Question about Sewing Machines
I have a Janome 2039. Every time I try to sew with it, it is gathering the thread into the bobbin area and getting stuck. Any ideas
  • Anonymous Dec 18, 2008
    The Tread gathers under the plate. I need to know what #'s to use for my settings. I bougth the machine at a yard sale, have no manuel.
  • mohammed marika thambi
    mohammed marika thambi May 11, 2010
    remove bobbin holder area and small bit of theared inside just remove the theared and clean the bobbin holder area u fix the bobbin try to sew
  • Sewing Machines Master
  • 1,388 Answers
If you are using a standard top tension of 4 or 5 and this problem has developed over time, the most likely cause is lint deposited between the tension disks....... if the top tension is loose, or in the tension spring of the bobbin case if the bottom tension is having troubles. In either case you need to remove the lint......
Raise the presser foot and with a length of scrap fabric, use an action like flossing your teeth to get between the top tension disks......in extreme cases a probe (old needle) may be used very gently to remove thread and lint, but be VERY careful not to scratch the polished surfaces.
I have also written a tutorial on tension balance which may be of further assistance, particularly for bobbin tension issues:
Please TRY the solution BEFORE giving your considered rating.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
I have a Janome 2039. - 4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
www.bargainbox.com.au
Posted on Nov 30, 2008
I think the timing is out on my janome 2039 sewing machine
It is very possible that the timing is off, which often occurs with broken needles. A common symptom is that the needle will not pick up the bobbin thread. Missed stitches aren't necessarily timing related--be sure to install brand needles often and use the correct needle for the fabric & thread you are using. Using the wrong needle will often cause skipped stitches.
What to Do If Your Sewing Machine Is Skipping Stitches
10 reasons for skipped stitches
Here What to Do if Your Sewing Machine is Skipping Stitches
Basic Maintenance Tension Skipped Stitches
You can search for sewing machine timing or take it for service.
Apr 12, 2017 | Janome Harmony 2039 Mechanical Sewing...
I am having a problem with my Janome Decor Excel 5018. It was working fine, until the bobbin thread won't gather with the top thread. And the top thread is binding up underneath the fabric. Kim
try a new needle
rethread the machine top & bobbin, that way you make sure the thread is not caught anywhere
make sure the bobbin is correctly inserted in the machine
clean under the needle plate & in the bobbin area for loose thread & lint
always keep a long thread tail of 3 to 5 inches long, & keep the tails pulled back behind the needle
before sewing
if none of these things help the problem,, then it may need to be serviced
Aug 10, 2011 | Janome D'cor Excel 5018
When I sew a seam, the bobbin stitch will just pull right out. Anything that I can try?
It has not been under tension when the seam was sewn, check your bobbin threading sequence and refer to your manual. The thread needs to click into a tension spring or similar device on all sewing machines.
For general machine tips, maintenance and help, try www.sewing.about.com - it has lots of information.
Mar 08, 2011 | Janome Harmony 2039 Mechanical Sewing...
How do I get thread from bobbin to come up?
You have to thread up the machine before that can happen... Wind the bobbin first Then thread the machine properly After that put the bobbin in the bobbin holder And place it in the shuttle make sure the notch on the bobbin holder is the right way... Then all u do is wind the wheel on the side of the machine towards yourself and it should come up, quite magical I suppose...
Nov 07, 2010 | Janome Harmony 2039 Mechanical Sewing...
Thread keeps getting stuck in bobbin holder area
Unthread your machine, clean out the bobbin area and brush it, then totally rethread your machine. Make sure that there are no tangles in your thread. Try that, good luck
Sep 20, 2010 | Janome Memory Craft 4900QC Mechanical...
Tension dial on my sewing machine is not working
Hi, Liz. When you adjust your tension, be sure the pressure foot is down. The pressure foot needs to be up when you thread the machine so the thread will slip easily between the tension disks, but when you adjust the tension the disks have to be tight (pressure foot down).
There are other possibilities, but this is the best place to start running the problem down. Please let me know if this does the trick, ok, and if not, we can try something ele.
Happy Sewing
Robbie
Apr 01, 2010 | Janome Harmony 2039 Mechanical Sewing...
Thread gets caught on bobbin and jams
You may need a new bobbin case if your machine is an older model.. Over time the cases get nicks in them causing thread to catch on it. Have you lubricated the bobbin area? Needs one drop of oil for every ,I believe it is 25 hours of usage. That may take care of it. The oil goes under the bobbin right in the center of bobbin case. Remove your bobbin before applying the oil. i hope this helps you. Good Luck
Jan 08, 2009 | Janome Harmony 2039 Mechanical Sewing...
When sewing the back of the stick is all gathered / notted / bulk of thread and the thread sometimes gets court around the bobbin. Also the thread the goes through the tension before being threaded into...
It sounds as if either it is incorrectly threaded, the upper tension is too loose(try no 4)the needle is in the wrong way around(flat side to back if it opens at the front) or that the bobbin area is jammed. Check all of the above and tell me if it helps.
Oct 07, 2008 | Janome Memory Craft 10000
Sewing Machines Logo
121 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
