Question about ASUS A8N-SLI Motherboard
Hard Disks Not Detected
I recently installed a new graphics card (an 8800) its much larger than my previous 6600GT i had and there was insufficient room to properly manover it inside my case so i unplugged my cables for the harddrives and installed the graphics card which works fine, or atleast i assume it is, then following this i plugged in all the other cables exactly as they were as far as i know. I booted up the PC and for some reason its just flat out not detecting my harddrives anymore, its like they don't exist at all. The only thing i can guess is that the cables were damaged somehow, but the cables im using to plug into the harddrives all connect directly to the power supply (those are the only ones i disconnected to make space) so replacing them is difficult/impossible without replacing my PSU. The harddrives hum lightly and rumble very slightly to the touch when the PC is on, indicating they are not broken and do work fine and the PC comes up with no other errors except saying "Boot Failed, Please insert system disk" trying to install windows because the harddrives are not found. Thanks for any help.
  • 624 Answers
Hi Alec, Chances are if hard drives are getting sufficient power (spinning hard drives are only a rough indicator) then there?s something wrong with the data lines that run from the hard drives to the controller. Check each connector on the hard drive to make sure it is plugged in securely, trace it to where it plugs into the motherboard and check them as well. They could have pulled out while you were moving things around. If that doesn?t work then I would try replacing the original video card. Let us know if this solved your issue and please don?t forget to rate the posting when we?re done.
Posted on Jan 17, 2007
Hi i recently upgraded to DDR3 8gb, and i have memory leaks when playing star wars galaxies, my video card is an 8800 GT
Hi there,Does this only happen with Star warss Galaxies,Or other games too?
If so You should try this:http://www.memtest.org/
Let me knwo how it goes for you..
Regards, Finphillips
Feb 03, 2011 | XFX NVIDIA GeForce 8800 GT 512MB DDR3 PCI...
Hi i have a problem with my nx 8800 gts ,error code 43 , with windows 7 ,i doesnt working about 2 months ,but 2 days ago it was working for 2 hours ,but today it's not working? help pls:(
reinstall your Windows 7.
then download and install a new driver for your Graphic card.
you can download it from here:
http://www.filehippo.com/download_nvidia_forceware_xp/
Jan 15, 2011 | MSI NX8800GTS-T2D512E Geforce 8800 GTS...
Hay.got a gw 6600gt 256mb.pci card.when i start up,theres a lot of strange things happens.its got dots of colour flashes,it freeze..cant get it too work
This is Most likely caused by a Manufacturers defect in the card, i would exchange for a new one and see if the problem still exists.
Jan 10, 2011 | Gainward GeForce 6600GT, (128 MB) Graphic...
Major Display Problems
your card is defect, just replace and ok
Feb 12, 2010 | LG Studioworks 900B 19" CRT Monitor
I've just installed XFX GeForce 6800 graphics card
Not enough graphics card for WoW. Here are the System Requirements,
http://www.worldofwarcraft.com/info/faq/technology.html
Nov 18, 2009 | XFX GeForce 6600GT, (128 MB) Graphic Card
Test drive unlimited is not for pc
The minimum hardware requirement for Test Drive Unlimited are: > Pentium 4 2.4Ghz or higher processor
> 1 GB of RAM
> a 256MB Graphics card (GeForce 6600GT or better)
> 8 GB of hard disk space
and it runs only on the windows platform. Does your PC meet these requirements? If it does, then, I suggest that you re-install your graphics card's drivers.
Dec 24, 2008 | Computers & Internet
Trying to load call of duty 5 world at war . with g force 8800
It will say on the box it was packaged in what the minimum requirements are for the game....
Here is from a site i found....
Processor: AMD 64 3200+/Intel Pentium 4 3.0GHz or better
Memory: 8 GB free hard-drive space, 512MB RAM (XP)/1GB RAM (Vista)
Graphics: Shader 3.0 or better, 256MB Nvidia GeForce 6600GT/ATI Radeon 1600XT or better
http://www.nvidia.com/page/geforce_8800.html
link for your line of graphics cards.
You have not given the entire model # so it is unclear if your card is sufficient, however it does say GeForce 6600GT or better - which yours is
Dec 22, 2008 | Nvidia GeForce 8800 GT 512MB Graphic Card
Help me
vista doesn't support ati 9200 anymore. you need to upgrade your card or go back to windows xp where the card ati radeon 9200 is supported. if that is your card.
but if you got presario b1900
goto the hp page here
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodClassId=-1&prodTypeId=321957&prodSeriesId=2512115
or here
http://h20000.www2.hp.com/bizsupport/TechSupport/Product.jsp?locale=en_US&taskId=135&prodTypeId=321957&prodCatId=82710&prodSubCatId=212728
select your model from the list and you will get eventually to the driver pages.
Oct 20, 2008 | ATI RADEON 9200 Graphic Card
No output to monitor,graphics cards work,new psu, new ram, all lights come on and fans turn. the mobo is a winfast nf4sk8aa graphics - nvidia 6600gt x2 cpu - amd 4000+ ram - corsair 1gb 3200 value select...
unplug power
re-seat video card
plug power - turn on all
windows comes up - else try another video card.
control panel under video uninstall then reinstall video driver
repair video programs or install video program
Mar 13, 2008 | Computers & Internet
Graphics cards
that might be pci express new style wont work with what u have ok
Feb 03, 2008 | Gigabyte GV-NX66T128D GeForce 6600GT 128MB...
ASUS A8N-SLI Motherboard Logo
67 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
