Question about Siemens Gigaset 2420 Cordless Phone
Reset base My base seems to work fine until someone calls in and when the ring happens it flashes all the buttons and it powers off and reboots. I was told its in a "protected mode" and might go back to normal if I reset it. I do not know how to try this. sorry I dont have a manual and I could not find a pinhole like routers have and it does nothing to unplug it for a while.
  • Davey Gogwell Feb 10, 2007
    I found the answer.
    To reset the PIN to 0000.
    1. Press Menu.
    2. Scroll to system Settins but DO NOT press SELECT.
    3. on the keypad, enter *65#.
    4. The display will show "System PIN Reset" and will return to the idle screen.
    Then you can use menu options to get to the factory Default reset and the "protected mode " goes away. At least it did for me.
    DC
Delete all the entries in the call log. This will fix the problem, though it may recur. The phone sometimes has a problem when the log is full, and then receives caller id info in a specific format.
Posted on Sep 15, 2007
My phone rings but I can't hear anyone and they can't hear me. What happened?
Samsung Galaxy S4: Rings but caller/receiver can't hear:
Question: Was this phone paired with a Bluetooth device like a headset or to a car? It may be stuck to that..
In any case, try holding down the power button, select reset or power off, let the phone reboot. Then try calling someone or have someone call you to test. It should work..
If not, by default Google's "OK Google" voice search maybe the culprit. Try turning it off and see if that works..
"From the home screen, hold down the menu button which should go into Google Now. Click on menu button again and select settings. Select "VOICE." Then select "Ok Google" detection. Once there, switch off the option "From any Screen." Once that is turned off. Restart phone"
Reference Link:
http://forums.androidcentral.com/samsung-galaxy-s4/461272-my-galaxy-s4-why-can-t-i-hear-anyone-no-one-can-hear-me-calls.html
If this does not work for you, try calling your Cellular Service Provider and ask them to reset the connection on their side to your phone.,. While they do that, they may ask you to power off your phone, take out the battery, take out the SIM card, wait for at least 30 seconds before re-inserting your SIM card and battery, and then powering the phone back on
Jan 14, 2016 | Samsung GALAXY S4
My nokia lumia 521 screen went completely black after my phone asked to update. How can I fix this
I had this happen on my Lumia 920 a lot. I pressed and held the power button till it finally rebooted. I seemed like it took a minute before it finally rebooted, so don't give up after 10-30 seconds. If that doesn't work try the power button and volume down button till it reboots. Some sites say this is a hard reset that wipes the phone, but as a last resort, I tried it when the power button alone wouldn't "wake it up". When it rebooted everything was normal, so either it isn't a "hard reset" or it doesn't do the "hard reset" when the phone is locked up and the screen is black. I never tried the power and volume down reset when the phone was operational, so I don't know.
Aug 25, 2013 | Nokia Lumia 520 Unlocked Black
My panasonic KX-TG5000 phone headsets cannot make or recieve outgoing calls and the intercom function is gargly.
You need to reset the menu once again as it is possible that the phone had hung up as there was LINE PROBLEMS . Once this was reset the CLIP facility came back. So if you can once again remove power battery and keep aside to reset , then start all over to set up the base and slave units to MESH , the intercom and line facility must work.
You can remove the battery from the slave remote units to reset.
Oct 20, 2011 | Panasonic KX-TG4500 Phone
Iphone does not ring when in sleep mode
This seemed to work for me;
1.) Reset the phones network settings
2.) Reboot the phone
3.) Put the phone in airplane mode
4.) Reboot the phone
5.) Take the phone out of airplane mode
6.) reboot the phone.
I read this on another website, and it seemed to work for me.
To reboot the iphone hold down the sleep/wake button, and the home button at the same time for 6 seconds (until the apple logo appears).
Good Luck!!
Jul 27, 2009 | BoxWave Corporation Apple iPhone 2G...
Phone doesn't ring for an incoming call
pls reset ur device for some reason the call handling software has been corrupted dont worry just backup ur data and reset the device as follows
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if not solved then go to www.htc.com for latest Rom update download and update backup ur data first
pls rate me fixya if i solved ur problem
Feb 28, 2009 | HTC P4350 Smartphone
GE phone has stopped ringing
I had the exact same problem and tried everything. It wasn't until I unplugged and main base from the electrical outlet for a few minutes and plugged it back in -- for some reason that made everything work. It is worth a try. We had some minor electrical outages in the last week due to weather so I assume that screwed something up.
Feb 02, 2009 | Uniden Cordless Phone
Problem with answering machine on Panasonic Model # KX-FPG376
i followed the advice posted & it worked fine after that. thanks.
Nov 22, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Jan 20, 2008 | Uniden Cordless Phone
When someone calls the buttons flash but doesn't ring.
Your ringer has been switched off..to solve this press the menu button(mute in most of the sets)and press it until you see the option ringer press + to change it to off and then press menu again until you see the main screen...Thats all..
Let me know if it worked..
Oct 20, 2007 | GE 28111 Cordless Phone
Siemens Gigaset 2420 Cordless Phone Logo
364 people viewed this question
Top Siemens Lands Phones Experts
Marvin
Marvin
Jaime Hernandez
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
