Screen blank pc monitor screen goes blank after a while of being on computor, a box floats around screen saying not optimum mode, recomenned mode 1268x1040 with a small box with a ? mark inside, ? any solutions. thanks carl
  • 1 more comment
  • Anonymous Dec 25, 2008
    having same **** . cannot do nowt else ,very annoying changed settings on many many occasions ,just bought a new pc tower an it won't work on that either . so the lovely 19inch screen is in corner of room gathering dust ,while i use i tiny 15inch flat mon . cheers
  • Anonymous Jan 22, 2009
    the problem of my hp,is that when i start i get mor than 6 different screen on the same screen ,i don't knw what to do,help me please
  • Anonymous Feb 01, 2009
    Can't access my pc at all. Can't even reboot as the monitor will only show that darn box. I've tried for 3 weeks now to find a solution.
    I give up. Just when I think my pc is ok I have to ask my neighbour to lend me their Apple Mac which never seems to go wrong
  • 3 Answers
Dear car
start system in safe mode ( u can go to safemode by pressing f8 ) then uninstall display drivers. then restart ur machine it will appear like normal after that install display drivers. every thing will be normal and the display settings ( it is at right bottom corner of the window tab from there go to graphic properties then click on display settings and set screen resolution as 1200x800 . restart ur machine
hope ur problem will be solved.
Posted on Dec 01, 2008
  • suryasystems
    suryasystems Dec 01, 2008
    solution #1 is working thanks
    Master:
  • 461 Answers
Sounds like its simply going into power save mode. Does your screen come back on when you move the mouse or press a key on the keyboard? Is the computer still on? Check your power options in control panel.
    Scholar:
  • 162 Answers
From what you are saying, the system is working and goes into screen saver mode and gets stuck.
Try turning off the monitor and then turn it back on.
My screen just stopped working and I have a rectangular box floating around in a counterclockwise rotation that says " Check cable signal " Do you have any ideas? It was working fine up...
that means your monitor is working fine, just check your video connection on both ends of the monitor and PC.
maybe your PC has two video cards, try to plug in another video connector
Jan 29, 2011 | Samsung SyncMaster 931B 19" LCD Monitor
Monitor optimum size
Do you have the latest Graphics drivers?
Jul 17, 2010 | HP Compaq dc5100 Microtower PC Desktop
My Dell E207WFP LCD monitor has a blank screen with the following message in the middle-2:Analog input cannot display this video mode optimum resolution 1680x1050 60Hz. It says this also for #1. This...
Hello!
For this issue you might reconsider focusing on your CPU Tower, the way you're describing the issue, the monitor losses it connection from the computer, therefore showing the "analog input..." This is a power saving feature of your monitor. This means that the monitor is no longer a signal from your computer. Possible points of failure for this one could be, PSU, memory, motherboard or add on video card if you have one installed, best approach i could suggest is to run diagnostics- if your still able to boot the computer - Try powering up the computer, when you see the Dell logo tap F12 several times until you see some options then look for diagnostics, then run it..(this is for a DELL pc) if it fails then a possible hardware issue, if your pc still have warranty, call in for help.
Hope it helps!
Apr 20, 2010 | Dell E207WFP LCD Monitor
Screen goes black with a floating sign the says Not Optimum Mode Recommended Mode: 1280x1024 60Hz Took in for repair and work ok there
befor loding windows press F8 then choose vga mode
inside vga mode change the resolution to the recommended mode and restart your pc
then i think it will works
bye
dont forget to rate my solution
Jan 23, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
My computer screen has a blue box floating round the black screen, the buttons and mouse dont do anything. There is a message saying 'not optimum mode, recomended mode 1280 x1024 60hz. There is also a...
Basically its telling you to change to the correct resolution. You may have it set too high. If you go into "Safe Mode" you should be able to bring it down. Or if worse comes to worse, uninstall and reinstall your video card. Just make sure to have the drivers available.
Oct 16, 2009 | Computers & Internet
Floating box non optimum mode recommended mode
You need to adjust the Display screen resolution.
  1. Control Pannel
  2. Display
  3. Settings
  4. Screen Resolution
Sep 22, 2009 | Samsung Computers & Internet
Monitor stops working and box start floating around on screen with "Not Optimum Mode -- Recommended Mode 1280 X 1024 60 Hz." Replacement monitor works on computer.
check if your monitor has an auto-adjust button, this will help you autoadjusting the recommended resolution so that there are no problems, if not, you can try to rightclick on windows desktop and go to properties>configuration, set the resolution there
Sep 16, 2009 | Computers & Internet
A box stating not optimum mode-get distorted internet images
Sounds like your resolution is not set correctly.
Try going to Start-->Control Panel-->Display and choose the Settings Tab
Under there change the resolution slider bar to 1280x1024
Should do the trick!
Jul 11, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Monitor shuts down , blank screen with a box floating around saying optimum mode not recommened , recommened mode 1228x1040, then a small box with ? mark inside, ? solution.
Reboot your pc and press F8 to go to the safe mode. You will be able to change the resolution of the screen. And then reboot.
Nov 29, 2008 | Computers & Internet
Samsung Syncmaster 710n monitor - screen goes black for no reason. All cords connected properly. Computer works with other monitors. Switch on front of computer is on - green light on. Get floating...
in safe mode adjust the resolution lower than 1280x1024
then restart and then install the driver again the driver is crrupted than install the right driver problem could be solved
May 16, 2008 | Computers & Internet
Computers & Internet Logo
1,039 people viewed this question
David Payne
David Payne
