Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Windows xp will not start sucessfully
When turn on the laptop it's not starting up correctly and giving 5 options
-Start windows normally
-last known good configuration
-safe
-safe with networking
-safe with command prompt
None of the above are working and I don't have the Windows Xp CD!
Thanks in advance
Chas
  • kalu4u31 Nov 30, 2008
    do not open my windows open the windows then hang that for many prblem
  • 849 Answers
No way dear,
bring a windows xp cd, then u have two options either install fresh windows or repair the current one.
Posted on Nov 29, 2008
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
My advent notebook 4211-B won't start up, it turns
Hi
Its mean you windows is corrupt may be due to virus infection or some body delete the system file. ok don't worry please take the windows Installation CD and repair your windows, don't worries about your data it will safe, for repairing the windows guide book is available hear.
Select your operating system
Windows 7
WIndows XP
If my solution fix your problem give me the thumb
Jun 23, 2011 | Microsoft Computers & Internet
My Toshiba laptop won't start. When I turn it on a command line itnerface appears saying that Windows won't start sucessfully and it may be due to a recent hardware or software change. It gives me 5...
Go to the safe mode option then once there go to start-run-then type in MSCONFIG then go to system recovery then go to recovery for an earlier time. This will reset your Windows to an earlier time you may be able to salvage it without having to re-install the operating system. F8 also will bring you to "Safe Mode" if not do it through the Dos command screen. If this does not work then you might consider re-installing Windows again. John
Jan 22, 2011 | Computers & Internet
I have an Acer Aspire One with Windows XP and when I turn it on a black screen comes up saying "We apologize for the inconvenience, but Windows did not start successfull..." Then it gives me a list of...
Try to use the last known good configuration the issue should be fixed.. If afforadable try to get a external DVDdrive.. If not try to get one from friends.. Nothing is working.. call acer they will take your computer and reinstall the OS ....
Sep 20, 2010 | Acer Aspire One PC Notebook
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Jan 27, 2010 | NEC Versa VX Notebook
Error window when starting windows xp
restart in setup or bios options
then choose to set to default
then f10 to save and exit
you may have had a virus
let me know
you may need to format
if you can't start in safemode
Feb 02, 2009 | Toshiba Satellite M50 Notebook
My computer froze and I had to shut down manually. Now I cannot get anything on it as I keep getting this recurring screen saying windows did not start successfully and gives me the option of starting in...
dear,
try safe mode and if it runs sucessfully then try again in normal mode or it will automatically start next time in normal mode..
let it be scan as scandisk automatically..
hope it will work
regards,
Oct 25, 2008 | Computers & Internet
Laptop wont start
Dear customer
your system OS is corrupted.so please installed oprating system newly XP or VISTA.try this
Jul 25, 2008 | HP Pavilion ze4145 Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
57 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
