Question about IGN Entertainment (G60310A) Game Pad
Where can i Download software and drivers for Gamers Factory USB Gamepad G60310A
I have a Twin USB Vibration Gamepad i need the driver for Windows 7
there is no driver for windows 7 as sitek (the chinese manufacturer of the device that sells it as in "white box license" for others to print its logo on discontinued such a device since 2005. Mind you itself has vanished and a new firm has taken over that address.
Thus end of story , problem on relaying on a small time manufacturor , however i do have the xp drivers and they do work , windows 7 would not accept them and insists that the generic driver it uses is up to date (which works fine except the vibration a.k.a force-feed-back wont work)
I am working on a new uproach on injecting the xp driver into windows 7 registry and if it works i'll let you know :)
Mar 05, 2010 | Genius G-12U Vibration, USB, PC gamepad....
I just bought the logitect dual action usb controller and it came with no download instructions. where would I go to find the correct download for the controller?
I would try Logitech's website first, then if not found I would go to I have a Logitech gamepad that I bought new and Windows detected mine and setup it up correctly without having to find a driver somewhere else.
Nov 08, 2009 | Logitech Precision USB Gamepad PC Game...
USB gamepad is not detected.
Get the latest dirvers from the manufacturers website and install it on your pc.After that connect the gamepad.It should work fine.
Code 10 error is due to incomplete drivers or driver malfunction
Aug 13, 2009 | Logitech Rumblepad 2 Game Pad
Gigaware controller on vista
You don't (and can't) disable DEP for the controller (a gamepad controller isn't an application, it's a device which uses a driver, Data Execution Protection applies to applications ie .exe files), it's the game or emulator you disable DEP for, so that you the game can run, completely free of security bindings, and then you would be able to go into the game configuration menu and select your gamepad, and calibrate it. Calibrating means the game detects you gamepad and applies the specific functions to each button.
One way to be sure is to disable DEP for everything, then install a game, and THEN plug in your gamepad. Then start the game/emulator and go to the configuration menu within the game/emulator and set up the gamepad calibration in there.
If it doesn't work, then you haven't installed the drivers for the gamepad properly, or haven't installed the correct driver.
Before doing any of that, you would have checked in Control Panel and Gamepad Controllers, double clicked the Gamepad in the list and pressed Calibrate, to enable generic gamepad functionality.
If you hadn't done that, do so now.
If it still doesn't work, then NOW disable the DEP (either all DEP or for the game/emulator you want to play). Unplug the Gamepad and load up a game. Then plug the game pad in. Set up the gamepad from within the game/emulator config menu, which differs from game to game, of course, but is more or less the same.
If it doesn't work.. re-install the correct driver for the gamepad.
Also make sure your operating system is fully updated and you're plugging the gamepad into a usb2.0 port. and have rebooted after installing the gamepad usb driver.
That's everything you need to know..
Good Luck!
Chris (ziraffa)
Dec 27, 2008 | Video Game Consoles & Games
Gamepad drivers
In this case you can istall the drivers as the vista os is having some trouble in detecting the hardware.
Its always better to go in & install the drivers.
This is the best way to download the drivers of all your devices which are connected to the system for free.
But you have to be patient.
First, i want you to download a free program called "Orbit download manager" from the link below,
And then you can download a program called "Driver genius" from link
it is a trial program for 15 days
dont worry we only need it for 5 minutes
Install & run the program & in the windows click on the update the drivers
It will check & it will give the window with the drives that needs to be updated & it will not update a it is a trial one.
So you just right click on the driver name, you will get a message called 'copy url address 1' copy that & open the orbit downloader & click on the create new download & paste the link the drivers will be downloaded for free.
Some sites give these drivers only for the money & we cannot be able to find them from the free sites, so i think this would be a nice trick.
Good Luck.
Live, Love, Laugh.
May 14, 2008 | Microsoft Windows Vista Ultimate Edition
It may sometimes work without drivers, but its recommended that you download the drivers and have them installed. That way you can also program the buttons for various functions if you want...
Apr 14, 2008 | Logitech Precision USB Gamepad PC Game...
Device driver required
here are the drivers, I have the same gamepad, and CD drivers is like new
link here
sorry for my bad inglish, I'm from argentina
Dec 08, 2007 | Video Game Consoles & Games
Not compatible with windows vista
Hey Guyz Just Go 2 Google And Search for lgs501.exe or LGS501.exe to Download, and then download and install the application on your Vista PC .Plug in the Gamepad(Rumblepad2 or 1) In ur USB Wen ur Installing it.
If youll have any problems\Errors in installing or playing or if you need any original softwares,Games,Cracks,Patches,Drivers,Help,Gamepad Drivers or Help JUsT EMAIL TO ---
Nov 01, 2007 | Logitech Rumblepad 2 Vibration Feedback...
IGN Entertainment (G60310A) Game Pad Logo
395 people viewed this question
Top IGN Entertainment Video Game Consoles & Games Experts
James Wishart
Are you an IGN Entertainment Video Game Console and Game Expert? Answer questions, earn points and help others
