Question about Orion STV2763 27" TV
Message on TV Error cannot access digital services
It seems that I have lost all digital services
  • 1 more comment
  • lisagedling Feb 14, 2009
    ORION HDD FREEVIEW 37" TV TV37RN10D. WE ARE UNABLE TO ACCESS ANY DIGITAL SERVICES, TV WAS WORKING FINE BUT NOW CANNOT ACCESS ANYTHING. ANY IDEAS ?
  • Anonymous May 17, 2009
    Digital tv has been working fine for months. Today when i turn it on it has a ERROR CANNOT ACCESS DIGITAL SERVICES and none of the digital channels are available...otherwise their seems nothing wrong with the tv and it is only 4 months old.
  • johnsonanton May 22, 2009
    i also have the same problem, & the manuel states that it is DVB compatable, & up until the 17/05/09 i have had all the freeview channels
  • Orion Master
  • 5,568 Answers
According to the specs on that model, it does not have a digital tuner capable of receiving ATSC signals. You need a converter to receive the digital signal and convert it to analog so that set can process it. Unless you already have a 'black box' between your signal source and the Orion, you have never received 'digital' signals.
Posted on Dec 17, 2008
When I try to access the digital channels having watrched something on analogue TV get an error mesage 'error cannot acces digital services. Cannot access retune facility in tool menu, tried switching...
If you are accessing the tuning menu correctly; according to the TV's manual, try unplugging the set for half an hour or so, it will discharge all the capacitors and return to the initial setup page. If this does not work, there is a problem in the digital tuning board and would need to be serviced. Hope this helps.
Jun 01, 2011 | Televison & Video
Cannot access digital service
Get a roof a antena,or digital antena for better serviced.
Nov 23, 2009 | Televison & Video
Error message: "Door Open"
HI there,
Follow the steps below:
Step one: Close the print cartridge access door
1.Verify that the print cartridge access door is completely closed. It may appear to be closed, but if it is not completely closed, the error message will display. Verify that there are no obstructions blocking the door.
2.If you are unsure how to close the print cartridge access door on your model, consult your User Guide for more information.
Figure 1: Examples of closing the print cartridge access door (your model may vary)
f3e57be.gif If you have attempted to completely close the access door and the error still appears, there may be a problem with the door sensor and the unit may require service.
Step two: Service your product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Good Luck!!!
neo
Feb 28, 2009 | HP OfficeJet Pro L7580 Color All-in-One...
I have one of these new TV's and cannot find the manual. It seems that I have lost all digital service. the message that comes up states. ERROR CANNOT ACCESS DIGITAL SERVICE
Hi Try inputting TV manufacturers info into a Google search, manuals are normally available to download from the makers web site
Nov 29, 2008 | Televison & Video
I have an Orion TV32rn10d and i have error reporting cannot access digital services although it was working fine this morning
I had this problem as well.... the TV jsut froze and then it turned onto analogue and when i press the TV/DVB-T button it came up with the following message...
Error
Cannot Access Digital Services
Solution...
I pulled the plug out the back of the TV waited 5 seconds and put it back in...
suprise suprise it works :D
Sep 08, 2008 | Televison & Video
Flashing error signal
Seems in a drop or knock flash board might touch metal and short out. When camera gets that error usually the main system board needs to be reset and it seems only trained service technicians have access to tools required to do this
Feb 12, 2008 | Sony Cyber-shot DSC-W70 Digital Camera
Orion tv32RN10D Digital problems
factory reset hold volume button on tv down all the way while holding it down hold number 1 on your remote goes to stanby turn back on..
Jan 08, 2008 | Orion HDLCDVD225 22 in. LCD TV
Error message saying video lost and not recording
There are several possible issues at play whenever the lost video message appears.
First, have cameras lost power? If you powered cameras through a central power source, inspect it and verify it is working
If you powered cameras through a plug in transformer, touch it, if warm it is working
Next touch the cameras, are they warm? If so, they have power.
Once you have determined cameras have power, disconnect power for several minutes. Turn power back on, if cameras respond and send video, your cameras have likely suffered damage from a power surge and are near failure.
If you have access to a small tv with an RCA video in jack, you
can test this by leaving the camera powered, run a short length of cable from the tv to the camera. We use hand held mini monitors to test this, but they are pricey,
It is most likely that have power surge damage and the cameras need to be replaced
Oct 25, 2007 | Geovision GV-650 BNC (GV6504) Video...
Orion STV2763 27" TV Logo
661 people viewed this question
Top Orion Televison & Video Experts
wayne chamberlain
Jerry Greenberg
Jerry Greenberg
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
