Question about Hansgrohe 06649860 Solaris Single Hole Kitchen Faucet with Base Plate - Ste...
Spray head leaks out of the top of Metro 06917000
How does one disassemble the unit to replace o rings, etc.
The manual has been misplaced. Is one available in PDF format?
  • 33 Answers
Here is a link to the PDF for that particular model:
Spare parts catalogue
Here is a link to the faucet page if this isn't what your looking for:
Metro 06917000
Hope this helps!
Posted on Dec 05, 2008
Leaking faucet
I've had problems with the O-rings at the head leaking, feeding back inside the corrugated hose covering, and pooling under the sink. Might be your problem as well. Verify by holding the head downward, and look for water beading out further up the hose.
Apr 04, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
BLANCO MODERA KITCHEN SINKS SPRAY HEAD, 157-081-CR, obstructed. The water flow from the hose is excellent. I have removed the screen and even the black part of the spray head, but the blockage is before...
Here is a webpage with a diagram of your faucet assembly: >>>>> http://www.build.com/mediabase/specifications/157081.pdf<<<<<
Copy and paste this in your browser and the page will open right up for you.
Note there are 2 check valves, one, #3d, where your incoming water line attaches and another, #9, up behind the head.
Don't be afraid to disassemble your faucet. Just remember to turn the water off and lay your parts out as you took them off and you should be able to reassemble with no problem.
As a note, a little veg. oil on O-rings will help reseal after you have disassembled.
Hope this helps. If it does, I'd appreciate a 4 thumbs up. Thanks,
Handie Andie
May 15, 2011 | Blanco 157-081-CR Modera Kitchen Faucet...
I have a pull out spray kitchen faucet and the spray faucet leaks around the pin that changes the water from a spray to stream. Can I get a replacement for the spray/stream head?
take old sprayer with you and you should be able to get one at a hardware or even at homedepot.most sprayers come apart. maybe the rubber ring is bad on inside of sprayer.
Apr 21, 2011 | Plumbing
Franke Kitchen Spray Head Part # 4089. Lever on top moves it from stream to spray While on Stream Spray is leaking.... Tried changing washers 1st...then tried new aerotors... still leaking
I have the same problem. By taking off both aerators, I can see that the rubber ring inside the spray head partially disintegrated. Little pieces of rubber even fell out. I can remove the spray head (it twists off; I used a pliers and rubber gloves) but I can't take it apart and even if I did, I don't know if I could replace the rubber ring.
Nov 18, 2010 | Franke Plumbing
Water leaking from top section of kitchen faucet
You might try replacing the o-rings but I would replace the cartridge and the o-rings. Be sure and use silicone lubricant on the o-rings.
Feb 23, 2010 | Plumbing
How do you take the water assembly apart it leaks out the top of the assembly.
Pop off the cap on top of the faucet, unscrew the philips head screw,pull faucet up and off the brass center and replace the two o-rings you see .
Feb 15, 2010 | Price Pfister Marielle Kitchen Faucet with...
The faucet continues to run when using the side spray.
under the neck of the faucet is a small cone in the side of the body.this is your spray diverter,it may be clogged,it may be spring loaded or a presure valve you must remove and clean. then it will work right.
Jul 25, 2009 | Price Pfister Marielle Kitchen Faucet with...
Leaky Blanco Single Lever Kitchen Faucet with separate sprayer
you can call or e-mail the company, if the faucet is the one in the picture it is a single cartdridge, turn of bith hot and cold water, take an allen wrench into the little plastic cover to remove the handle , unscrew the top cover or it might pop off, that there is either a large lock not or 3 screws holding down the cartdridge, take it out replace it put some faucet frease around all rubber gaskets then install it in the smae way it came out
May 30, 2009 | Blanco Classic Single Handle Faucet with...
Moen single lever kitchen faucet leaking at base and through spray. Can it be fixed? I lost my installation manual. Are there any online?
base leak is from bad o ring or loose spout very easy fix you can get a washer kit at lowes all you need is a allen wrench(sometimes comes in kit) a pair of channel lock pliers
May 09, 2009 | Moen 7840 Camerist Single-Handle Kitchen...
Srayer leaking down the hose from pivot joint near spray head
there is an oring in that connection that is most likey bad. turn water off and disconnect coupling to spayer. remove the black oring and match it up at your local hardware store. when installin it lubricate it with vaseline for ease of insatlltion and to help protect it during installation.
Apr 21, 2009 | Kohler Model 10433: Fort® Single-control...
Open Questions:
Hansgrohe 06649860 Solaris Single Hole Kitchen Faucet with Base Plate - Ste... Logo
603 people viewed this question
Top Hansgrohe Plumbing Experts
Jim Goldsmith
Jim Goldsmith
ray gallant
Daryl Gleaton
Are you a Hansgrohe Plumbing Expert? Answer questions, earn points and help others
