Question about Panasonic Navigon 5100
Navigon 5100 won't turn on when battery is charged.
Charged battery for six hour will not power on.
  • 7 more comments
  • Anonymous Dec 26, 2008
    brand new and charged for 6 hrs and will not turn on
  • riesford57 Feb 07, 2009
    it has a green light but nothing happens when we hold the power button. Tried 6 sec on up. even tried just a quick hit also.
    We don't find a reset switch anyone know where it might be?
  • razorback23 Feb 23, 2009
    I have had this product for about a month, and have the same problem. I cannot get it to turn back on.
  • Anonymous Feb 27, 2009
    Used it a few times and won't turn on.
  • Anonymous Mar 02, 2009
    It suddenly just had the Navigon screensaver on it and it wouldn't go off whether we turned the gps off or not. NOw it just has a blank screen and won't do anything.
  • Jjabberwock Mar 26, 2009
    Have charged mine (haven't used it for a few weeks), the light is green and I can't turn it on. Damn!
  • Anonymous Apr 06, 2009
    Same problem. Had it about a year, and now nothing. Piece of junk!!
  • Anonymous Apr 14, 2009
    same thing here in Texas.. POS
  • Anonymous May 16, 2009
    Same here! I had the screensaver pop up one day that wouldn't go away then it died and I charged it and got one more use out of it then it just went blank
Try holding the power button down for 15 to 20 seconds - that worked for mine!
Hope that helps
Posted on Aug 06, 2009
Hi everyone, this happened to me to - green light on but wouldn't turn on. I pressed the reset button (found next to the usb) and simultaneously pressed the power button - hey presto - it came back on. I have the Navigon 20 easy, hope this works for you too.
Posted on Jan 24, 2011
1992 Mazda mpv . Won't hold charge . Engine won't
The first thing to do is have the battery tested, just because you charged it doesn't mean it will stay charged if the cells are sulfated up or shorted.
Oct 02, 2012 | Cars & Trucks
I have navigon 6300 Gps when i switch it on it starts up then switches off
Hello
Check the power source. If the battery of the vehicle has not enough charge, this may happen. Check it. The problem is with its working voltage itsef. OK.
Jan 28, 2012 | Navigon GPS
My navigon 5100 gps wont charge while in use
Switch it on and let it totally discharge - the battery could have established a memory and thinks that it is fully charged -the wonderful world of electronics where nothing is what it seems.
Once discharged put it to OFF position and recahrge it.
Good Luck
Sep 13, 2009 | Panasonic Navigon 5100
NAVIGON 7100 WON'T TURN ON
your battery is gone requires new one.
Aug 20, 2009 | Navigon 7100 GPS Navigator GPS Receiver
Navigon 5100 When connected to charger, computer icon comes up
you are not using a charger with the right voltage- you need 5 volts 1.2 amps radio shack has a gps charger that will work
Jul 15, 2009 | Panasonic Navigon 5100
My Navigon 5100 GPS will not turn on. At times, when it does turn on, it will not turn off.
I'm not sure if you realize this, but you must hold the power button for about 10 seconds to turn the 5100 on and off.
Jul 12, 2009 | Navigon 5100 GPS Navigator Handheld GPS...
GPS signal not sufficient on iPhone 3G
Had the same problem with Navigon for the iPhone. I found a simple quick fix:
1. Go to your iPhone Settings
2. Press the General tab
3. Scroll to the bottom and press the Reset tab
4. Press the Reset Network Settings tab
This may take a short time, then after it's done, reboot your device (if it doesn't on its own).
You should now have a good GPS signal!
Jul 05, 2009 | Navigon 5100 GPS Navigator Handheld GPS...
Wont turn on
This has happened to me with my tomtom, I freaked out! What there is, is a reset button somewhere located on it. It should be a small hole you can fit a pin or needle into. Do this, and hold the small button inside down... let go and try it again, should turn on!
Good luck! :)
May 27, 2009 | Panasonic Navigon 5100
Navigon 5100 gps
Try turning it off and turning it back on while it is still plugged in and see if that works.
Oct 23, 2008 | Panasonic Navigon 5100
Panasonic Navigon 5100 Logo
2,376 people viewed this question
Top Panasonic GPS Experts
Richard Foster
Richard Foster
Will Halftowaite
Are you a Panasonic GPS Expert? Answer questions, earn points and help others
