When our house was built ten years ago manufacturer installed honeywell heating units but we have noticed that our house hasn't been heating correctly. We could hear the unit turn on but only room temperature air blows. We went up to the attic and tried reading manual and realized their is a red light that flashes long flash then pause then 3 flashes. i dont know if this means anything but trying to explain to you everything i am doing with my 5 senses so u have an ideal in your mind. anyways tried swithing to heat auto @ higher/lower temp, placed on w/heat, no good. what do you think that it could be? friend said replace whole thing but i dont have $ i live on ssi frm major accident i was in. please advise what i could try to do. thank u i think that is the correct program. the thermostat thermperature gauge unit has the words heat and cool the the other switch can be switched on off and something else . tooo cold to go down the stairs right now so sorry hopefully yoy can help with this info
em means emergency heat,which means you have a heat pump.check out door unit,it might be all froze up,or covered in snow,sweep snow off gently. if it's froze up its not defrosting and you need a service call.if your back up heat is not working there might be little window on furnace,look for flashing light inside.if light is steady on its working.
hook up the blue wire in the furnace cabinet where the blower section and the other thermostat wires are connected to the furnace. the thermostat you have uses a common wire from the thermostat to the furnace and this needs to be hooked up in the furnace otherwise you will have the problem you are having.
take the face off of your thermostat or open the front cover. there will be selector swithces the say HE, HG, and possibly one for heat pump. Heat electric and heat Gas. Make sure it is set to the type of furnace that you have. The wire should be red to the rh or rc terminal.(Should have a jumper wire), yellow wire to the y terminal, White to the w terminal which is for heat, and green to the g terminal. there is another adjustment to be made on the heat anticipator, but you would need an amp meter to set properly
a/c is either on or off,there no in between.check air filters make sure they are clean.also keep in mind a/c will only bring temp down about 15 degrees from outdoor temp
Humidifiers are made from a very durable heat resistant plastic. If it melted or warped you have a serious overheating problem. That plenum should not get over 140 to 155 degrees. If this furnace is running to hot it could stress and crack your heat exchanger. Install a good carbon monoxide detector in your home!!!! Check your filters. Check your airflow. Make sure all registers in the house are open. Is your blower speed set high enough? If this furnace is operating to hot it is definitely worth the investment to have a pro look at it before you replace the humidifier.
Is this overheating problem new? Or was this something thar happened years ago and may have since been solved But you are just now noticing the heat damege that was caused.
Goog luck
HVAC Teacher
Whan your room is up to temp or room is set at 70 and your stat is at 70 do you hear the stat click off .if not its a bad stat. you will have a little flam on your stat that should go off also
