Question about GPS
I shut the nextar off and pluged the power cord into the GPS then into the wall plug. It was on and why I charged it up was because a picture appeared on the screen that had a plug on it. This to mea meant it needed charging. It was plugged in all night and it never got warm as most things do. I unplugged it and was going to turn it on. Nothing happens.I did all I can do by what the instructions say. It did work as I have my home address in it and where we went yesterday. But I never got it to function properly. Thank you so much in advance.
  • towme May 11, 2010
    I have a NEXTAR Model M3-02 and I bought it at ACE Hardware in Dickinson ND on Friday after
    Thanksgiving. The Cord that plugs into the Lighter in the car works OK. The on the is for the house
    did not work. and I bought a new one at Radio Shack it was $31.00 and it works good. Now I let it charge and after about 6 hrs when checking on the battery level,it say 0% of 100% and that means
    the battery is not holding a charge. I have not registered it yet as I just got it and have been busy.
    I was hoping this would work as I have Lung Canser and have been traveling allot lately.
    Thank You Delmar Robertson
    910 19th St. West
    Dickinson, ND 58601
    (701) 483-7821
SOURCE: HOW TOO ADD ADDRESS TOO
my gps is stuck i cannot put my address in to use as my starting point how do i fix it it is stuck on the address across the street i want to put in 1011 libertyville road as starting point.
Posted on Jan 15, 2009
SOURCE: Garmin 305 wont power on, wont charge on cradle
Same thing happened to mine. Put the unit in the cradle (just like you are going to recharge it) and press the reset and mode button at the same time for 3 seconds. This will "wake" the unit up.
Posted on Apr 05, 2009
SOURCE: garmin 200w goes into usb mass storage mode when pluged to charge
Steps:
1) Disconnect the nuvi from the charging cable.
2) Press and hold the battery meter icon for 8 seconds. This puts the nuvi into "system test" mode.
3) Plug in the power cable.
4) Click "Exit." The nuvi will reboot, but remain in GPS mode!
Posted on Jun 17, 2009
  • 11 Answers
SOURCE: i want to download truck routes onto my nextar x3-03
garmin has the feature built into it. though sometimes it will take you down a hog path.
Posted on Jul 21, 2009
  • 4090 Answers
SOURCE: my nextar gps will not keep favorites anymore
Make sure the SD card is not write protected.
Posted on Jul 26, 2009
Can I charge the magellin GPS using a wall charger, plugged into the USB port on the GPS unit if I had rechargeable batteries in it? Or will it blow up? Lol
Yes your magelon already has rechargeable batterys so when in your car you keep it plugeg in all the time.I had a adapter plug with the same voltage output but the positive negitive is backwards.If while pluged into your y fi cord turn on the magelon go to settings you should be able to see the battery leavel if it is stuck on full charge then the y fi cord isnt working but if it is charging from low bar to top bar it will work if not you can buy a wall charger made just for that and again you dont need to replace the batterys unless it wont hold a charge for longe when removed from the car but that is usual for those gps,s not to hold a charge for long when out of the car thats just how it is.
Nov 20, 2012 | GPS
IHAVE GPS NEXTAR BUT IS NOT PWER ON Wath can I do
The battery may be bad but if unit has a lighter power cord it should still power with that connected (watch as most have a fuse in that lighter plug).
Nov 05, 2012 | Nextar Q4-06 Car GPS Receiver
Gps 1412 will not charge
Have you check the voltage output on your power/charger cord? It's easy to test if you know how to use a multi-tester or take it to a small electronics shop like a Radio Shack.
If there is no voltage output from the charger, then simply replace the cord. I have found that those charging cords can break real easily but it's hard to physically see any damage.
Otherwise, if you've already tried a new charger, you may need to send your GPS in for service.
Mar 31, 2012 | Magellan RoadMate 1412 Car GPS Receiver
My garmin won't work while the power cord is pluged in.It shows a picture of a computer and a garmin
Sometimes this is caused by wear in the mini USB socket that the power cord goes into. The plug appears to be in fully but it's not. Pushing it in further may solve the problem.
Feb 24, 2011 | Garmin nuviĀ® 200 Car GPS Receiver
How do you charge the battery? Does it require a battery charger?
Yes, you need the power cord that will go from a 12 volt socket in the car to the GPS receiver.
Best Buy, Radio Shack or possibly Walmart should have one.
Here's one on Ebay for $7.99 and free shipping:
http://cgi.ebay.com/Car-Charger-Power-Adapter-Nextar-GPS-navigation-P-P3-S3-/260658702096?pt=LH_DefaultDomain_0&hash=item3cb0782710
Thanks for using fixya, and a favorable rating is appreciated if this helps you.
Feb 08, 2011 | Nextar S3 Car GPS Receiver
Unit shuts down while navigating with power cord plugged inalso seems to have dead pixels in screen
Dead pixels you can't do anything about without replacing the COLOR LCD TOUCH SCREEN. Which will probably cost as much as replacing the whole unit anyway.
As for shutting down while plugged in, that may be one of two things. Either the charging cord has gone bad (and they do go bad), or your not plugged into the lighter/charging port in your vehicle completely. Lastly, the charging cord for a Garmin GPS has a fuse in it, at the head that plugs into the charging port. Check it to see that it's not blown. Chances are it may be.
Jul 10, 2010 | Garmin nuvi 1300 Car GPS Receiver
WE CHARGE THE MAGELLAN GPS AND TURN IT OFF. BUT WHEN WE GO TO USE IT AGAIN IT IS DEAD. I ONLY HAVE THE LIGHTER OUTLET TO HOOK UP FOR POWER SO WHEN I NEED TO PROGRAM IT IN THE HOUSE I DO NOT HAVE A WAY TO...
Hello kdiltzbook,
Most GPS units can be charged three different ways:
1. Connection to a computer via USB port
2. Connection to a automobile via cigarette lighter plug
3. Connection to a wall outlet via an AC adapter
Typically most GPS devices these days include only the USB cord. Some GPS units also include the cigarette lighter plug. For most GPS units the cigarette lighter plug and AC adapter are optional accessories have to be purchased in addition to the GPS.
You don't mention which model of Magellan GPS you have so I am not sure which cords your GPS should have included. It sounds like you have the cigarette lighter cord and the USB cord? I am sure that Magellan has an AC adapter available for your GPS. You will want to contact them directly (their website is http://www.magellangps.com) or visit an electronics store that sells Magellan GPS receivers (such as Best Buy™) to purchase the adapter.
However, most GPS receivers can be charged from the USB programming cord on the computer. However, ensure you are plugging the cord directly into a USB 2.0 on the computer itself NOT a port on a USB hub. (A USB hub may not output enough power to actually power and charge the GPS.)
You will also want to check and replace the fuse on the automobile plug.
I believe that both the USB and automobile cords should be charging the GPS. If neither adapter is charging the unit then the problem may be the GPS unit itself. The GPS may have a bad battery or problem with its charge circuitry. If that’s the case the unit may require factory service as the battery pack is generally not considered to be end user replaceable.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 07, 2008 | GPS
Can i charge the batt for thec530 by pluging in the computer with the USB cord,Pc to c530
Yes, plugging the unit into the computer via the USB cord will charge the unit.
Dec 11, 2007 | Garmin StreetPilot c530 GPS Receiver
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
