Toshiba dlp red light green light on and off no image
I have a toshiba dlp 46hm94p, i was seeing tv last night then it turned off then on but no image. Now the green light and red light starts to go on and off again and still no image. until the red light and green light stays blinking simultanious.
  • hankinsrl Dec 22, 2008
    Mine did the same thing today accompanied by a rather loud click sound. Possibly a reset button somewhere popped out? hopefully the lamp didnt blow. I recall them being rather expensive.
It was the lamp cover original response was right on point
Posted on Jan 17, 2014
premtech
  • 934 Answers
SOURCE: Toshiba 46HM94P
booboo43,
How's the lamp?? Sounds like a lamp failure which is the most likely problem with these units. The lamp for that unit is Toshiba p/n# 23311083x but a better source would be http://www.dlplampsource.com/ and they have it for $199.00 dollars with free shipping...
Posted on Nov 05, 2007
  • 317 Answers
SOURCE: Blinking Yellow light on a HD 65" DLP Toshiba TV
unplug all nite.
Posted on Aug 03, 2008
SOURCE: toshiba dlp 46 inch red light keeps blinking
42 inch Toshiba DLP. Was watching a movie and the screen went dark. The red light started to flash and kept flashing. any ideas
Posted on Nov 24, 2008
  • 32 Answers
SOURCE: I have a Toshiba 46hm94P. Just replaced the lamp.
make sure the lamp cover is on because sometimes they have switches on them that turns the on when the cover is on but if its off tv might not come on. If thats not the problem then you might have a bad ballast. Call a local tv repair shop.
Posted on Jan 20, 2010
  • 10865 Answers
SOURCE: I have a toshiba dlp,
Hello Santamariael. Here is the manual for your tv Go to page 94 to see all of the info on the blinks. . http://www.tacp.toshiba.com/tacpassets-images/models/62hm15/docs/62hm15_om_e.pdf Actually the interval of the blinks must be timed. Here is the chart
LED Indication Condition Solution
1) Green blinks 3 times The TV is warming up. Wait about 30 seconds until the Green LED lights continuously,
after power cord is and then press POWER to turn ON the TV.
plugged in;
Red is OFF.
2) Green is ON (solid); The lamp unit door is not seated Turn OFF the TV and unplug the power cord. Review "How to
Red blinks continuously properly. replace the lamp unit" on pages 99-100 to ensure that the lamp unit
at 0.5-second intervals. door is installed securely. If the problem persists, contact a Toshiba
Authorized Service Center.
3) Green blinks continuously The lamp is not working properly. The TV automatically will try to restart itself eight times (see item #4).
at 0.3-second intervals;
Red is ON (solid).
4) Green and Red blink The lamp is not working properly Turn OFF the TV and then ON again. If the problem persists, replace
continuously at after the eighth automatic restart the lamp unit (see pages 98-100). If the problem still persists,
1-second intervals. (see item #3). contact a Toshiba Authorized Service Center.
5) Green and Red blink An abnormal temperature Turn OFF the TV. Check to make sure all slots and openings in the
3 times only. increase has occurred. TV cabinet are not covered, blocked, or dusty. Turn ON the TV again.
If the problem persists, contact a Toshiba Authorized Service Center.
6) Green is OFF; The TV requires servicing. Turn OFF the TV and unplug the power cord. Plug the power
Red blinks continuously cord in again and turn ON the TV. If the problem persists, contact
at 0.5-second intervals. a Toshiba Authorized Service Center.
Chapter 10: Troubleshooting
TV/VIDEO EXIT CHANNEL VOLUME MENU POWER
LED indications
The green and red LED lights are on the TV front touchpad, to the left of the POWER button.
The green and red LED lights on the TV control touchpad (on the lower right corner of the TV screen) indicate the TV's current status, as
follows:
• Green ON (solid) and Red OFF = TV power cord is plugged in but the TV is OFF. This is called standby mode.
• Red ON (solid) and Green OFF = TV power cord is plugged in and the TV is ON.
• Green and Red ON (solid) = TV front touchpad is being pressed.
• Green and/or Red blinking (see table below).
Joe
Thanks for choosing Fixya!
Posted on Nov 21, 2010
Hi all. i got 1 toshiba led tv 32pb10e problem DOUBLE IMAGE WITH DISPLAYED RED N BLUE COLOR ONLY ON SCREEN . I TRIED REPAIRED SINCE LAST NIGHT BUT CANT . PLS HELP ME IM URGENTLY NEED REPAIR IT . TQVM
The old projector TV's are using 3 lamps for Red Green Blue....in your case the Green lamp stopped working....either the Green lamp burned or the lamp board is defective.
Mar 31, 2016 | Toshiba Televison & Video
I have a Toshiba DLP 62HM15A TV; I turned the TV off the night before and everything was working fine. But the next morning I went to turn it on, but the power red light came on then turned off then o
Many LED TVs and other electronics have bad capacitors on their power supply boards. You can visually inspect them by opening the TV and looking for capacitors with bulging tops. If you see any, replace them all in the power board section. This should fix the problem. Check to see if your TV is still under warranty first though.
Dec 04, 2014 | Toshiba Televison & Video
My Toshiba 62HM95 62 in. HDTV DLP TV won't turn on...the green and red lights under the power button remain on and the red light flashes. How do I fix this?
Most likely, you need to replace your DLP bulb. The one that comes with your TV will last a few years max. The replacements seem to only last about a year. D:
Dec 08, 2010 | Toshiba 62HM95 62" DLP HDTV
Green led indicator light is off on my 62" toshiba
when you turn it off your light blinks because your internal fans are still spinning allowing the inside of the chassis to cool off, hence the reason you dont watch a DLP TV and then unplug it. DLP's are JUNK
Dec 01, 2010 | Toshiba 62HMX84 62" Rear Projection HDTV
I have a Toshiba 46hm94P. Just replaced the lamp. Now I get the TV trying to start. It will reboot 8 times, with the green light blinking 8 or 9 times while the red light is on. The TV will then turn off...
Jan 20, 2010 | Televison & Video
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
50' plasma, does not turn on,
still nothing, tried twice last night and second time tv worked, this morning nothing
Feb 14, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Toshiba dlp 46 inch red light keeps blinking
Jun 26, 2008 | Toshiba 46H84 46" Rear Projection...
Televison & Video Logo
1,045 people viewed this question
Top Televison & Video Experts
Electro Med Services...
