Question about Toshiba 53H71 53 in. Rear Projection Television
No brightness for Colorstream either connections
Hi ! Recently bought this TV used from a friend. Analog interfaces work good. When I try to use any one of the 2 Colorstream interfaces, the video is there, the colors seems to be there, but in 'darkness'. Like there is no backlighting to illuminate the colors. It is not a problem with a bad cable box or a bad DVD player, as the previous owner had the same problem. I am pretty knowledgeable with electronics and know how to solder electronics. Can anybody help at least narrow down what may be faulty ?
Sounds like a bad coupling capacitor in the luminance "y" signal processor circuit. Use a schematic of the tv and a osciloscope to find this problem.
Posted on Feb 02, 2007
This received analogue in UK until the switch to digital.Is there a small digibox for this available?
Yes. you can buy an analog to digital; or a digital to analog converter according to your need. It must be interfaced between your TV and cable input.
Jun 08, 2015 | Televison & Video
Esa tv digital to analog
Hi.I assume you can watch some channels, using your indoor digital antenna. As far as I know, you need an intermediate "box", or interface between the cable TV coming in, and the decoder. This has to be installed by the cable company. Between the decoder and the interface, there are two connections. One signal connection and one UTP wire connection for communication between both units.At least, that's how it works in Belgium and most other countries.
Jun 24, 2014 | ESA ET427E 27" TV
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
No picture, no sound, but has power light...any suggestions? thx in advance
Do this first:
1: Check the antenna/cable connections.
2: Press the TV/VIDEO on the remote control or the TV to view a signal coming from another device connected to your TV, such as a VCR or
video disc player. You can select ANT 1,
VIDEO 1, VIDEO 2, VIDEO 3, ColorStream HD1, ColorStream HD2, or ANT 2 depending on which input jacks are used for connecting the devices.
*Be sure you have the right source to view video.
Try the above and post back before I can say there is a problem with your unit. If you have the user manual it's a good time to get it out. If you don't have it let me know and I will give you a link to obtain it. Good luck!!
May 23, 2009 | Toshiba 50H82 50" Rear Projection...
Its not broken or nothin i was wondering how to put the input for cabel from cable/sat to colorstream hD1
Cable boxes or satellite receivers typically only come with audio/video output, RF output, and component output. You need an upgraded one which has the Hdmi output jack. The upgraded box will cost you a service fee around $5-10 a month, so if you don't want to pay to receive the 1080p service you can receive 720p by using the component video output leads from your cable box.
The quality is almost as good. The only difference will be that you won't be able to receive the hi-def channels that the cable company offers.
Apr 29, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
No signal
Weegee, Unfortunately you are trying to mix two different video types: VGA is an analog video interface found on most computers (except for latest with flat panel monitors, which are usually DVI). Your TV DVI interface is digital (although there is a DVI-A, which is an anlog DVI interface, it is unlikely that your TV has this). So, what you are trying to do probably won't work. I assume your computer does not have DVI output (otherwise you wouldn't have bought the adapter), but some monitors have VGA inputs; does yours? What kind of DVI adapter did you get? Is a DVI-A? Check out http://en.wikipedia.org/wiki/Dvi for info on DVI interfaces.
May 12, 2007 | iLO 3200 32 in. LCD Television
Toshiba 30HF84 and progressive scan
check your connections properly there could be some thing that you are not connecting .or your cable are not compatible.good luck
Jan 23, 2007 | Toshiba 30HF84 30" TV
Toshiba 53HX71 Proj CRT television - colors missing with HD only
DANGER I take it you understand that these can kill. Even WEEKS after they have been unplugged. The chassis can be HOT on them too, what is normally considered to be EARTH can be live with thousands of volts. Bleed the capacitor down first, using the right resistors, use rubber gloves, boots and stand on a rubber mat. Keep one hand in your pocket to avoid current going through your heart if you mess up. This is just how I do it since a near miss. Check out precautions yourself, from a reputable source if you still wish to try. Now that I have said that, it may be connections on the inside of the Colourstream interface. Sounds like you have dropped a colour and have another problem that could well be related. ie: two wires touching or shorting.
Jan 17, 2007 | Nolo Dealing with Problem Employees: A L...
Toshiba 53H71 53 in. Rear Projection Television Logo
51 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
