Hi the machine is a la spaziale cjz it is leaking water from the boiler i believe also after you switch it on it is fine for a while. then all the main llights on the front come on and i can not use the machine afterwards i belive it to be the thermostat that is faulty is this correct thanks.
-   Syncrony logic uses 2 fills from grinder to make 1 cup. First fill produces nothing second fill works normally. This is followed by a considerable amount of clean water flowing across work surface. -   goggle eyes
Dec 15, 2008
-   Same deal, hot liquid (coffee, tea, whatever you're making) leaks out all over the place when you make a cup now. Cleaned everything, there do not appear to be any missing / damaged seals or gaskets. I think this machine is worn out, after about 11 months of use.
-   fixya287
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop...
(More)
Where in North-Central London can I purchase a replacement gasket for a 1-2 cup vigano stovetop espresso maker?
despite scrupulous cleaning, the dual frother plus wand keeps popping off my jura capresso espresso...
(More)
despite scrupulous cleaning, the dual frother plus wand keeps popping off my jura capresso espresso machine
