Question about Kodak EasyShare V610 Digital Camera
Kodak V610 won't turn on
Hello camera helpers!.... I am so sad... In my Hotel at Disney and My camera won't turn on... I have and extra battery and it doesn't work with either of the batteries.... no little glimpse of a light.....nothing. I HAVE EXACTLY THE SAME PROBLEM WITH MY KODAK V610. IT HAPPENED SUDDENLY. I HAD JUST USED IT THE DAY BEFORE WITHOUT ANY PROBLEMS.
LAROCK2@COMCAST.NET
mads_aye
  • 58 Answers
SOURCE: Kodak Camera V610 easy share
Hi!
This is what I need you to try..
If you're using a 5v ac adapter to charge the camera's battery - please hook it to the camera WITHOUT THE BATTERY in it. The 5v ac adapter can be an alternative power supply.
Turn on the camera - check if it would do the same thing - like lighting up, making a noise (attempting to extend the lens) and closes. If it does, the camera needs to be sent in for repair.
visit www.kodak.com/go/itg to arrange repair
If you are using a photoframe dock2 or camera dock series 3 to recharge the camera's batt - use its 5v ac adapter. It will work with the cam. Make sure, the batt is not in it to check the cam's condition, isolating the possible interference of the battery.
If the camera works fine - when the AC adapter is attached, no battery in it - consider buying a new battery.
V610 is a very nice camera, but it was manufactured in 2006. If you have not replaced the battery yet, it might just need to be replaced. Even Li-ion rechargeable batteries wear out eventually - it can only last up to 300 charging cycles.
If you're using a batt that is less than a year old, the cam might just need to be sent in for service.
Posted on Nov 29, 2008
  • 415 Answers
SOURCE: ERROR E45 KODAK V610
please see this
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=8962/7269&pq-locale=en_GB&expression=e45
Posted on Jan 22, 2010
fathitkf
  • 1871 Answers
SOURCE: camera error #e45 kodak digital camera v610
Hello :
This means the lens alignment of your camera is messed up and it will take repair service to fix it. The cost of this might be equivalent to replacing the camera- Better to call KODAK and see what they're willing to do for you.
Not supported solution is to smack the side of the camera . That helped some people with the same error .
Please read this useful link carefully : Kodak cam errors forum
I hope this will help .
please don't forget to rate !
Posted on Apr 06, 2010
lock123
  • 6831 Answers
SOURCE: kodak v610 camera shows error #E45
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Nov 09, 2010
lock123
  • 6831 Answers
SOURCE: I have #E45 error massage displayed on my Kodak Easy Share V610
Hello
Regards
Andrea
Posted on Dec 15, 2010
KODAK V610 MEMORY CARD STUCK
Try going into your setting and check the "QUALITY" settings. It may have defaulted to the maximum 6.1mp for images, and Quicktime for video. Also, you should have the option of formatting the SD card in the camera. Try these and see if it gives you a few more photos. With a card that size, you may have to take a step down in image quality to gain a higher number of stored photos.
Oct 23, 2017 | Kodak EasyShare V610 Digital Camera
Kodak V610 Easyshare won't turn on
You have a board power supply issue which would be covered under warranty. (Hopefully you still under warranty)
Aug 19, 2007 | Kodak EasyShare V610 Digital Camera
Okay.. I Turned The Camera Off To Let It Charge Over Night. When I Came To Turn It Back On, It Wont Power On. When I Put The Charger Back In, It Lights Up As Though It Is Still Charging But It WILL NOT...
Haha,maybe there's a accident happened at the night ,so the battery for Kodak EasyShare V610 is still charging as begin.You need let it charging until it is full with power then we can confirm what's the problem definitely.
Feb 10, 2011 | Kodak EasyShare V610 Digital Camera
Camera error #e45 kodak digital camera v610
Hello :
Apr 06, 2010 | Kodak EasyShare V610 Digital Camera
My shutter is broken on my Kodak V610
I'm afraid your camera needs a repair. There's no other way. Contact Kodak under 1-800-421-6699.
Mar 10, 2010 | Kodak EasyShare V610 Digital Camera
V610 camera wont turn on
I figured out that the rechargeable battery inside my camera is dead so I have to buy a new one because it is like 3 years old.
Mar 06, 2009 | Kodak EasyShare V610 Digital Camera
V610 KODAK ERROR E45
This problem is frequently due to weak/worn out batteries or corroded battery terminals inside the camera. If charging/replacing the batteries does not clear the problem, remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Dec 04, 2008 | Kodak EasyShare V610 Digital Camera
Hi!
Nov 24, 2008 | Kodak EasyShare V610 Digital Camera
Kodak EasyShare V610 Digital Camera Logo
172 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
