Question about HP LaserJet 3050 All-In-One Printer
HP 3050 When I'm recieving faxes if there is more than one page it will print 1 and 5 of 7 or 2 and 4 of5 and says communication error
  • 1 more comment
  • Anonymous Mar 12, 2008
    The outgoing faxes are intermittently illegible and another fax machine on the same line does not have the same problem. Incoming faxes are fine.
  • Anonymous Jul 21, 2008
    same porblem
  • Anonymous May 14, 2009
    When I use the copy feature, I am getting a solid line printing vertically on the copy. Any ideas
The issue with the solid line is that you have some dirt/tipex on the glass scan plate, if you lift the front up you will see the dirt on the glass plate, clean it & your issue will be resolved.
Posted on Oct 13, 2008
When I use the copy feature, I am getting a solid line printing vertically on the copy. Any ideas?
Posted on May 09, 2008
    President:
  • HP Master
  • 2,022 Answers
There is problem ith fax line see it is not giving any disturbance i the line . bye
Posted on Oct 03, 2007
My HP Laserjet 3050 used to print automatically after each fax sent a call report showing that the page(s) had sent. For some reason, after a service call, now it doesn't do that any more and I have...
Hi Dear
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  1. Press the right arrow until Reports appears in the display, press the checkmark.
  2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
  3. Press the right arrow until Print Report appears in the display, press the checkmark.
  4. Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
  • Send Fax Only - a confirmation sheet will only print when a fax is sent
  • Never - no fax confirmation sheets
  • Every Error - default setting
  • Send Error - a fax confirmation prints when the fax transmission encounters an error
  • Every Fax - a fax confirmation sheet will print for incoming
Jun 01, 2011 | HP LaserJet 3050 All-In-One Printer
Recieve faxes problem in hp laserjet 3050
- cables properly connected
- analog or digital (DSL, VoIP, etc) phone line
- dedicated line?
- under fax setup, all faxes, turn error correction off
- under fax setup, all faxes, turn v.34 off
- test fax
Jul 17, 2010 | HP LaserJet 3050 All-In-One Printer
Comm error 232
This is the common cause and solution: A communication failure has occurred between the two machines. On the other hand, the user at the remote machine may have pressed the Stop button. Alternatively: the power at the remote machine has been interrupted, or deliberately turned off causing the fax session to be interrupted.
Solution:
1. Re-attempt the fax reception at a different time when telephone line conditions have improved.
2. If the error persists, and error correction is in use for the fax session, disable ECM . (See Error 222)
Good luck
Jun 12, 2010 | HP LaserJet 3050 All-In-One Printer
No communication between faxes.
settings are wrong also check lines to device
May 01, 2010 | HP LaserJet 3050 All-In-One Printer
I receive 1 page of an incoming fax but then the next page is a fax call report saying comm error 232
Try this...
a) changing the Error Correction Mode (ECM) to OFF
b) disabeling V.34 option
steps for
a) Fax setup -- All faxes -- Error correction -- OFF
b) Fax setup -- All faxes -- V.34 -- disable
I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
Mar 31, 2010 | HP LaserJet 3050 All-In-One Printer
Hp 3050 laser jet printer the fax page is black
The scanner in your FAX is nothing working -- i.e., "100%-black" or "100%-white", and so what is transmitted is what the scanner has scanned, improperly.
Dec 13, 2009 | HP LaserJet 3050 All-In-One Printer
Hp laserjet 3050 fax report
The error 244 results from a fax machine communicating and trying to 'Poll" your fax. (receive information you have loaded into the fax memory for all to receive) The error comes in when your fax has no information or is not set up to be polled.
Look in your menu for the "ECM" setting on the printer menu. If this error is getting persistent change the ECM setting to the opposite of what it is set now. More than likely your fax will say ECM=On, change to off.
If you have problems locating where the ECM section is, print a "settings report" or "printer menu".
Hope that helps you.
Sep 02, 2008 | HP LaserJet 3050 All-In-One Printer
Fax confirmation set up
document.tlSearch.tx.value=unescape("") s.gif s.gif HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
  • Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
Mar 31, 2008 | HP LaserJet 3050 All-In-One Printer
Low memory display on HP Laser Jet 3050
Hello All,
Please perform the following:
Super NVRAM init
When a super NVRAM init is performed, the all-in-one language and telecom country/region settings
are undefined. The user is prompted to set the language and telecom country/region. Until these settings
are defined, the all-in-one will not return to the Ready state.
CAUTION A Super NVRAM init erases all data that is stored in both the unprotected and
protected NVRAM memory.
To perform a super NVRAM init
1.
Turn off the all-in-one.
2. Press and hold down the * and 5 buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. When prompted, set the language and telecom country/region.
6. Allow the all-in-one to return to Ready before using it.
Mar 10, 2008 | HP LaserJet 3050 All-In-One Printer
Fax receiving problem in 3050
changing these settings:
ECM-error correction 'off'
V.34 'off'
Silence Detection 'on'
Dec 28, 2007 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
166 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
