Print is ready to be sent to the printer - press "print" and nothing happenns.
    Genius:
  • 1,447 Answers
Hi
Try to check the queue of the printer. try cancelling the documents pending and make sure printer status on printers and faxes is ready. keep us posted.
Hope this helps
Posted on Nov 29, 2008
Plotter will not print
Check lan card led blinking pattern., Replace lan card(Jetdirect card 620n) & check, mostly lan card issue might be there..
Jun 12, 2015 | HP DesignJet 5500PS InkJet Printer
When I press "print" from file in upper left corner of computer it doesn't print
You may wish to check that your printer of choice is clicked as the default printer. Or you may need to reinstall the printer drivers.
Nov 20, 2011 | Office Equipment & Supplies
I am unable to retrieve fax from memory, on the Fax Setup menu no reference to faxes in memory. I have a Lexmark 6650. When the fax wa sent it said "printing" but nothing came out
Usually, faxes are temporarily sent to the printer's memory when one of the cartridges' ink level is not substantial for printing. You are advised to replace the cartridge/s, *without navigating away from the message "fax sent to memory", by opening the printer cover and replacing the low-ink cartridge/s. After the new cartridge/s is installed, close the printer cover and press OK button to let printer print the fax stored in the memory.
* Make sure not to navigate away from the "fax sent to memory" message. You will lose the fax-in-memory data once you turn off the printer or navigate away from the message.
Aug 16, 2011 | Lexmark X6650 4-In-One Wireless InkJet...
Hi, the green light is steady on the lightbulb icon. And im unable to print
This light sequence means that the printer is ready to receive and process data but it is in Power Saver mode.
If a print job is sent, Press Continue to print the menu settings pages for a list of current printer settings. You may also Press and hold Cancel to reset the printer.
Please call Lexmark Technical Support for additional assistance.
Jul 09, 2011 | Lexmark E260dn Laser Printer
HP Officejet 5610v: Sent document to print. Somehow the settings were set to print offline, so nothing came out. I "unchecked" the "print offline" option. I tried to...
This Utility program resolve all the printing issue for HP Printers ( Network and USB connection )
This Utility will Resolve :
1. Check Connectivity between the Pc/laptop and HP Printer
2. Check if there any Documents stuck in Queue
3. Check if all the software/Drivers are correctly Installed
4. Check if the HP Printer icon is the default icon to print
5. Will Resolve Printer Spooler Issue and few more issue
This Utility program will fix all these issues.
Download the file on Desktop and Run the program ( Ex. File name = HPPDU.EXE )
Click Here to download the Utility and save on Desktop location
Run the HPPDU file and follow the instruction on screen to fix.
Regards,
Ron
* Please rate this solution with Thumbs up and comment to help us improve providing support
Feb 21, 2011 | HP Officejet 5610v All-In-One InkJet...
After a ps print job is sent and printed by the
There is probably nothing wrong with the printer, but it may not be be receiving all the dope it needs. Usually the printer needs a CR/LF signal at the end of the file to print. If it doesn't get that it will assume that it hasn't got all the file and will hang. This may be a setting in the application producing the file, or a setting on the printer itself (i.e needing either a full CR/LF signal or just one of these). Don't like the idea that it doesn't print its own test page though....
Dec 01, 2009 | Ricoh Aficio CL7000 Laser Printer
I have an hp Laserjet 1012 printer and find that I do not possess any instructions for trouble shooting. My problem is that the printer persists in reprinting the same job given it several days ago and I...
Here is a link to the LJ1012. There are links for manuals, drivers, support forums, etc.
LaserJet 1012 Support
As to your question, here are the brief descriptions of the 2 lights and 2 buttons...from top to bottom:
1 Attention light: Indicates printer media input tray is empty, print cartridge door is open, print
cartridge is missing, or other errors.
2 Ready light: Indicates that the printer is ready to print.
3 Go button and light: To print a demo page or to continue printing while in manual feed mode,
press and release the Go button. To print a configuration page, press and hold the Go button
for 5 seconds.
4 Cancel Job button: When the printer is processing data, press the Cancel Job button to
cancel the print job.
Also, see if powering down the printer and unplugging it from the wall outlet for several minutes clears the repeating of the print job.
Nov 02, 2008 | HP Office Equipment & Supplies
Printronix P5412 Do not Print
Sounds like this unit has some electrical (minor) damage.
Sep 07, 2007 | Printronix PrintNet Print Server
41 people viewed this question
jasbo
jasbo
