I would like help setting up my qnap 209 II nas server as a FTP server. Can you help?
  • 10,515 Answers
Hey dude,
Link for the set up :) including the pics :)
http://www.pcreview.co.uk/reviews/Storage/QNAP_TS-209_Pro_II/
i hope i have answered ur query. If ur satisfied with the answer, do check the post as "Fixya" as this is the only way i wld be paid for my services.
Thnx.
Posted on Nov 29, 2008
Unable to login to SmartNAVI how can I reset to factory defaults to create a new user name and p[assword?
The user manual for this device is available on the manufacturers website. Promise NS4600 manual.
The instructions (with pictures) are on page 197 of the manual (or page 209 of the PDF).
"To reset the Administrator's password:1. Verify that the SmartStor is fully booted.
2. Insert your reset tool into the reset button hole on the back of the SmartStor.
3. Press and hold the reset button for eight seconds, until the System Status LED flashes three times. The Administrator's password is now reset to admin."
Oct 23, 2013 | Promise SmartStor NS4600 4TB 4 x 1000GB...
Mac OSx 10.8 cannot search BUFFALO TS-8VH24TL/R6 24TB
Specs only indicate Windows. No iOS. Might be cause of the RAID configuration / software.
Though it does support HTTP and FTP protocols.
Nov 05, 2012 | Buffalo Technology - TS-8VH24TL/R6 -...
FTP not working on BlackArmor using IE or Windows 7 Explorer Share created, even public access enabled. Details: 200 Switching to ASCII mode 550 Permission denied
Check on BlackArmor Manager that the FTP mode is enabled for the folder you want access to.
You can check it by typing "http://192.168.1.66" in the adress bar on your explorer, enter your login and password ("admin" and "admin" by default), then click
storage -> shares
if "FTP" is disabled, click on the pen (modify) and enable it. don't forget to click "submit" ;-)
Hope it was helpful
Sep 24, 2011 | Seagate BlackArmor NAS 110...
Getting write-protect error on qnap ts110 folder
right click on the folder select properties thwn click the sharing tab make sure the folder is sharing and the box is not ticked make this folder private in xp
You will have to be the computer administrator to change any values on any hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options select the security tab option then advanced make sure you have full control in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
Remember do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
Jul 03, 2011 | QNAP Systems TS-110 QNAP Turbo NAS, USB...
How to set up a wireless file transmitter(WFT-E4 II) to canon eos 5D mark II
Configuring communications settings in FTP mode1. Select [Address setting] with the camera's Quick Control Dial.
2. If you choose [Disable] for DNS server setting, enter IP address. For [Auto assign], enter server name. For [Manual setting], set up IP address.
3. Set up [Port No.] usually at 0021.
4. Configure [Proxy server].
5. Configure [Login method].
6. Set [Target folder] to [Root folder] or select folder using [Select folder] menu.
7. FTP server connection is established.
Note: Settings can be stored in the camera.
Configuring automatic image file transfer in FTP mode1. Select [Set up] in [WFT settings] menu.
2. Choose [Automatic transfer].
Configuring communications settings in PTP mode1. Select [OK] from Pairing screen.
2. Start WFT Pairing software on PC.
3. Double-click the icon inside PC task bar.
4. Select the WFT-E2/E2A/E3/E3A/E4/E4A [MAC address] you want from on-screen list of cameras.
5. Connection to camera is established.
Remote control of cameraOnce you start EOS Utility, you can control the camera remotely, using all available functions.
May 05, 2011 | Canon EOS 5D Mark II Digital Camera with...
What is nas
network attached storage server using bsd.used for backup
www.nas.org
Feb 05, 2011 | Microsoft Windows XP Professional for PC
I have a TERASTATION PRO II 2TB 2URM NAS 4X500GB. It seems to be shutting down unexpectedly. I have all the sleep modes disabled and the switch on the back set to auto. No temp issues and I have it...
no i would concentrate on the date time issue than see if you have any more problems i wish you the best of luck and if it works out OK please give me a good vote
Nov 29, 2010 | BuffaloShop Buffalo's TeraStation Pro II...
Please can you tell me user name and password for web interface?
username: admin
pwd; <blank> just leave blank
try also u:dmin p:admin
Sep 24, 2009 | Ma Power 3.5" LanDisk, IDE to USB / RJ45,...
Need Infrastructure Hint
If you need to store this data for several years, it's going to be a huge machine.
I solved a similar issue by using a standard PC and fill it with disks, and then run Freenas on it. It's BSD based, gives you NFS, SMB/CIFS, iSCSI, FTP, HTTP/WebDAV, Apple, ... connectivity in an open source package, ready to go, easy to manage. it supports doing software Raid 5 with a bunch of disks, so stable and secure. I even lost a disk last week, and replaced it with another one. After 2h the system was 'OK' again...
If you really need huge storage capacity, go for a 'standard' storage server (supermicro for instance) that can store 24 or more disks... You have them in several brands, and the SuperMicro ones aren't that expensive.
Put in a bunch of inexpensive disks (500GB SATA-II disks are really affordable these days) and create a RAID5 array out of all these...
If you want to be even more secure, go with hardware Raid controllers. We use 3Ware/AMCC controllers all the time.
If you got the money, Sun just released a couple of 'Storage Servers' in their 7000 series... Go check them out...
Nov 13, 2008 | San Computers & Internet
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
