Question about RCA 27F650T 27" TV
Tv turns its self on or off at times
My tv will sometime turn its self off, it can also turn its self on at any time.
  • Anonymous Feb 10, 2008
    my tv turns its self off every 5mins or so and the timer is not set
    can any1 help me
  • Mistj1 Mar 14, 2008
    Started turning itself off then back on then off and now it's off and has been for about 6 minutes and all of a sudden it will turn itself back on. RCA was suppose to be a good tv. My old one, thank goodness which I still have after 20 + yrs works fine just old. I guess with so many having the same problem, maybe RCA isn't so good anymore and we should be looking at the newer HDTV's and not the RCA's. I bought this one from a neighbor who's son had passed away and this problem just started 2 nights ago.
I tried to unplug mine for awhile then plug it back in that worked for awhile now it won't come at all. Hope this helps abit, although i'm sure your like me and have tried it all,8)
Posted on Feb 07, 2007
My olevia 237-t11 turns off by its self and sometimes makes a loud screcheen noise
Sounds like either the main or display power supply is failing. Might consider a new TV. Parts could be found but it might be hard to find them.
Aug 28, 2014 | Olevia 237T 37 in. LCD TV
Samsung SP50L6HD Tv turns it's self off. Time
sir it may happen if the auto off option is enabled and the timer is enabled........... check for this options if they r and enabled then disable that........... or give your tv to the service shop and check for any problems
Jul 20, 2009 | Samsung Televison & Video
Tv just goes blank shoots off then i have to turn it back o n
Using the menu/options button, check whether there is a sleep timer. You may have accidentally set it, and it will shut off the tv at either a particular time, or after a period of time has elapsed.
Jun 30, 2009 | RCA Universal Remote Control
Tv turns self off after about 20 - 30 seconds
check main pcb for bad solder also replace r422 1ohm fusable resistor part number 996500015672
Jan 09, 2009 | Philips Magnavox 27MS343S 27" TV
Menu flahes on and off
contact switches on front panel board are dirty or bad try cleaning switches with contact cleaner first thy are the ones that turn tv off/on vol- vol+ ch- ch+
Dec 20, 2008 | RCA D61W20 61" Rear Projection Television
After my 70" tv is on for a period of time, it turns off and won't come back on for a while.
Good Day, Connie ss;
The next time the TV turns off try this:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB. I hope this was helpful, good luck, big IRISH.
Jul 02, 2008 | Mitsubishi VS-70707 70" Rear Projection...
Random Turn-Off on KV-34HS420
Hello there,
7 times blinks shows that Horizontal Deflection Circuit doesn't work properly.
I think, its not big fault and can be resolve in low cost at nearest Sony repair shop.
Feb 18, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Hitachi 50" MTS TV/Monitor
It's possible you may have bad solder connections on the chassis boards.
C-Dog
Feb 13, 2008 | Televison & Video
TV KEEPS TURNING OFF ITSELF
how long does it stay powered on and do any of the lights flash if so how many times?
Dec 16, 2007 | Samsung HCN4226W 42" Rear Projection...
RCA 27F650T 27" TV Logo
121 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
