Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Embroidery centering I just recently got the Singer CE-200. I am having problems in getting it to center the images on the hoop. It wants to sew more to the right. Some images are destored because of this. I tried the center feature in options but it did not change. Wondering what I am doing wrong?
From my experience with this machine it is not a problem with the machine itself, but a software issue. Maybe your computer is not compatible. My first suggestion is to try to uninstall AND completely remove ALL programs related to Futura. Then restart your computer. Now re-install ONLY the main program. See if this works. Do not get frustrated, this machine usually takes awhile to figure out. Training is important for 100% success. Good luck!
Posted on Jan 28, 2007
When I thread the bobbin, code 88 flashes, what is that?
Try zero your embroidery hoop carriage by off/on your machine before your next application, if no result disconect your embroidery unit and connect back again ensuring it is properly connected. Hope the problem can be solved.
Jan 17, 2014 | Singer CE-200 Quantum Futura Computerized...
My needle goes too far right when starting up. It actually hits off the hoop and breaks. I have made the design smaller and centered but it still lines up too far to the right. I have changed the hoop...
This is common problem' is your machine under warrenty ? if so take it back to the place you got it. if not you will have to take i to a repair shop this is a computer board issue
Aug 08, 2011 | Singer CE-200 Quantum Futura Computerized...
Hoop doesn't center
The needle does not center when you have selected a design to stitch-out?
There is a FAQ for Futuras at the Singer Company website that may be of more help.
Apr 03, 2010 | Singer CE-200 Quantum Futura Computerized...
Futura ce-200 "parked" in wrong position.
I think you might have damaged the embroidary arm.
Contact these people for some advice.
Gezina sewing machine
(012) 335 0636
Feb 27, 2009 | Singer CE-200 Quantum Futura Computerized...
Futura CE-200 Stops in middle of design and says wrong hoop size
Dear cjnations
Firstly we must all remember that the CE200 is a very particular machine and requires that you follow certain procedures in order for it to run smoothly. When using the small hoop, firstly you must make sure that the small hoop is selected on the screen by going to Tools, Select Hoop & clicking on small frame. Once this has been done and the design selected, you must then attach the small hoop before sending the design to the machine. If you attach the hoop after sending the design, the machine will give you the error message.
Good Luck!
Nov 16, 2008 | Singer CE-200 Quantum Futura Computerized...
Errors
Wow, I finally get to have a solution.
1. Turn the machine off.
2. Remove the hoop.
3. CAREFULLY slide the bar on the embroidery unit to the left.
4. CAREFULLY slide the piece where the hoop attaches toward you.
5. Turn on the sewing machine. The machine should take the unit to "standby" with a click.
6. Attach the hoop with the power on.
7. Exit the Futura software.
8. Restart the software.
This "should" fix the problem, however, you may have to repeat this process more than once to get it to "stick".
Jul 28, 2008 | Singer CE-200 Quantum Futura Computerized...
I recently bought a Singer Futura CE-200. I was using the embroidery function, but had to stop due to threading problems. When I went back to the computer a few days later my computer was shut down. I...
2. Remove the hoop.
Jul 25, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer futura ce-200 problem, pattern mis-alignment
I have had similar problems in the past.
Do you hear a noise from the embroidery unit when the misalignment occurs ? If so, I suspect that your issue may be that you have some resistance under the hoop. Is there extra material that may be rubbing on the machine or catching somewhere. I have found that if I use some masking tape to keep all of the extra material from hitting any other parts of the machine or dragging under the edge of the hoop this error does not occur. FYI: I also stopped using the "optimize stitch speed" option at the same time. I believe that material dragging was causing the problem, but I still wonder about the stitch speed optimization feature.
Jun 03, 2008 | Singer CE-200 Quantum Futura Computerized...
Centering the starting point
Unfortunately you can't. It is imposible to move the neddle because of the machine limitation. It will only move to the starting point according to your design.
Jun 07, 2007 | Singer CE-200 Quantum Futura Computerized...
Carriage not returning
Dear Netter - I too have a CE-200 Quantum Futura Sewing/Embroidery Machine. I have run into similar problems. I have tried the various things suggested: remove hoop, turn off machine, turn on machine, replace hoop. However, often the carriage does not return to the initial location (carriage all the way to the left, mounting plate all the way to the bottom, closest to the user). I have found that with the gradual application of force, I can pull the mounting plate all the way to the bottom of the carriage. I turn off the machine before I do this. I have not tried to move the carriage to the right or left; I have not had to. Sometimes when I turn the machine on, it beeps steadily (more than the usual 3 or so complaints). But when I turn it off and on again, eventually it is ready to continue embroidery. By doing this, I may be causing damage to the machine or making the warranty void. If you do it, you may face the same problems. Or it may make your machine into an expensive paperweight. I can't offer you a complete solution for your problem, but I hope this helps.
Nov 09, 2006 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
64 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
