Question about RCA HD52W59 HDTV Projection Television
TV DOES NOT TURN ON
Tv does not turn. Went you push the power button on the back at the left hand side you can see a spark
    Genius:
  • 1,030 Answers
Sounds like you may have the flyback arching. Ussally when we replace the flyback. at the shop the horizontal output transistor is shorted. so usally replace both. now i would no recommend this repair for a non tech. the flyback can be tricky. but if your a tech or have experience in electronics definatly possible. parts about 60 dollars. at our shop this repair ussally runs 150 to 175
Posted on Nov 30, 2008
Once the current went out in our residence, the tv went out as well. When the current was restored, the tv didn't come back on by the remote or pushing the power button on the tv itself. Where the green...
Although you may think the power outage has ruined your TV, it has not. I have repaired this model . This model by now has several bad grounds. The worst case is in your convergence board. This problem was in the process before the power outage. I do not believe you will have to purchase parts for this particular model. If you can very carefully pull out the convergence board, you will find 15 or twenty bad solder grounds on the solder side of this board. The major concern will be that the convergence IC, which is a STK-393-110 has separated pins from the board. This would be the first thing to solder. Next the jumper jack cables that connect this board to the other two boards will have bad grounds as well. You must really,really have good eyes to see the cracked rings around the pins of any and all ICs,resistors,transistors, capacitors, diodes etc. This will restore the operation of your TV. I must tell you...it will not be easy to pull this board out and replace. You may opt to see a TV tech. Show a tech this info. This will repair this TV. Thanks for asking and show a few hands of support!
Feb 20, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I have an RCA big screen tv and when I push the power button I can see that it sparks at a splitter box under the bulbs. The tv will not power up
first you have to open the back cover of the television to check for bulged capacitors.
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps....
Jun 07, 2010 | RCA Televison & Video
I have a 1994 50ex8k hitachi rear projection tv that wont turn on
it has a built in safety. there's a problem with tv board
May 31, 2010 | Hitachi Televison & Video
D52w19 rca hdtv.will not tourn on. when u push the
Hi Friend,
Please folliow the below steps one by one
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
If still you are having the same problem then please check the resolution configured in the Screen,try to reduce the Colour and the brightness of the TV
Even after that you are facing the same issue please check with the Display Card in the TV,
If you have any Clarification please feel free to contact us
Regards,
Ayyasam
Apr 03, 2010 | RCA D52W19 52" Rear Projection Television
I have no picture. After the power button is
Hi Friend,
Regards,
Ayyasam
Apr 03, 2010 | Akai PT4298HD Rear Projection Television
The tv turns on and off when power button is pushed. Now the tv will not turn on at all
Remove Back on left hand side bottom board,it is your Deflection/Power board has FBT flyback Transfomer on it. CK these 3 capacitors if they Look swollen,vented or puffed up on top they are Bad
Cp150 2200uf16v Cp114,120 220uf 35v replace all 3 if any one of these are Bad.
Mar 24, 2010 | RCA D52W19 52" Rear Projection Television
Philips rear projection tv 7 years old 55PP9352..
when yellow led....push the "P-" button about 5 times then push the left hand square button (looks like square with arrow pointing right) several times until it cycles to the input device.... order is ext1, ext2, ext3, front input, TV....
Nov 04, 2009 | Televison & Video
The power went out today. Once the power was restored, the green (Timer) light simply keeps flashing and the TV wont turn back on. None of the buttons on the front of the TV work nor does the remote. I...
There are 7 capacitors that need replacing in you digital module, it is located on the left hand side facing the back of the set. After opening the module there is a small power board inside, replace all 1000uf 16volt capaictors with 680uf 16volt capaictors. After replacing them there will be a small green led on the board that lights inside the digital unit. it will flash then go steady if all is ok with the set after replacing these capacitors. After this is done the power light up front will blink about 30 secs then go off. Turn on the television and happy viewing...
Please leave comment...
Oct 08, 2009 | Televison & Video
Mitsubishi WS65513
4 1000mf caps on the dm module. replace with equivalent size and temp range. dm mod is inside the vertical standing metal case in left hand side of chassis looking from the back
Feb 19, 2008 | Mitsubishi WS-55513 55" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
48 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
