Hi I have had a problem with my computer part of the hard drive became corrupted and part of the RAM memory burnt out. this resulted ina new hard drive and Ram memory I am not sure if the updated version of my symantec was retrieved I have had this fixed and need to know if I have to re download my security again? Sam
  • 102 Answers
Just to be on the safe side just download again ok
Posted on Nov 29, 2008
Is ram and memory the same?
Yes it is Ram stands for random access memory .........cheers
Jan 27, 2011 | Toshiba Satellite L25-S119 Notebook
I bought a ep43-ud3l mobo that I installed with windows, after moving some files from my old hard drive windows became corrupted , boot up resulted in BSOD, erased windows bsod, formated HD BSOD, removed...
pls check the cpu compatibility. one time I tried to install 64bit , but could;t install. 32 bit was ok. check the video adapter and remove it and try it with on board vga
Jul 17, 2017 | Gigabyte GA-EP43-UD3L Motherboard
My computer will lock up for no reason.
all of the things listed below can cause a PC to lock-up:
  • Windows 95/98 instability
  • Hard drive errors
  • Incorrect or corrupt mouse driver
  • Loose or reversed mouse and keyboard connections
  • Running out of RAM memory
  • Resource leaks
  • Software conflicts
  • Computer viruses
  • Bad RAM memory
  • IRQ conflicts
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 14, 2010 | HP Computers & Internet
Want it 2 be main hard drive on desktop,
There seems to be a misconception here. The virtual memory is a part on the Hard drive that your computer uses similar RAM. It only uses it once you have utilized most of your RAM so increasing it would not do much value at all. I suggest you upgrade the physical RAM sticks. (the memory physically attached to the motherboard of your computer). For your Seagate, it would be used just as a storage for data and not as memory. and since it is external, you could also not allocate some part of it to be used as virtual memory.
you could go to a computer store and ask them what memory (RAM stick) would be compatible for your computer if you want to do an upgrade. I'm sure you could also ask them to put it on for you to have the result or your desired amount of memory installed to your computer.
hope this helps.
Jul 09, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
HP Pavillion dv6700 - black screen
Do the following without the battery inserted.
Let the computer sit with no battery for 24 hours. Do not put the battery in at all. Try using your original memory stick ONLY, with no hard drive and see if it will POST. If it does, insert the hard drive and try again. Could be the new memory...
Another thing you can try is reseating the processor. Turn the ZIF screw, take the processor out (WATCH THE PINS!!) and put back in GENTLY. Leave the memory in the computer, hard drive removed, try to power on.
These models have been known for bad motherboards. Contact HP and arrange to send it in. If you do enough digging on HPs website, you'll find the service advisory.
-Dell & HP Certified Technician
Oct 29, 2009 | HP Pavilion DV6700T Notebook PC
I turned on my external f drive this morning, after it worked fine last night. Now shows as local disk F. I cannot access it as it says F drive is not acessible error performing in page operation. I have...
The inpage operation error actually refers to an error going between the drive and your RAM. Try the drive on a different computer, if it works the problem may be in your RAM, if it doesn't the drive is corrupted and can't be read under normal circumstances.
If it does work, let me know and I'll link you to a memory diagnostic program to test your RAM. If it doesn't work on the other computer, let me know your Country, State and City and I can refer you to a nearby Data Recovery team.
Chris
Aug 06, 2009 | Fantom Drives Titanium II (TFD160U2) 160...
Setup was unable to verify drive C:.
hi ;
this sems to be a memory problem;
in bios , try to decrease the memory for your card to resrve a memory space for the installation program,
if this does not work , it might be your VGA card.
Mar 11, 2009 | Computers & Internet
Usb flash drive corrupted
try other usb port, or other computer, if still have problem, download a usb recovery software, one I used before is Asoftech Data Recovery, you can follow this guide for usb recovery
usb file recovery guide
Oct 18, 2008 | Electronics - Others
E Machines
In this situation I would start by testing the hard drive then the RAM.
For the hard drive find out the manufacturers name and download their test program.
For the RAM test I have used a free program call memtest86 with very good results.
If the problem is the hard drive, you may be able to install a hard drive of the same size and using an imaging program copy the old drive to the new drive. Re-run the recovery program. My suspicions are that the old drive has developed bad clusters near the beginning where the operating system is and some of the files have become corrupt.
If the RAM fails the test replace the RAM and try again.
Apr 27, 2008 | Dell PowerEdge 2500 Server
How much ram can i install on a hp compaq d220mt?
Laptop Computer Memory Desktop Computer Memory Printer Memory Memory Applications All data processing and execution takes place within the memory module(s). The program's directions are replicated into memory from a hard drive, external drive or from a network. The processor then extracts the directions from the memory and puts it into the circuit for analysis and execution.
Memory is so important that it cannot be wasted. RAM is allocated by the operating system and programs, and then released when not needed. Errant applications can grip RAM and not release it, which results in a diminishing amount of memory available as you load and use more programs.
If you could actually look into memory, you would be astonished. By watching how much and how quick data and commands are written in and out of it each day, you would realize it is a marvel that it works so we
UpgradeComputerMemory.com is here to help you speed up and breathe new life into your computer by adding more RAM memory! We have hundreds of relationships with different manufacturers and carry all major computer memory brands. This includes Dell Memory, HP Memory, Samsung Memory, Micron Memory, Toshiba Memory and many, many more. We can cut through all that computer jargon and provide you with the part that will work each and every time. Our 100% guaranteed compatible RAM memory upgrades are available for more than 21,000 different computers, laptops, servers, printers and other electronic device.
Jan 15, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
