Question about HP Office Equipment & Supplies
When trying to copy original, copy comes out completely black! help.
  • snapper45 Dec 03, 2008
    THANKS, IMAGING UNIT IS FAULTY - TRYING TO GET A REPLACEMENT
    Novelist:
  • 158 Answers
First, from the MENU screen on the HP, print a CONFIGURATION page. If the print is ok, your scanner is the problem, maybe the scan light is dirty or defective. If the print is black, the DRUM or the IMAGING UNIT may need replacement. These are "consumable" parts that can be ordered like toner cartridges as "supply" items. DO NOT try to clean the imaging unit! The drum can be damaged by even a fingerprint. If there is spilled toner inside the printer, you can TRY to wipe or brush it away. DO NOT use a vacuum! The static WILL DAMAGE THE PRINTER CIRCUITS.
Posted on Dec 01, 2008
"error downloadable content has changed" can you
I have the solution time after time I tried playin and got this problem if ur I burnt bout 4 different copie then I burrowed a original installed now back up works fine
May 10, 2011 | Activision Call of Duty: Black Ops
Copystar cs1510 showing error e70 please help
The E70 its a troubleshooting original placement and memory errors:
1. Remove originals and replace them in the original table when the "E70" or "E71" errors display.
2. Remove originals placed on the original tray and allow the copy job from the plate to complete when the "E72" error displays.
3. Remove originals remaining in the original table when the "E90" error displays, indicating that the memory is full. Press the button with a "%" sign on it, labeled recall, to print the copies of the originals that have already been scanned. When printing completes, place the remaining originals back into the original tray and press "Start" to continue copying.
Hope helps.
Apr 18, 2011 | Copystar CS-1510 Copier
My HP photosmart is printing out completely black pages when i put something in to copy!
It would be worth checking if the lamp is coming on when it scans the original in for the copy. I bet it isn't...
Aug 31, 2010 | Office Equipment & Supplies
When I send a fax the receivers copy is black.
Make a copy with the machine. If it comes out black as well your scanner has gone bad. In other words when you insert an original to be "scanned" so it can be faxed or copied, it is being read as all black. Usually this occurs because the row of led's that light up the original go bad. Now I have seen in some cases, if you unplug the machine for a bit then power back up the problem goes away so try that. Test by making a copy. If this does not work then your are looking at a scanner assembly replacement or just get a new machine.
Good Luck and Thank You for using Fixya.
Aug 25, 2010 | Brother IntelliFAX 4100 Laser Fax
Black copies
lay an original on the glass and make a copy, see if the lamp under the glass stays lit as it scans the original. Don't look directly at the light, it's very bright.
Apr 24, 2009 | Sharp Office Equipment & Supplies
Copy is 90% blacked out
Hard to tell what your trouble is when you don't say what type of machine you have, but some canon copiers had a common problem like that.
The scanner cable would break. Lay an original on the glass and make a copy with the top cover open, if the light under the glass comes on and then goes out while scanning the original, that's what your trouble is.
Apr 18, 2009 | Office Equipment & Supplies
Black pages on every fax I send
Is sounds like your exposure lamp is not coming on, put an original in the machine and make a copy, if you look where the original is coming out, you should be able to see a light illuminatig the original so the scanner can read the image. If this lamp is not coming on you will get a very dark to black image.
If it is just locked up is may be as easy as this. Turn off and unplug the machine for a couple of minutes, reconnect and power up the machine, make a copy. as the machins uses the same parts to copy you should see the result of your efforts.
If the copy look good, try a test fax to someone, and call them for confirmation.
If this doesn't fix the problem, then I suspect the exposure lamp unit has failed.
Hope this is of some help.
Apr 17, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
Fax problem
Something is blocking part of your scanner light, or scanner light may be bad. Check if the scanner light comes on, and check inside the original feeder and machine for a scrap of paper blocking the scanner light to the imaging drum.
Nov 26, 2008 | Brother IntelliFax-2820 Laser Fax
Xerox workcenter XD120f
The small scanner glass (not the full size glass) has some dirt on it. Use a lint-free cloth (not paper) with alcohol or Windex and clean the glass. This should help.
Nov 14, 2006 | Xerox WorkCentre XD120f Copier
Ben Johnson
