Question about Fisher DD603B / DD603W / DD603H Dishwasher
F&p DS601v2 F4 code
F&p dishwasher DS601v2 F4 code comes on . It trips the maim breaker. I did another wash & it stopped f4 came up & the breaker did not trip. There was alot of water in the tub & it was cold I've checked the heating element its got 55 ohms though it. Dose not appear to be burnt.
5 Suggested Answers
  • 18 Answers
SOURCE: zoek storings code f4 van gsfp3988
F4 is a drain pump problem, possibly bad connection on pcb
Posted on Jul 12, 2007
TheMazz
  • 78 Answers
SOURCE: help with and f4 fault code on a fisher and paykel
Without the model number I have to guess.
Fault code 'f4' means "faulty temperature sensor or element".
Here is a link to User manuals:
http://fisherpaykelparts.net/index.php?blockitemid=29
If this information was useful, please select YES to the first two rating questions. Good Luck and thank you!
Posted on Oct 24, 2009
  • 69 Answers
SOURCE: F4 error fisher & paykel nautilus dishwasher
F4 is a heating error- dishwasher has not reached temperature in allocated time. If intermittent fault, problem is usually with electronic board, which has temperature sensor attached. Sometimes the wiring to the control board burns out and can give intermittent false readings causing F4 error. Disconnect from power, remove front panel (4 screws down each side). You can now see wiring going to control board- check for burnt wires. Also check temperature sensor (small square with two purple wires) is stuck to inner door panel- if this is not stuck to inner panel, temperature sensor will not work properly. If in any doubt, call in the experts!!
Posted on Mar 09, 2010
blueextc3221
  • 15935 Answers
SOURCE: Error code F4
The F4 error code on your washer indicates a problem in the electrical circuits of the washer... and not end-user repairable.
This problem requires a technician to test the wiring circuits to diagnose the problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
Does anyone know what the F4 fault is on my kitchen aid dishwasher? I can reset it and then start over or select another program, although after approx 1 minute the F4 error code comes up and I cannot see...
Check the drain hose. When you turn on a dishwasher, the first thing that it does is check the pump. If there is a drain issue then it stops.
Mar 02, 2014 | Dishwashers
Code F4 dishwasher whirlpool ADP 7590
i think f4 is a drain error check the pump has no blockage ie broken glass/pottery etc. hope this helps
Feb 03, 2012 | Whirlpool Washing Machines
Whirlpool Aqua Steam dishwasher, coming up for 3 years old, starts cycle but gets stuck with fault code F4. Have cleaned it out and persisted and it did drain but once again went to F4
You have actually posted your Dishwasher problem onto the (garment) Washing machine forum!
However I have checked my Whirlpool list for dishwashers and for some models 'F4' stands for 'drainage' (as you have checked) but for others it mentions (quote) 'no heat, relay, NTC (thermostat), connections, underfilling are all possible'(unquote).
When there is an NTC problem with washing machines we often suggest pouring the contents of a couple of boiling kettles into the washer as it sometimes kicks the NTC into life! Might be worth doing that with your dishwasher before calling for service ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 19, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Hi! I have Whirlpool ADP6948 dishwasher. It's
Hi.
F4 points at at a drain problem, often the problem is caused by a dirty or defective pressure switch. Before replacing the pressure switch it is necessary to test the drain system.
First try turning power off from circuit breaker for few minutes and see if that is enough to clear the error code.
Turn power off from circuit breaker (or disconnect power cord) and clean the drain well inside the tub. Remove any water present in the tum. Check also the drain hose at the back of the appliance and make sure it is not kinked or blocked.
If that does not work remove the kick panel at the base of the dishwasher, locate the pressure switch and clean the hose connected to the pressure switch. The pressure switch is the device that detects water level, determining when to start and stop the drain pump. The pressure switch is a small plastic switch connected to a long rubber hose. If the hose gets blocked with detergent or if the switch is defective you get f4.
Resuming:
Try resetting the appliance to clear the error code.
If that does not work clean and check the drain system.
If still no luck check the pressure switch.
Disconnect power before doing any maintenance.
Regards.
Ginko
Aug 31, 2011 | Whirlpool Dishwashers
2LYMPAIA - F4
Hello
If you have F4 and the sump is full of water, there's a good chance the drain pump is being jammed by a broken bit of glass or pottery. However, if the appliance is empty of water and F4 error code is flashing, where do you go from there?
The electronic control (module pcb) does a self check of the components, during a drain cycle the programme allows a time parameter for the appliance to empty away the water. How does the pcb know the water has gone? Simply by testing a pressure switch for continuity.
The pressure switch is an on or off switch, when the appliance is empty the internal contacts are "made" (on) when the appliance is full of water the switch is "broken" (off).
The sensing grid of the pressure switch is exposed to the dishwasher wash water and can over a period of time get clogged with crud ( a mixture of food waste and detergent and limescale), eventually this crud stops the switch from being in the correct attitude during the self tests. The electronics notes the on or off and determines that the appiiance has not drained and gives error code F4.
If you have F4 error code it could be the pressure switch needs cleaning or replacing.
On the self test about 4 mins is allowed for the appliance to empty the water away.
Aug 03, 2011 | Whirlpool Dishwashers
I have an error code f4 on my whirlpool adp 8966 dishwasher can you tell me what it means please
F4 indicates draining failure.Your washer drain pump starts and after 4 minutes the OWI(optical water indicator) detects that mashine is 'not empty'
Posible mailfunction reasons:
The drain pump must be defective/blocked
The siphon would have got closed
The control board would have got damaged
OWI defective
Apr 04, 2010 | Whirlpool 24 in. ADP6940 Dishwasher
Whirlpool Dishwasher machine (Mod. ADG 8970/1) wont start. Water is taken in. After several attempts to start an error code "F4" appeared.
Hello Sir,
This error code, " F4 " comes only when the waste outlet is totally clogged with waste and blocked. Try to dismantle the machine and locate the Waste outlet pipe and thoroughly clean it. This will reset the error which is caused.
Thank you Sir,
Have a nice day.
Jan 13, 2010 | Whirlpool WFW8300SW
Kenmore Elite Catalyst washing machine getting error F4
See if this helps.
http://www.askmehelpdesk.com/appliances/washer-kenmore-elite-catalyst-110-20092993-f3-f4-error-codes-191730.html
Aug 01, 2009 | Kenmore Washing Machines
CODE F4 and washer not working
Not too sure on that code, could be timer error. One thing to try would be to turn off the AC power to the unit and let it stay off for 15-30 minutes and then turn it back on. Sometimes if the unit takes a voltage spike it hashes the memory and resetting the power will clear it up, but to do this the voltage needs to turned off at the fuse/breaker box and not just the switch on the front. If you have the manual it may give ideas. I could not find the model no. you listed. Check to see if it is correct if resetting the unit doesn't help.
Feb 01, 2008 | Whirlpool 24 in. ADG6962iX Built-in...
Open Questions:
Fisher DD603B / DD603W / DD603H Dishwasher Logo
182 people viewed this question
Top Fisher Dishwashers Experts
Tony Houde
Tony Houde
George Merkley
George Merkley
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
