Question about IBM ThinkPad T43 Notebook
When I tried to switch on ny laptop t43 it is failing to boot,
It is saying bootmgr is compressed when I press ctrl+alt+delete to restart it is still displaying the same that bootmgr is compressed.what can I do solve the problem
  • luv_sicc01 Jan 20, 2009
    i have an apple macbook, i am also running vista ultimate. i let a friend who said they could fix a problem i was having. and now when i try  to start vista, i get stuck at a black screen that says bootmgr is compressed press ctrl+alt+delete  to restart. when i do that nothing happens.
  • Anonymous Feb 20, 2009
    yes i have the same problem please help
  • 4 Answers
Is there any way I can take a remote session on your laptop ? .. This way I can look into the problem andb can find the appropriate solution.
regards
Nitin
Posted on Nov 29, 2008
BOOTMGR is compressed says Press Ctrl+Alt+Del to restart. Keep going back to same thing.
Your MBR (Master Boot Record) is probably corrupted.
You could use Google to find a way how to repair the MBR for your specific OS
Nov 22, 2013 | Dell Precision M90 Notebook
I have an Amilo Pro V2035 and when switching on it only display 'BootMGR compressed.' I'v tried to press Ctrl+Alt+Del but nothing has changed. Pliz help me how I can restart the Laptop.
press F12 for boot manager before the screen displays bootmgr compressed.. Sounds like your hard drive may have developed a problem. When you press f12 you should get some startup options.insert your OS CD
go to DOS window and type in your OS drive (usualy C:\)
type in bootrec /FixMbr
then type in bootrec /fixboot
then type in bootrec /rebuildbcd
then type in exit
restart your computer
Oct 18, 2013 | Computers & Internet
Boot manager compressed dell inspiron e1505
you may have trouble sorting this with out the disc.Here are the steps to replace the BOOTMGR:
  1. Boot from the Windows install disc.
  2. Click on Repair your computer after selecting proper language, time and keyboard input.
  3. Select the Windows installation drive, which is usually C:\ , and click Next.
  4. Choose "Command Prompt" when the System Recovery Options box appears.
More items...
BOOTMGR is compressed: Press Ctrl+Alt+Del to restart
https://neosmart.net/wiki/bootmgr-is-compressed/.....or try this link.. boot manager is compressed press ctrl alt del to restart Google Search
Oct 14, 2017 | Dell Inspiron E1505 Notebook
My computer wont boot. It says "BOOTMGR is
You will need:
  • Windows 7 OS installation disc
  • Computer with "BOOTMGR is compressed" error
Please note that the following steps require you to have your computer to be able to boot the CD-Drive first.
Steps:
1.Insert the Windows 7 OS disc into your CD-drive and restart the computer.
2.Wait for the setup window to appear
3.Press Shift+F10 simultaneously to bring up Command Prompt
4.Type in Code:bootrec/fixbootthen press enter
5.Last but not least type in Code:bootrec/fixmbrthen press enter
6.There you have it, all fixed
Oct 19, 2011 | Sony VGN-NR430E/L PC Notebook
Boot mgr is missing
Boot Manager is missing If the boot partition no longer can be found, then Vista will display the following error: BOOTMGR is missing. Press Ctrl+Alt+Del to restart
The Windows Boot Configuration Data file is missing required information
More Info MS KB 919529 More Info MS KB 927391 Check points for fixing missing boot-manager: Check that your boot device is configured properly Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". Boot Manager is compressed If by accident having compressed the entire boot partition, then Vista will display the following error: BOOTMGR is compressed. Press Ctrl+Alt+Del to restart OR maybe try this first. Check points for fixing compressed boot-manager: Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". If the above doesn't solve the problem then boot into WinRE again, but when selecting the Vista-installation, then press "Load Drivers" (Instead of "Next") and use the mini Windows Explorer to right-click the boot-drive and deselect "Compress this Drive" and choose Apply to sub-folders and files. If that also fails then boot into WinRE again, and go to the "Command Prompt" and execute these commands: compact /U C:\bootmgr compact /U C:\ntldr If you for some strange reason have lost your Vista DVD, then you can also use a Windows 2000 / XP install CD and enter the recovery console instead and execute the following commands: attrib -c c:\bootmgr attrib -c c:\ntldr
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 21, 2010 | Acer Aspire 8920-6048 Notebook
Laptop help
sounds like something got hosed up......use the recovery partition and reload windows....easiest thing to do....Good luck...
Jan 12, 2010 | Acer Aspire 5315 Notebook
Bootmgr is compressed and press ctri+alt+del to restart
Hello ajay1 8 83
You need run SFC /SCANNOW
Read this first for more understanding http://support.microsoft.com/kb/936212/
Try booting to your Vista installation CD. Choose Repair. Select your operating system, should bethe only one. It will repair the BOOTMGR.
Jul 12, 2009 | Microsoft Windows XP Media Center Edition...
Compressed boot manager
Windows Vista includes a new Boot Manager (BootMgr) that replaces the old NT Loader (Ntldr).
This can usually be solved by checking the boot devices, and if no problems found then use Windows Recovery Environment (WinRE) and perform a "Startup Repair".
This can usually be solved by using Windows Recovery Environment (WinRE) and perform a "Startup Repair". If that fails then use WinRE to enter the "Command Prompt" and execute these commands:
  • compact /U C:\bootmgr
  • compact /U C:\ntldr
Aug 28, 2008 | Computers & Internet
BOOTMGR is missing Press Ctrl+Alt+Del to restart
first u go to bios settings and change first bootdevice cdrom and reboot system u put winxp cd in cd drive
u will see this message
press any key to boot from cd
u press any key
winxp setup start automatically
and repair winxp
som case hardisk partition probelm , that case u will format drive and re install winxp
Jul 12, 2008 | Computers & Internet
IBM ThinkPad T43 Notebook Logo
203 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
