Question about Sony CPJ D500 Multimedia Projector
Screen output I have a solid gray stripe with some scatter running up and down on the right side of the output. it doesnt seem to be there on video out. any suggestions or fixes
  • oposeta Apr 20, 2008
    I have the same problem with the same projector. I have just got it, it was a gift. It was supposed to be ok. But I donĀ“t think it is the resolution. Any other idea? Thanks very much.
If connected to the PC, try lowering the resolution. The maximum resolution supported by this model is SVGA compressed (800 x 600). At higher resolutions, I have seen a vertical stripe similar to what you described
Posted on Sep 01, 2007
  • Robert George Jan 21, 2012
    I had the exact same problem and lowering the resolution as you suggested corrected the problem. It would have been nice if Sony had this suggestion in their troubleshooting information. Thanks again!
I have the`same issue with the gray line, but lowering the resolution doesnt remove the line??
Posted on Jul 05, 2010
Sorry, yes it worked!
I did that. I changed the resolution to minimum 600x800 and it is fine. Great. many thanks!
Posted on Apr 20, 2008
Pioneer deh 15ub wire diagram
Yellow - Constant 12 Volt (battery)
Red - Accesory 12 volt (switched) only 12 volts when car in accesory or on position
Black - Ground (chasis)
White/white with black stripe - Front left speaker (black stripe is negative polarity)
Gray/Gray with black stripe - Front right speaker (stripe negative)
Green/green w/ black - rear left
purple/purple w/ black - rear right
solid blue - power anteanna (not all have this wire)
blue w white stripe - remote turn on (used to turn amplifier on or power anteanna)
yellow w/ black stripe - mute (for cellphone handsfree kit)
Jan 21, 2014 | Car Audio & Video
Installing stero in car wiring diagram front soeakers 1999 mercury mountainer
your right front speaker neg side is Green with a orange stripe your right front pos side is Light tan with a green stripe your left front neg side is a light blue with a white stripe and the left front pos is orange with a green stripe,, a typical new radio will have a gray with a black stripe for the neg side and solid gray for the positive, on the right side and the left will have a white with a black stripe for the neg, and solid white for the positive, if you need anything else just reply to this feed and I'll help you
Oct 07, 2011 | 1999 Mercury Mountaineer
Gray see through stripe about 3" long running the length up and down right hand side of monitor Toshiba Satellite MX35
It means your monitor has sustained physical damage. There is no way of repairing it bar replacing the entire screen.
Apr 07, 2010 | Toshiba Satellite M100 Notebook
Wiring diagram for pioneer deh-p41
Yellow for memory.
Red for power acc.
Black for ground.
Blue for remote turn on(amps and accessories).
Gray pair is for right front speakers, solid for positive,striped for negative.
White pair for Left front, again solid is pos, striped is neg.
Violet or purple for right rear, same with solid or striped.
Green pair for left rear, same solid/stripe configuration.
Nov 17, 2009 | Pioneer DEH-P410
Gray Stripes displayed when playing video
I am having the same problem with a Sony Digital 8, When I hit play I see blue screen buy when I press play and fast foward I see the same gray scan lines> Did you have a stuck tape or problems ejecting tape? I think it is more than cleaning the heads. When I try to record it indicates no tape in camera.
Apr 25, 2009 | Canon DC210 DVD Camcorder
A bar code stripe on the right side of the copy.
i'm not sure if you're talking about a solid black band or a bunch of little stripes running down page. does it happen when you run an internal report or only on copies? if its a black solid band, check and make sure the bluish colored tab on top of the drum is all the way to the left side. if its a group of fine lines, depending on whether it happens on internal reports or not, it could be the drum is going bad or you may have a bad scanner. write back with a little more info if this suggestion doesn't work.
good luck,
razors
Mar 18, 2009 | Brother IntelliFAX 5750e Laser Fax
Wire diagram pioneer deh-p7200
Yellow: Constant +12VDC (memory)
Red: key-switched +12VDC (accessory)
Black: Ground
Blue/white: amp remote or power antenna output
Speaker wires: The solid-color wire of each pair is positive; the black-striped wire is negative.
Left front: white
Right front: gray
Left rear: green
Right rear: violet
Hope this helps!
Mar 07, 2009 | Pioneer DEH-P7200 CD Player
My wife bought a kenwood z828/uf4. there are wires in the back but none of them are labeled. can anybody help me
red - 12v ignition
yellow - memory 12v cont.battery
orange - illumination
black - ground
white- front right speaker +
white/black stripe - front right speaker -
gray - front left speaker +
gray/black stripe - front left speaker -
violet - rear right speaker +
violet/black stripe - rear right speaker -
green - rear left speaker +
green/black stripe - rear left speaker -
blue - remote, amp
blue/white stripe - power antenna
if you don't have a blue/white strip wire than the solid blue wire goes to power antenna, amp and remote...........
hope this helped you
Feb 26, 2009 | Kenwood Car Audio & Video
I have a kenwood krc-3005 radio I do not have a wire diagram can you help
Yellow (+) Constant 12 Volts
Red (+) Switched 12 Volts
Black (~) Ground
Blue w/white stripe (+) Remote Out(used to turn
on the amplifiers)
Orange w/white stripe (+) Dimmer IN(used to dim
the display of the unit)
NOTE. if you dont want to hook up this wire it doesnt matter)
SPEAKERS OUTPUTS
White(+) Left Front
White w/black (~) Left Front
Gray (+) Right Front
Gray w/black (~) Right Front
Green (+) Left Rear
Green w/black(~) Left Rear
Purple (+) Right Rear
Purple w/black (~) Right Rear
Jan 04, 2009 | Kenwood KRC-207S
Sony CPJ D500 Multimedia Projector Logo
274 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
