Question about Maxim MAXSC5W
The ceramic pot
The crock pot inside the cooker has 2 cracks in the bottom & any liquid seeps out. Where can I get another one? thanks, kitties3
0 characters
1 Points
Should the lid be a tight fit or loose
Most crock pots are made of porous ceramic and is relatively brittle. It is glazed on all sides (except the bottom usually), to make it hold liquids without absorption. The lids, usually glass or thermoplastic, sit of top, but do not usually fit tightly as this could crack the crock. Also, it is not a pressure cooker, so you want excess steam to vent. The lid just keeps the heat inside and allows condensation to drip back into the crock, reducing the speed at which the fluids cook off, thus the term slow cooker.
Nov 06, 2015 | Hamilton Beach Crock Pots & Slow Cookers
I have the SCVP601R-L red crock pot. My ceramic pot is starting to look like it is cracking on the bottom. It is not leaking, I am just worried. I would like to get a relacement liner and it doesn't...
Check with your local hardware store, maybe they have some sort of scellent or glue for ceramic, just make sure it can stand high temperatures, if the crack is in the inside of the pot make also sure the product won't contaminate the food with nasty chemicals. Sorry that is the only thing I can think of besides buying a new crock...
good luck!
Jun 28, 2011 | Rival SCVP601R-L Slow Cooker
Cracked ceramic pot
Not sure what you are looking for here... the pot cannot be repaired...
It looks as though the crocks breaking is a very common problem...
This might be very interesting to you....from what I can see you can get a replacement crock but they break easily also ans it will cost you about 1/2 the price of a new cooker..
Nov 26, 2010 | KitchenAid KSC700 7-Quart Slow Cooker
Help .Do i put water in my slow cooker!!
do not put water in to the metal pot. place the ceramic pot inside the housing or metal part add your meal and set to high or low depending on how long you will be away and enjoy your food.
Jan 26, 2010 | Crock Pots & Slow Cookers
The Pot has a crack and won't hold liquid. Where
Go to
(or simply and click on "Replacement Parts")
They have a diagram to help you locate your exact model number. Enter that number in the box at the bottom of the page and press "Go"
If this helped, please be sure to hit the "thumbs-up" button for me, thanks!
Dec 14, 2009 | Rival SCVPE503-SS 5-Quart Slow Cooker
Our cermaic pot of our crock pot cracked when using it today is this a common problem its only a year old and has been used two times...
No this is not a common problem.
The ceramic bowl should last for years if handled correctly.
It may have had an unseen stress crack causing the premature failure.
Avoid putting cold liquid or items into the hot ceramic bowl/pot. This will cause the bowl/pot to crack and can be very unsafe when it pops. The reverse is also true, avoid putting hot liquid or items into the cold ceramic bowl/pot.
It is the sudden changes in temperature that can cause cracks to form.
Hope this helps!
Nov 10, 2009 | West Bend 84754 4-Quart
Line crack in bottom of the ceramic crock itself
Here is the direct link to the Rival Customer Service Dept. Call them and ask them how they can assist you.
Please rate this help!
Aug 21, 2009 | Rival 38501 Smart Pot 5-Quart
Cracked ceramic Kitchenaid crock pot liner
There is no inherent problem with the Kitchenaid ceramic inserts. As far as a replacement ceramic insert, I would suggest calling Kitchenaid Customer Service. They may be able to provide a new insert at no cost if the unit is still within the 1 Year warranty.
Their toll-free phone number is 1-800-541-6390.
Jun 25, 2009 | KitchenAid KSC700 7-Quart Slow Cooker
Cracked ceramic liner on a 84356 WB Crockery cooker
Go to this site and put in your model number (located on the bottom of the unit) and you can order the liner and other parts for your crock pot. The cost is $15.00 plus shipping and applicable tax.
Jan 24, 2009 | Crock Pots & Slow Cookers
Maxim MAXSC5W Logo
Top Maxim Crock Pots & Slow Cookers Experts
Are you a Maxim Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
