Question about Electrical Supplies
Bathroom light switch faulty
Bathroom light switch (2 toggles) operates two lights. 1 bank of lights gone out. Opened switch, found 2 cables coming in, 1 with a red and earth and the 2nd with a red and black.The first cable has the earth properly earthed and the red going to A1. The second cable has a red going to A, and the black was loose! A and B are joined by a small red cable. I presume the black should go to B1, as 1 bank of lights work like this, but the other doesnt.
  • 92 Answers
Hi you have many way to connect it go to http://www.hometoys.com/htinews/dec97/articles/kingery/kingery6.htm
good look
Posted on Dec 04, 2008
My bike won't start from the button and all my rear lights will not come on
Hi, Ja and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Security alarm needs a reset.
6. Starter control circuit, relay, or solenoid faulty.
7. Faulty starter button.
8. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
Good luck and have nice a day.
Aug 13, 2015 | Motorcycles
The engine won't turn over
Hi, Anonymous and the usual suspects are:
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Faulty ignition switch.
6. Faulty starter button.
7. Faulty kickstand or clutch pull in switch/sensor.
8. Security alarm needs a reset.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
1985 yamaha maxim won start
Yamaha XJ750 not starting
Yamaha XJ700N Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
May 18, 2014 | Yamaha XJ 700 X Maxim Motorcycles
Check engine light is on and i got error code p1133. what is that?
Faulty Heated Oxygen Sensor (HO2S) Bank 1 Sensor 1
- Vacuum leak
- Faulty Heated Oxygen Sensor (HO2S) Bank 1 Sensor 1 harness is open or shorted
- Faulty Heated Oxygen Sensor (HO2S) Bank 1 Sensor 1 circuit poor electrical connection
The Powertrain Control Module (PCM) monitors the Heated Oxygen Sensor (HO2S) activity for 90 seconds after closed loop operation has begun. The PCM determines if the front HO2S is functioning properly by counting the number of HO2S-1 Lean/Rich (L/R) and Rich/Lean (R/L) switches.
If the Powertrain Control Module (PCM) determines that the front HO2S did not switch enough times, the PCM will set the P1133 code.
replace the o2 sensor
Dec 14, 2013 | 2006 Saturn Vue 2.2
Intermittant no start
Hi Anonymous, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections check negative cable at both ends. (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to on.
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
7. Security alarm not disarming
For a prime suspect please visit website below and good Luck.
Harley Davidson Wiring Diagrams and Schematics
Sep 02, 2013 | Harley Davidson Motorcycles
Harley wont start
Harley Diagnostic Codes 04 to Present
May 20, 2013 | 2005 Harley Davidson FLTRI Road Glide
The bathroom light does not turn on, I changed the switch but now the light in the hallway does not turn on. The original switch was wired through the back but I have changed it to the side.
Is the bathroom light controlled by two switches?
Is the hallway light controlled by two switches?
What color wires are in the bathroom light switch that you changed?
Side wiring will not change the way the switch works.
Dec 12, 2010 | Leviton White 3-way Toggle Switch 15a...
Our switch for the ceiling fan burned out today. Instead of getting the same type of switch (rotary knob with push on/off) I bought a Pass & Seymour combination toggle switch (dual on/off toggle...
The wire to the ceiling fan are meant to send voltage to the fixture only and are not usually wired to control both the light and the fan independently. In order to do that, you may have to pull another set of wires to the switch box and then connect them to the light circuit in the box where the fan is. In regards to the other wiring that you mentioned, it makes no sense that the wires go to the stove fan and the bathroom fan unless those wires are source wires that carry the incoming voltage.
Mar 17, 2017 | Pass & Seymour #690IGCC6 15A Ivory DPLX...
What if the light that is being connected has been added, thus the reason for the outlet being converted from 2 plugs to now 1 with a toggle?
I don't exactly understand your question, but to control that light using a switch you have to have two sets of cable one coming into your switch box and one going out of it. Tie your two whites together and the two black wires go on your switch, whereas on a receptacle black and white wires go on the terminals.
Jun 20, 2010 | Pass & Seymour #660IGU 15A Ivory SP Toggle...
Wiring comination 2 switch, with exisiting light to new bath fan
Hello anonymous,
I am concerned in so many ways... (USA NEC assumed):
FIRST concern:
(after the obvious BATHROOM/GFCI issue) is the
NATIONAL ELECTRIC CODE for wire/device capacity
INSIDE your existing ELECTRIC box...
The CODE requires wires to have space ... aside
from the fact that it is just plain dangerous to
pack wires densely and pack them together tightly...
Then... of course... You have said nothing about the wire gauge/ampacity... (again assuming 14 Gauge/15 Amp)... you will have to calculate the fill for each wire and check the Cubic Inches Plus your device against the ELECTRICAL BOX rated capacity...
That is just the BASICs of SAFETY.
Looking for a diagram of your
"1595" Legrand Pass & Seymour I have failed miserably.
I have found what YOUR switch looks like...
From an old electrician's standpoint...
If you have EACH device wire separately thru
their respective switches...
There should be NO POWER to operate the FAN.
The FACT that there is ... Is highly PROBLEMATICE.
It would seem that a PREVIOUS ELECTRICIAN
has switched the NEUTRAL side of your
old light circuit... Easy to prove with a VOLT TESTER.
I Recommend KLIEN NCVT (non-contact volt tester)
Klein Tools NCVT 1 Non Contact Voltage Tester Electrical Tools Amazon com
A SWITCHED NEUTRAL
poses an EXTREME hazard in a bathroom
(any water) location but is EASY to fix...
Rip it ALL apart and properly configure all the EXISTING WIRES...
Do it right... Be safe.
WHAT ARE TWO BLACK WIRES FOR COMING OUT OF PASS sEYMOUR 1595 SWT SWITCH FOR
Carnac the Magnificent
Apr 30, 2017 | Pass & Seymour / Legrand 1595-2SWT...
Electrical Supplies Logo
200 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
