Filter capacitors in the power supply. They don't do well sitting either.
Jan 27, 2013 | Audio Players & Recorders
Can not open cassette player door
There are typically cam belts that become lose after some time that allow the deck to get stuck in a mode that locks the door closed such as play mode. Rotating the pulley that is driven by the motor will release the tape but that is just to release the tape- you need a new belt in the unit and some cleaning and lubrication to make it working again.
Oct 18, 2012 | Audio Players & Recorders
The play, rewind switches won't stay down
I have advised people before that replacing belts is not the only answer and sometimes people that are not experienced can upset some part of the deck without knowing it. We don't yet know the model or brand of the unit and from the description this kind of points to a Piano key or lever key type deck. I could also be a cam system deck. This complaint of buttons not staying down would not apply to a tack switch or solenoid type transport.
Like Jerry says a visit to a good Tech is the answer. I have been doing tape decks for 40 years and have worked at Sony and Teac service shops. If you need my help let me know. I am near Chicago.
Jul 20, 2012 | Audio Players & Recorders
Sony TC-138SD cassette deck starts to play then stops after 3 secs. Same when trying to rewind/fast forward
It sounds like the belt is slipping or broken which monitors the speed of the tape movement. When you play or rewind the tape, it thinks the tape has reached the end of play and shuts off. You can try a different tape to make sure the tape does not have too much tension on it. If the second tape has the same result you will need to remove the top cover of the deck to inspect the tape drive mechanism. Make sure the belts and pulleys are clean and replace any belts which have glazing or cracks. If the belt is broken you will need to replace it with a compatible belt of the same length and width.
Aug 15, 2011 | Sony CASSETTE DECK Single Dual Cassette...
Sony TC-K690 3Head Cassette Deck - no playback
It needs a new rubber belt for the mechanism control.
It is a smallest of th 3 rubber belts.
Mar 14, 2010 | Sony Audio Players & Recorders
My Teac R-H500 tape deck will not play tapes
The belts will have failed. You will need to replace them for the deck to be reliable. If you are mechanically minded I can talk you through it... You giving me a FixYa rating will help my profile and loosen my lips on how to overhaul your deck. :)
Feb 13, 2008 | Teac R-H500 Dual Cassette Deck
598 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
