Question about Kenmore 88732 Top Load Stacked Washer / Dryer
Stackable washer I am having problems with my washer it has filled with water and now it does nothing it acts like it wants to agitate, but then clickes its self off. i don't have the money or the know how to fix it. i bought it from a person just a few weeks ago boght new hoses and gas conecetion pipes and stuff now it worked good for about 10 loads then quit please help me it is an older model i hope it is a belt or some thing but i don't know where to look for that kind of thing. thanks
  • litjuan Nov 04, 2007
    The washer does not drain the water. It just stop.
    President:
  • 878 Answers
Ibunton. 10 loads, what some bad luck. Your model is a direct drive, so there are no belts. From your description it almost sounds like your drain pump is jammed causing the motor to kick on overload. Remove the front panel by pushing on the two clips just below the top on each end about 2 inches in. The panel will pull off. The pump sits right in front. There are two clips that hold the pump on. Remove the clips and pull the pump off. Now put the timer to the spin position and start it, see if the motor turns. If so, your pump is probabley jammed with something. If it is the pump the part number is 3363394. Easy fix, 2 clamps, 2 clips. If the pump is ok, then we'll have to dig in deeper. The attachment shows a top loader, but the pump, motor and trans are the same as your stacked unit. Catriver...post back
Posted on Jan 20, 2007
I have a GE spave maker Laundry that fills up with water than stops!
GE Washer Not Agitating Repair Guide
www.appliance-repair-it.com/GE-washer.html
If your washer will not agitate or spin take a look at this page GE Washer Not ... If the washer fills up with water then doesn't do anything at all and you do not hear ... if this were the problem, the water would not stop running, over-filling the tub.
GE washer spin cycle not working - ApplianceBlog
www.applianceblog.com/.../217-GE-washer-spin-cycle-not-working
Mar 12, 2005 - 10 posts - ‎3 authors
I have a GE "Spacemaker Laundry" (Stackable) model number ... Today it filled withwater initially then stopped working all together when it ... Bad motor, something jammed/seized up holding the motor back from running?
Jan 10, 2016 | GE Spacemaker Washer and Dryer Electric...
Older maytag stackable washer and dryer combo washer fills , washes and spins but water wont pump out
check for the pump belt broken or off,clogged pump or sock or small item clogging the tub outlet to pump hose. the pump pulley may have become loose on the shaft also
Feb 28, 2013 | Maytag LSE7806A Top Load Stacked...
Fridgidaire stackable washer dryer model: fleb8200dso will not fill with water
You will need to replace the water inlet valve. Here is the part to order.
Here is the service manual to help you with the repair.
Nov 26, 2012 | Washing Machines
Maytag stackable top load wash maching - will fill with water but then nothing. It just stopped.??
Hi. Listen for an audible click as you just open and close the lid. You should hear a micro-switch. If you do not hear that click you most likely have a bad lid switch. A bad lid switch on a Maytag washer will still let it fill BUT, it will not agitate or spin.
If you hear a click then there are other things to that can cause the symptom that it would spin but not agitate.
Thanks for choosing FixYa,
Kelly
Aug 26, 2010 | Maytag WD16 Top Load Stacked Washer /...
The stackable washer will not agitate
Give me a model number. Fridgedare and White westinghouse made some of these stacks for Kenmore. I'll need to know the manufacture. Reply with the whole model number and I'll help.
Aug 27, 2009 | Kenmore 98702 Stacked Washer/Dryer
Frigidaire stackable will not stop filling with water or agitate.
yes unless pressure switch(water level switch)detects proper fill level wash will never start agitating some washer will not spin if switch does not detect empty tub
Jun 02, 2008 | Whirlpool LTE6234D Top Load Stacked...
Model 417.94802301 stackable with electrical haywire?
you got a problem with your power supply for sure. check and make sure both your breakers are on inside the fuse box. turn them completely off and them back on(there should be 2 linked together for this unit. if that ok try to gt behind the unit and check the incoming power source(make sure wiring on rear of dryer is in tact. def sounds like inadequate power supplied to unit
Feb 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Maytag washer
This is similar to a problem I had after my power suddenly went out while the washer was filling with water. When the power resumed the washer would no longer run water... all other systems (agitate, drain, spin) worked fine.
A 10 minute, $113 dollar service call revealed that there was a fuse inside the front upper left area that had blown. Remove the 2 screws at the bottom of the front panel to get access to the inside.
Check it out and replace it if necessary.
Jan 20, 2008 | Maytag LSE7806A Top Load Stacked...
Kenmore 88732 Top Load Stacked Washer / Dryer Logo
85 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
