Question about Plumbing
Side spray has very low pressure
After only one month, my kohler kitchen faucet side spray has lost pressure. What is the fix for this problem?
  • James Feragola
    James Feragola May 11, 2010
    Do you have hard water?
    Take the hose off of the handle and see if any sediment comes out.
    Press the spray button while the spray head is off and blow through the outlet side so that air is coming out of were the hose screws in.
  • 334 Answers
Disassemble the sprayer and remove the dirt and dibri gathered inside.
Reassemble.
Has the water been turned off to that faucet, or the entire home recently? If yes, it probably loosened sediment in the pipes and its clogging the sprayer.
Posted on Dec 06, 2008
New kitchen faucet worked for 4 weeks, now the water flow is very low
Check the inside of the faucet for debris blocking the cartridge or the inlets.
Sep 29, 2014 | Kohler Kitchen Faucets. Elate Pull-Out...
Diverter
Hi! Yes it sounds like the spray diverter needs replacing. Kohler .com will have this part online or you could try a plumbing supply shop.
Mar 29, 2014 | Kohler K-10413-VS Forte Single-Control...
Kohler Fairfax kitchen faucet has low flow pressure. Any suggestions? It's the faucet, not the water getting to the faucet that has the low pressure.
First thing to check is if it has a strainer on the spout that has debris. The second thing is if you have a sprayer attachment the diverter valve is a chronic problem with kitchen faucets.
Dec 29, 2010 | Kohler Fairfax Single Control Lavatory...
Hi just moved in new home love it but the water pressure in kitchen is very low but the two baths i have the water pressure is fine can you help me please
One thing you could try is to remove the aerator at the end of the spout on the faucet, Turn water on and see if pressure is any better. If so the aerator is got something in it restricting the flow.
You also can remove the dime shaped flat in the aerator to increase water flow. It looks like a dime with a hole about 1/8" in center to restrict the flow to about 1.6 gpm. Remove it and reinstall aerator and check water flow
Most of the times when cold and hot side of faucet.It would be the first thin to check being you have good water pressure at other faucets. They catch debris and the flow slows down from the faucet's. Check out supply lines and faucet for a blockage if this doesn't take care of the problem.
Check out this web sire for a parts breakdown of parts in faucet. Check out installation and rough in sheet for information on faucet below.
http://www.needplumbingsupplies.com/Kohler-Kitchen-Sink-Faucets.asp?id=3628
Jun 15, 2010 | Kohler K-12176-PB Fairfax Single Handle...
Low stream
these faucets have a single handel, and have a cartage that can be taken out and cleaned. Low water pressure is caused by minerals in the water to build up in the cartage and slow down water flow.
Mar 28, 2010 | Kohler K-10416-BN Fort½ Single Control...
Kohler forte single control kitchen, low colder water pressure
1. If it is old enough, it is time to replace the control cartridge.
2. Check your supply stops under the counter, check that they are both supplying full pressure.
Nov 16, 2009 | Kohler Forte Single-Control Remote Valve...
The water pressure for the hot side is less than the water pressure for the cold side. what can be done to correct this?
one of supply tubes partly blocked,turn off water supply ,disconect coupling for tubes underneath,
remove screen on faucet and blow out with air this
should remove obstruction replace in reverse and recheck pressure
Nov 01, 2009 | Kohler K-10416-BN Fort½ Single Control...
Kohler K-12177 low water pressure output. Removed
check valves under sink make shure tey are all the way on but spray them into a bucket if you can to see if they are ok.
Oct 25, 2009 | Kohler Model 10433: Fort® Single-control...
Cannot pull out spout to replace o'ring of Kohler Faucet 10416
the pic u have up doesnt show it being a pull out u trying to fix airater?
Jan 31, 2009 | Kohler K-10416-BN Fort½ Single Control...
Plumbing Logo
858 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
