Question about JVC AV-27530 27" TV
Picture getting dark
My picture is getting dark.When I clean the bulbs you can see alot of dust down in the blue bulb. How can I clean under the bulbs?
picture is really dark
  • mflores10019 Dec 28, 2008
    I have a jvc av 27530 model, the picture is dark, tried adjusting it with the menu on the remote and tv, but it does not work, if the scene is dark I can not see whats going on. does the tube need to be replaced? or can i ioen it and clean it out? is so what do I use to clean it? and can I remove it from tv for better cleaning?
My jvc 27" tv was so dark I could hardly see any night scenes, even with the bright all the way on. If you push the sleep button, let go, then hold down the video and display (together), the service menu will come on. Scroll down to #7 (too dark) and adjust the brightness there. Works immediately. Good luck.
Posted on Jan 11, 2009
My tv picture is faded and dark
you might need a new bulb, bulbs average around 4000 hours, depending on the bulb, they range from 750-6000 hours
Apr 20, 2014 | Philips 60PP9352 60" Rear Projection...
I have the KDF-50E2000 Sony I have replaced the bulb and I have a solid green light which isnt blinking though could the replacement bulb be the issue
So you do have a picture? Albeit dark blue? Then its the source and/or video connection that is probably the problem
Mar 18, 2014 | Sony KDF-50E2000 50" HDTV
Have power but color is very dark. I've done research and a lot are saying to replace the bulb, but I'd like to test it if possible before buying a new one and its still dark like before. Any help wil
its the bulb. sometimes over time the bulb gathers dust, the bulb is running at extensive temperatures and debris begin to stain the lens. this is more common with pet owners or smokers. you could check the color wheel but i doubt any color loss is due to that being dirty or stained, reason i state that is because when my crt samsung gets dull its because the lenses on the crts red green and blue are dirty with dust debris.
Nov 20, 2012 | Televison & Video
Dark Picture
Your backlight transformer has failed, this is not a simple fix and requires the replacement or one or more of the boards in the back of your tv.
Mar 07, 2012 | Sony KDF-E50A10 50 in. LCD HDTV
Mitsubishi wd 62527 has very dark picture changed
Clean the small front projection mirror. That mirror can get dust on it and will cause the projected image to appear dull and dim and cleaning that mirror will usually restore the brightness and crisp details in the image.
Oct 20, 2010 | Mitsubishi WD-62725 62" Rear Projection...
I have a 1994 zenith big screen the picture is showing really dar
It could be that the picture tubes have gone down on emission, there is a prcedure that can be tried to bring up the overall brightness but it is just possible that you will loose some picture quality. If it's a 1994 projo tv i am thinking of the three crt system, a gray scale alignment would probably correct the dark condition in your picture, again depending on how far gone is the emission in your picture tubes, if your projo tv is the dlp system, the bad news is that you could be needing some light engine repair. The color adjustment is possible with the availability of a service manual or in the case of the dlp system, light engine repairs or replacement are available from some on line stores.
Jan 12, 2010 | Zenith E44W46LCD 44" Rear Projection...
Dark picture problem
there are 2 mirrors did you clean both there is one down in front near the light source when front screen removed lean in and look down there is another smaller mirrorclean it
Jan 02, 2009 | Mitsubishi WD-62327 62" Rear Projection...
Blue bulb emits light, but no picture.
Phillips have been known for the coolant to get contaminated especially in the blue CRT. it congeals and your picture will become hazy and out of focus.This is something you an do yourself. If youre careful. If you would like instructions on how to do this proceedure. Let me know.
Jan 21, 2008 | Philips 55PW9363 55" Rear Projection...
JVC AV-27530 27" TV Logo
876 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
