Question about Dell Inspiron 700M Notebook
Laptop speakers stopped working
I have a Dell Inspiron 700m. My laptop speakers have always worked unit recently, when i used some headphones to view a training video for work. After removing the headphones, the laptop speakers did not work. I do get audio from the headphones when I plug them back in to the laptop. Thanks for any help. Mike
  • 5 more comments
  • sunny723 Nov 13, 2007
    I have the similar problem of speakers not working on the Dell Inspiron 6400. When I use my headphones, I do get sound on the headphones but when I take them out speakers don't work. I've updated drivers, reinstalled drivers, e.t.c. - pretty much everything on the Dell support site.
    It looks like it may be a case of what you;re describing. Unfortunately, my laptop is out of warranty. So, I will have to disassemble and see what else I can do. Please post the disassembly instructions and what else I can try to resolve this problem. Thank you so much!
  • 521mck Dec 27, 2007
    Speaker does not work when the laptop screen is open but when I close the screen it works.
  • Anonymous Jul 27, 2008
    I had the some problem with the speakers, i need the disassembly instructions photos
    thks
  • Anonymous Oct 14, 2008
    speaker is not working when i unplug the head phone
  • Anonymous Apr 04, 2009
    my speakers on the dell inspiron 700m also does not work but my earpones work fine when plugged in
  • Mark
    Mark Apr 11, 2009
    the wire for the speakers run through the screen hinge, what happens is the hinge slices through the wires. ive replaced the speakers 2wice so far on mine, have a thrid set brand new on standby, spliced the wires 3 times, and they still get cut. this model laptop was badly designed and im never buying a dell again, they just kinda ****.
  • Anonymous Mar 21, 2014
    all of a sudden my line out for external speakers or headphones doesn't work.
  • 624 Answers
Hello fadesit, It sounds like the headphone socket is sticking/defective. When you insert the jack into the socket a contact is broken to disable the external speakers, when you remove the jack the connection is resumed. Due to the amount of work this will take and the possibility of causing other problems in the process I would check to see if the warranty is still in effect first. If not then the next thing to ask is do you have the tools, mechanical aptitude, patience and ability to risk damaging your laptop to do this yourself? If you want to go the do it yourself route let me know and I?ll post some disassembly instructions later tonight otherwise please don?t forget to rate the posting.
Posted on Jan 17, 2007
Hey,
After reading the problems you posted, as I had had the same one, I took my fist and hit around the headphone jack, and guest what, it worked.
It may not work in all cases but worth a try. I'm sure it might come loose again, but the problem in my case was definitely the headphone jack issue and my hitting lightly around that area it seemed to have restored things for now.
Thanks for the help.
Posted on Oct 04, 2008
Hi I had the same problem what is happening is the speaker wire funs up through the hinge and what happens from open and shutting it so many times is it disconnects you have to take apart the laptop to repair it. would suggest finding a breakdown of it. if you cant find a site the little round pads on the monitor come off and you have to unscrew those and one hidden screw left of the wifi light you have to peel the sticker back. good luck
Posted on Feb 17, 2008
SOURCE:
Dell inspiron 700m no sound
You may have the well known issue just as I had which is the lines running up the left side from keyboard to screen which are supposed to go to the speakers easily break because they are very small and they break from just the opening and closing of the screen. It's no worry I dug it all out and still just went on Amazon and got a USB audio speaker/headphone interface for $8.
Here's what I got and I am very happy....you will save a lot of time to just grab this now... Trust me. I would never suggest if I didn't like it and have used or owned it. http://www.amazon.com/gp/aw/d/B00BP2REBK/ref=pd_aw_sims_8?pi=SL500_SS115
Jun 14, 2014 | Dell Inspiron 700M Notebook
Hi,my speakers stopped working.. I plugged in a headphone and it stopped working..it was working fine before
If neither the headphones or the speakers work, then there may be an issue with the sound card drivers, so I'd uninstall them and reinstall the drivers. If headphones work but speakers do not, take off the hinge cover, see if one of the wires are broken (Happened on mine) if so you can splice, but the are is close work.
Feb 25, 2010 | Dell Inspiron 700M Notebook
No sound from the speakers with my dell laptop inspiron 700m I trouble checked everything.I have the sound when I plug my headset. Is it a sound card or a driver problem? Can I download another driver?...
Fred if you get sound to your headset from the same port you get no sound for your speakers, it is the speakers and not your headset. Are there any speaker lights on at all? If not maybe your power supply for the speakers is bad.Try a different set of speakers in the same computer and see what happens. If they work, the speakers are bad. Otherwise you have some strange connection problem.
Feb 03, 2010 | Dell Inspiron 700M Notebook
Internal speakers do not emit sound but I can hear w/ headphones
I have a 700m, so I'm real familiar with the system. I see one of 2 possibilities. The headphone jack has a switch that disables the on-board speakers, if that is stuck or broken, then the jack/switch must be replaced. (Big hassle)
The other is easier to troubleshoot, then connection from the speakers to the MB goes through the Right hinge cover. Take the hinge cover off, check for broken wires (I has one, ***** to splice too)
Jun 05, 2009 | Dell Inspiron 700m Notebook
No sound from internal speakers on Dell Inspiron 700m ?? Any Ideas. I ahve atried all the basic stuff
sometimes the wires for the speakers break... just take the laptops panel above the keyboard out, remove keyboard, unplug the 4 white and black wires, and repair the break... Takes about 10 minutes to do! and you'll get your sound back.. Dell had a small design flaw there, but you'll get the speakers running easily! Same thing happened to my Inspiron 700M..... You can splice the wires and fix it yourself!
Jan 03, 2009 | Dell Inspiron 700M Notebook
Headphone jack does not work
It could be a broken or cold solder on the motherboard OR the circuit on the motherboard is defective. Either way the motherboard has to be removed from the laptop to fix or replace it.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 02, 2008 | Dell Inspiron 6000 Notebook
No sound from laptop
Sounds like everything has been done that can be, new sound card, drivers, and format. The only thing left is the motherboard. It's rare, but I have seen a few machines that when the sound card went out, especially if the card went out violently by overload, short etc... the traces (circuit paths) in the motherboard, or the seat for the card on the motherboard were damaged. Have them run the traces and check the seat on the motherboard to determine if this is the cause of the problem. If this is the case, unfortunately, motherboard replacement is your only option in order to get the sound to work.
Aug 10, 2008 | Dell Inspiron 700M Notebook
Dell Inspiron 700M Notebook Logo
3,565 people viewed this question
Clive
Clive
Alun Cox
