Question about Nokia 6131 Cellular Phone
The web application doesn't work
When the mobile was new it worked. but after a while it stopped working. whenever i try to surf the net using the web application, my mobile just freezes and i have to take out the battery and then re-start it.
    President:
  • 2,110 Answers
Type this code to reset to factory default..*#7370925538#
Posted on Nov 29, 2008
I want gprs setting for nokia 2626
Basic Setting Parameters for GPRS & MMS
Proxy Server :- 192.80.7.133, Port :- 8000
For accessing internet/WAP through your mobile handset :-
GPRS APN :- ntwap
GPRS Home Page :- http://wap.ntc.net.np (You can use your favorite site link also)more...
For accessing internet through computer by using GPRS service in your mobile phone :-
APN :- ntnet
Leave Username, Password and any other fields blank.more... For sending and receiving MMS :-
MMS APN :- ntmms
MMS Home Page/Server Address :- 192.80.11.180
Setting I for Nokia (2626,2600,2760, 3110, 3120,3600, Xpress Music 5200, 5220, 5300, 5610,5310, 6030, 6070, 6080,6085, 6151, 6233, 6280, 6300,6500 Slide,6600,6220,7210, 7360, ...)
1. Enter the main menu.
2. Select Settings, configuration, personal config. setting
3. Add new (From options)
4. Select Web and provide details
a. Account name: Ntc
b. Homepage: http://wap.ntc.net.np
c. Leave User name and Password field blank.
d. Preferred access point: No
5. Then define access point settings
a. Proxy: Enable
b. Proxy Address:192.80.7.133
c. Proxy port: 8000
d. Data bearer: Packet data.
6. Select Bearer settings.
a. Packet data access point: ntwap
b. Authentication type as Normal.
c. Leave other fields as it is.
7. Finally, activate the above created web
8. Restart your set and you are now ready to surf internet with NT Mobile GPRS service.
Note: In case if if third applications(like operamini,ebuddy,mig33) don't work, follow these steps:
1. Repeat the above steps upto 3
2. Select Access point and provide details
1. Account Name: Ntc
2. Go to Access point settings;
3. Data bearer: Packet data
4. Go to Bearer settings:
5. Packet data access point: ntnet
6. Network type: IPv4
7. Authentication type: Normal
8. Leave other fields as blank
3. Save the settings and activate it
4. Restart your set and you are now ready to surf internet.
Apr 22, 2016 | Nokia Cell Phones
Unfortunately, facebook has stopped.
Try updating the facebook software for mobile or try downloading older versions.
If it doesn't work, try downloading the java software. ( java always works)
Jun 28, 2012 | Samsung Galaxy S3
Found error message insufficient memory for china mobile while using net
In china mobile there is very minimum internal memory provided by the manufacturer ,
For good surfing remove your History, cookies and catches from your recent visits home pages from setting,
Use memory card and make it as an storage device for all downloads,
Always clear you cookies and histories.
make free your internal memories to work mobile application smoothly
Aug 17, 2011 | Health & Beauty
I was surfing on net by connectting my samsung c3510 to my pc,and at the same time i want to open gmail java application on same device (samsung c3510).at the movement of opening java application my...
hi just remove the cable connecting to your computer and dismandel the mobile just remove your mobile battery and again replace it as it was and then switch it on the mobile will work as normal
Feb 26, 2011 | Cell Phones
My monitor keeps on blacking out whenever i play a game (bout 5 minutes into it). i think its automatically switching from digital to analog... however when i tried to fix this through the monitor the...
Game uses GPU power, it needs more resource to generate picture then when you are surfing. If you use not integrated video card check GPU cooler fun is working or not, it may overheated and stops responding until cools down.
Dec 15, 2017 | Samsung SyncMaster 920WM LCD Monitor
When you surf the net most of the sites I visit tells me not enough memory. Why? how to solve this problem?
Hey there, This is becuase of your free space on your phones memory and/or becuase you have not got cookies turned on web connection settings..
Either try deleting personal data from your phone memory or try turning on cookies in web connection settings...
regards, Finphillips
Feb 05, 2011 | Cell Phones
Cannot install new applications downloaded from the net
use the Device CD which you got along with mobile
install the PC suit and drag and drop the application in the PC suite it sohould work
if it does not pls msg back ..
Jul 18, 2009 | Sony Ericsson G502 Cellular Phone
Why I can't open web on my N81..?
please before any thing check your network provider and the setting message
and your network setting on the phone
Apr 24, 2009 | Nokia N81
Http/1.1 internal server error
If you are running two versions of ASP.NET, you may get HTTP:/1.1 500 Internal Server Error when creating a new Web project or opening an existing Web project in Visual Studio.
This problem may occur when IIS is not sure what version of ASP.NET to use or where to locate ASP.NET files. One of the following solutions should fix the problem.
Solution 1.
  1. Remove web.config file from inetpub/wwwroot directory
  2. Go to IIS, Right click on Default web site / All tasks / Check server extensions and let it run
  3. Reset IIS by right click on IIS or call iisreset from Run command
Solution 2.
  1. Install ASP.NET again using the following command from your Run command: C:WINNTMicrosoft.NETFrameworkv1.1.4322aspnet_regiis.exe
    Make sure to change the windows folder and ASP.NET version folder with the version what you want to install
  2. Reset IIS
Solution 3. Applies to Windows Server 2003
Note: This is a Microsoft KB article:
When you try to create a new Microsoft ASP.NET 1.1 application after you change the script mapping of the existing ASP.NET 1.1 Web application to ASP.NET 1.0 on a Microsoft Windows Server 2003-based computer, you may receive the following error message:
The Web server reported the following error when attempting to create or open the Web project located at the following URL: 'http://localhost/822319ev1'. 'HTTP/1.1 500 Internal Server Error'.
CAUSE
This issue occurs because Windows Server 2003 does not allow two versions of ASP.NET to run in the same application pool.
WORKAROUND
To work around the problem, do one of the following:
Restart the IIS before you create a new ASP.NET 1.1 application. At the command prompt type the following command: iisreset
OR -
Create an ASP.NET application in a separate application pool. Create the script-mapped application (ASP.NET 1.0) in a separate application pool -- for example, in the ScriptMapappPool application pool. Then, create a new ASP.NET 1.1 application in an application pool other than ScriptMapappPool. For more information about how to create an application pool, visit the following Microsoft Web site: Configuring Application Pools http://msdn.microsoft.com/en-us/library/1kdfe21k(VS.80).aspx
Dec 10, 2008 | Acer Aspire 5610 Notebook
Y!Go is not working
Hi there..
which type of operator service u have means airtel,vodafone,bsnl...
reply first.
Your operator should provide u to surf the net & ushould receive
the configuaration message to surf net.
OK bye
Nov 07, 2008 | Nokia 3110 Cellular Phone
Nokia 6131 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
