Question about Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive
No Allocated letter on HDD
I have a two year old PC that was running its original installation of WinXP pro SP2. I have an AMD 6400+ Dual core Processor and 2.5 GB DDR2 RAM, NVidia Geforce 7600 GS 512mb GPU and a 250 GB SATA 1 HDD.
It's the HDD that's giving me the headache. Boot times had reached 5 minutes plus! No matter what I did I couldn't reduce it. I had a lot of Photo's and music on the drive so unless I copied it all to DVD I'd loose it all on re-format.
I decided on a different solution and bought a second SATA 1 drive, 500 GB. Using a fresh WINXP Pro installation on the second drive, I placed it in SATA slot 0. I placed the original drive (250GB containing all my wanted data) in the SATA slot 1. This worked a treat and I was able to boot the PC and access all my data from the old drive without a problem.
As luck would have it the new installation developed a bug with the desktop and it seemed quicker to do a second fresh install of WinXP pro, than try and fix the bug. All went well except on completion the old drive didn't show up under 'My Computer'.... Nothing at all! However, if I went into 'Device Manager' it was there and was showing as working perfectly, (Which it certainly wasn't). Also, if I went, Control Panel / Administrative Tools / Computer Management / Storage / Disk Management, there was the HDD showing but no drive letter was allocated to it. Right clicking the drive did NOT bring up the option to change the drive letter or path.I tried removing the old drive altogether and reformatting the new drive and doing another WinXP pro install. Then re-connecting the old drive. Same result! I then bought a caddy and mounted the drive in that, hoping Windows would see it through a USB port as an external drive. No luck!I can pull data from it with a drive resalvaging program but its a mess. There is no file tree at all. Everything is completely random, plus every graphic the PC has ever seen is there even viewed web pages and the job of sifting through it all is endless. Also any file that spans two sectors is chopped in half so most of the recovered music is useless.
Can you help please?
  • topperbrenha Nov 29, 2008
    Thanks for the advice but if I boot from a second drive I can't scan the old drive as Windows XP can't "see it." Nor can I run an antivirus scan for the same reason. I shall try to "fix" the mbr and see if that does the trick.
    Regards.
  • 55 Answers
i think you lost the mbr of old hdd. Or you have a virus problem on your pc. firstly you boot the pc with new hdd and then scan the whole drive by an updated antivirus and then boot prom old hdd. if it is not solve your problem then rebuild the mbr by any software which are avalable on net.
i think it can solve your problem.
ramesh
Posted on Nov 29, 2008
I can't install AUTOCAD 2009 in my windows XP computer.It asks to install direct 3D
Most probably your hardware ie graphic card do not support software requirements.
Autocad 2009 system requirements for Win XP.
32-bit AutoCAD 2009
Running under Windows XP:
•Microsoft Windows XP SP2 operating system
•Intel® Pentium® 4 processor or AMD Athlon®, 2.2 GHz or greater
or
Intel or AMD Dual Core processor, 1.6 GHz or greater
•1 GB RAM
•750 MB free hard disk space for installation
•1024x768 VGA with true color
•Microsoft Internet Explorer 6.0 (SP1 or higher)
If you are using AutoCAD for 3D modeling, you should bump up your system as follows:
•Intel Pentium 4 processor or AMD Athlon, 3.0 GHz or greater
or
Intel or AMD Dual Core processor, 2.0 GHz or greater
•2 GB RAM or greater
•2 GB of additional free hard disk space
•1,280 x 1,024 32-bit color video display adapter (true color) 128 MB or greater, OpenGL or Direct3D capable workstation class graphics card.
Hope it helps.
Mar 22, 2011 | Computers & Internet
PC shuts down after logging in to WinXP pro Athlon uP
reinstall the window xp
open my computer from the start manue
go to view and open folder options
show the hidden files and also deselect the protecting window files below it
and apply
then click on the folder on the top in the my computer
and remove all the suspected hidden files from all the drives and restart your system
Dec 21, 2009 | EliteGroup GeForce 6100SM-M Motherboard
After installing Vista SP2. computer tries to reboot, but cant configure update 3of 3, so it reboots to start all over. tried setting CD as 1st boot, hangs waitng for CD-rom then boots off HDD. Tried...
ok go into your bios and load default settings.
set your cd-rm as your first boot device. then HDD.
save settings and exit. allow unit to reboot.
you can contact me direct e-mail. rain_catcher000_6@hotmail.com.
so i can give you one on one technical support.
Nov 14, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
After installing Vista SP2 update computer wont reboot from HDD or CD w/ vista CD
ok boot the computer and as soon as you see the black screen hit f1
or delete to enter bios go to boot menu and configure the cd-rom to be your first boot option. you can also hit f12 when you first see the black screen to enter boot menu. choose to boot from cd .
ok now install the disk and choose repair system .
Nov 13, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
I want an upgrade on my video card...
more cpu and a better graphics card, id say get a amd athlon x2 dual core [Cpu]
And a Nvidia Gefore 8800GT
May 28, 2009 | Computers & Internet
Cannot see drive letter for deskstar 7k250 in usb enclosure winxp
Add a letter for this HDD in "control panel\performance and maintenance\administrator tools\computer manager=ment\disk management"
Feb 16, 2009 | Hitachi Deskstar® T7K250 250 GB Hard Drive
Winxp Drivers For CQ45-112AU or CQ45-106AU
Hi there
Apparently this model is only able to work on vista, - have a look at HPs page, here:
regards /Teis
Jan 17, 2009 | Compaq Presario Notebook
Sp2 on dual core cpu
Please read and follow the article for your issue trouble shooting.
http://forum.notebookreview.com/showthread.php?t=60416
Thanks
Cyber_kaka
Nov 21, 2008 | Microsoft Windows XP Professional With...
Western Digital 250GB MyBook External USB 2.0 250 GB Hard Drive Logo
119 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
