Monitor shuts down , blank screen with a box floating around saying optimum mode not recommened , recommened mode 1228x1040, then a small box with ? mark inside, ? solution.
  • Anonymous Feb 18, 2009
    shutting down itself
    Champion:
    Scholar:
  • 209 Answers
Reboot your pc and press F8 to go to the safe mode. You will be able to change the resolution of the screen. And then reboot.
Posted on Nov 30, 2008
Not optimum mode Recommened mode 1280x1024 60hz while monitor is on in between it shows this message then when i press enter it go and it will come again in a minute please give me a good solution i am mad...
right click on desktop as in your screen and click on personalize and click on change resoltuion
change to your resolution to 1280 x 1024 and then click on monitor tab and change the refresh rate to 60 hz
May 19, 2010 | Samsung 19IN ANALOG/DIGITAL 1000:1 5MS...
My Dell E207WFP LCD monitor has a blank screen with the following message in the middle-2:Analog input cannot display this video mode optimum resolution 1680x1050 60Hz. It says this also for #1. This...
Hello!
For this issue you might reconsider focusing on your CPU Tower, the way you're describing the issue, the monitor losses it connection from the computer, therefore showing the "analog input..." This is a power saving feature of your monitor. This means that the monitor is no longer a signal from your computer. Possible points of failure for this one could be, PSU, memory, motherboard or add on video card if you have one installed, best approach i could suggest is to run diagnostics- if your still able to boot the computer - Try powering up the computer, when you see the Dell logo tap F12 several times until you see some options then look for diagnostics, then run it..(this is for a DELL pc) if it fails then a possible hardware issue, if your pc still have warranty, call in for help.
Hope it helps!
Apr 20, 2010 | Dell E207WFP LCD Monitor
Screen goes black with a floating sign the says Not Optimum Mode Recommended Mode: 1280x1024 60Hz Took in for repair and work ok there
befor loding windows press F8 then choose vga mode
inside vga mode change the resolution to the recommended mode and restart your pc
then i think it will works
bye
dont forget to rate my solution
Jan 23, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
My computer screen has a blue box floating round the black screen, the buttons and mouse dont do anything. There is a message saying 'not optimum mode, recomended mode 1280 x1024 60hz. There is also a...
Basically its telling you to change to the correct resolution. You may have it set too high. If you go into "Safe Mode" you should be able to bring it down. Or if worse comes to worse, uninstall and reinstall your video card. Just make sure to have the drivers available.
Oct 16, 2009 | Computers & Internet
Floating box non optimum mode recommended mode
You need to adjust the Display screen resolution.
  1. Control Pannel
  2. Display
  3. Settings
  4. Screen Resolution
Sep 22, 2009 | Samsung Computers & Internet
Monitor stops working and box start floating around on screen with "Not Optimum Mode -- Recommended Mode 1280 X 1024 60 Hz." Replacement monitor works on computer.
check if your monitor has an auto-adjust button, this will help you autoadjusting the recommended resolution so that there are no problems, if not, you can try to rightclick on windows desktop and go to properties>configuration, set the resolution there
Sep 16, 2009 | Computers & Internet
A box stating not optimum mode-get distorted internet images
Sounds like your resolution is not set correctly.
Try going to Start-->Control Panel-->Display and choose the Settings Tab
Under there change the resolution slider bar to 1280x1024
Should do the trick!
Jul 11, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Screen blank
Sounds like its simply going into power save mode. Does your screen come back on when you move the mouse or press a key on the keyboard? Is the computer still on? Check your power options in control panel.
Nov 29, 2008 | Computers & Internet
My monitor has a message floating up and down saying not optimum mode recommended mode 1280x1024 60Hz what do i do
dear dalton,
1.right click on desktop.select properties and click it.
2.then select settings tab on top.
3.there u can see the screen resolution slider bar. there u can select the optimum mode for ur monitor.
thanks,
Sep 30, 2008 | Computers & Internet
Monitor
When your computer is starting up, hit F8 and you'll see the safe mode, safe mode with networking, etc. screen...You should see a choice that says "enable vga mode". Select that and windows will start and the os will select a screen resolution for you. After that, everything will work fine...I hope.
Good Luck!
Anonymous
Mar 15, 2008 | Acer X193W LCD Monitor
Computers & Internet Logo
75 people viewed this question
David Payne
David Payne
