Water dripping from split level aircon on to floor
  • Anonymous Mar 25, 2014
    Water is leaking from the front of my aircon onto my floor.
  • 34 Answers
This time of year it's either from your humidifier or if you have a high effeciency furnace it's because the water isn't draining where it's supposed to.  you need to get to the furance or air handler and make sure the drain line is where its supposed to be.
Posted on Nov 30, 2008
Water leaking on floor of 2005 camry AC
Ok well had same problem. The drain hose is blocked and is backing up and coming out of top of drain plug and tube into the car so the tube hanging down in engine bay left side of motor may be blocked with mud dirt or something else so check it and with aircon on if the water is not dripping out of the drain tube then it is blocked
May 29, 2014 | 2003 Toyota Camry
Summer rite window air conditioner
if its driping on the floor then yeah a pan is good all aircons have a drain cause they create water of the coil
Jun 29, 2013 | Heating & Cooling
Carrier split unit aircon mdl 42P100c has water dripping from the unit mounted internally onto floor.
Due to non maintenance of a/c. Col and air filter dust blocked. Due to this, some time ice formation over the coil will be there. Clean air filter, coil and blower wheel. And also drain pan.
If you see any ice formation over the coil after service, it's meant for short of gas. Thanks.
Jan 11, 2011 | Heating & Cooling
HI my samsung split sytem aircon is dripping water on to my carpet? only just started today. Richard
Check outside for the drain hose and make sure water is draining.If not, disconnect hose at evaporator ,and blow it out. Do not **** it from the open end: it does not taste good.
Feb 23, 2010 | Dehumidifiers
Ford Fiesta 2003 1.3 If I run the aircon water leaks onto the floor of the drivers side (by the pedals, alot of water.
In the dashboard,set down low is a driptray.It collects water that comes off the aircon.It has a hose (sometimes 2) that drains the water out of the car via the firewall so it drips onto the road.This is blocked or the tray has a buildup of gunk.The hose is about 1/2 inch thick.If you lay on the floor where it leaks with a torch you should find it.Or look in the engine bay,just to the left or right of centre(which side leaks?)and backtrace it into the car.You may find the inside hose has fallen off allowing the water to drip inside.Hope this helps you
Jan 01, 2010 | 2007 Ford F
My split type aircon wont work properly, water keep dripping
try cleaning the port for the drain plug, when the air is damp outside it will condence a large amount of water. Aslo make sure unit is level so it will drain properly.
Jul 19, 2009 | Fedders Heating & Cooling
Air conditioner dripping water
Try pouring some bleach in drain.
Jun 28, 2009 | Fujitsu 12C1 Air Conditioner
1. Do not set the aircon too low temperature in overcast weather, this will cause ice ups and water dripping. Optimal comfort zone temperature is 24c.
2. You need to open the grill cover on the front of the aircon which unclips either end left and right with a finger pressure. You will find two filters which can slide out and should be cleaned. First tap them together to remove dust, then you can wash them with mild soap and cold water.
3. There is the third possibility that an insect has made a nest in the drainpipe. You should look on the outside of the building and locate a plastic drainpipe. You can either blow into this pipe with your mouth or get a blower. This will unblock any restriction in the drainpipe.
Goodluck and ratemeplease.
Mar 19, 2009 | LG LSC121PMA Split System Air Conditioner
Fujitsu wall mounted air conditioner.
 during Cooling and Dry modes, if the unit is used under conditions of
lower temperature (18C)  the heat-exchanger may freeze, leading to water leakage and other damage.
If the unit is used for long periods under high-humidity conditions, condensation may form on the surface of the indoor
unit, and drip onto the floor or other objects underneath. (About 80% or more)
Increase Temp to 20 and also run coil dry cycle,
Jun 03, 2007 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
327 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
