I am tryin to find a stereo amplifier code STK488-050
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls try and start here, here, here or here.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 29, 2008
I am installing alpine ixa-w407 into a 2000 suzuki grand vitara. is there anything i should know aside from hooking up the harness and antenna from vehicle into the alpine?
You should check to see if it has an remote out in the back ...cause if you are planing to install an amplifier ..it will need it ...cause amplifiers (specially for woofers ) are connecting to the power directly to the + of the battery ..and the - on the body (ground) ..and it is switched on ..by the remote cable attached on the player ..This way it will power on in the same time and also react on the break on ..and when the key is switched off.
Also for an amplifier it should have rca out separate from teh normal left and right stereo going to the speakers ..
The rest is just standard harness ..
Jan 19, 2011 | Alpine Car Audio & Video
Stereo help
Make sure the red wire on the unit is hooked up to power. The blue antenna wire is hooked up (or to the factory amplifier) and the yellow wire on the radio is hooked up to a key on power supply. If it works and you lose the memory when you shut the key off, switch the red and yellow wire power supplies.
Feb 25, 2010 | 1987 Volvo 240
Need wiring diagram for 92 dodge caravan tryin to install cd player
Here it is
Car Radio Battery Constant 12v+ Wire: Red/Black
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Black/Yellow
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 5 1/4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Dark Green/Red
Right Front Speaker Positive Wire (+): Purple
Right Front Speaker Negative Wire (-): Purple/Yellow
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Tail Gate
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Yellow
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Feb 14, 2010 | Car Audio & Video
Free radio unlock code
hi im tryin to unlock my honda accord 2001 radio code can u help me out?
Nov 26, 2009 | Car Audio & Video
Installing my deh 2300
Heres all the radio wiring colors for your car:
2002 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger: Dark Green
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Jun 02, 2009 | Pioneer DEH-2300 CD Player
Need help with wires
This is from a 2004 Solara, but it's probablly the same.
2004 Toyota Solara Radio Wiring Chart
Car Radio Battery Constant 12v+ Wire: Blue/Yellow
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Dark Green
Car Stereo Dimmer Wire: White/Green
Car Stereo Antenna Trigger Wire: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
May 25, 2009 | 2006 Toyota Solara
Multi amp hook-up
honestly i dont think those to amps will push cvxs no matter how you wire them up.
the rms on the 200 should be used to push a door speaker.
the 800watt should deff just be hooked to 1 cvx but still wont max it out.
Dec 25, 2008 | Rockford Fosgate Punch 301M Car Audio...
Radio codes
The radio will have to be removed from the car dashboard
.Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
Also quote the MAKE of CAR it is fitted into.
Please note: Not all stereo codes can be calculated from the Serial Number
Oct 19, 2008 | Philips GEMINI XPM-30003 Channel Stereo...
Two amplifier installation
not 100% sure but i think it is because your tryin to pull 2 much power from system try unbridgeing them
Feb 20, 2008 | Car Audio & Video
 Grubhead
Grubhead
