Question about Breitling A1336313 Bentley Gt Racing Watch
My bretiling watch falls behing even after changing battery
I have a bretiling reveil watch and i changed the battery yesterday. right after the second hand started moving fine, but the hour and minute hands started falling behind. any idea how i can fix it myself!!!!!!
  • 24 Answers
Is your breitling a Kinetic one?
Posted on Sep 16, 2009
How to change battery on a ladies classic 18 k and steel watch with solid back
Welcome to Fixya,
Hi hope this steps will helped you in changing the battery but I just want you to remind that you have to be careful in changing the battery because it might affect the other part.
1- remove the crown by pulling away from the watch, use your thumb and index fingernail and pull , it will come out
2- remove all 5 gold bezel screws
3 - be careful,, the bezel/crystal will pry off easy
4 - be careful and remove the entire face/hands/watch guts all in one easy step,, or just turn the watch over and it will fall out
5 - small screwdriver and remove/replace battery
6 - reinstall watch guts/bezel and gold screws
7 - push crown back into watch
Thank you for using Fixya.
Feb 22, 2011 | Ebel Classic Wave 9090F249725 Wrist Watch
I have jlc movement 450 with dial but case is missing
cousinsuk.com choose branded watch parts, select the brand and search. They are in England but I use them all the time, you have to go through there little signup procedure but whatever it takes, right?
Feb 12, 2011 | Jaeger-lecoultre JaegerLeCoultre Master...
I have a geneve quartz 14k gold mans watch dont no how to take apart to put battery in.
mcdevito75 here, Battery usually lasts 1 year and longer, even if you did change the battery yourself now, you"d forget for a year or even longer next time battery needeed to be changed, I know I did. Add to this you can easily destroy your watch with in-correct handleing. BEST BET, look for a small watch repair shop in your area for this battery change $10--$15.00 and peace of mind.
Oct 26, 2010 | Geneve 14K Gold Ladies Diamond Panther...
How to open the back of Kenneth Cole KC3434 watch to change the battery?
BASIC WATCH BATTERY CHANGE
Get a replacement battery for your watch. Some watches have the battery information stamped on the back plate. If yours doesn't, you'll have to wait until you've removed the old battery to see what kind of replacement watch battery you'll need.
Lay your watch face down on a non-scratching, non-skid surface. It may help to clamp the watch to the surface.
Remove the back from the watch. You might be able to pry it off with your fingernail, but you'll probably need a stiff, thin tool like a knife or screwdriver. You can also buy watch repair kits, which have the perfect tools for the job. Check the watch back for a small notch to insert your tool, but not all watches have these.
Remove the battery from the watch once the back is off. You might need to tip the watch over to let the battery fall out.
Insert the new watch battery into the proper space, first double-checking its size against the old battery to make sure it will fit. Press lightly into place.
Replace the back on your watch. Make sure you press firmly to get the back seated snugly.
If this doesnt work, then take to a local jeweler/watchmaker who is equipped with the right tools to assist you.
Best regards.
Aug 17, 2010 | Kenneth Cole KC3434 Wrist Watch
I have a Peugeot 292 with a face that is exactly the same as a 288BK. I love this watch, have had it for years, but lately it has not kept time. I checked the battery and it is still at 1.5 v. Is there...
mcdevito75 here, Even the best watches, Wind-up and Quatz give out over time, components simply wear down. If the battery is over 1 year old, even though it still test good at 1.5 volts Change it. Also check with the repair service right here on fixya, bottom of this page click on repair service directory then click on watches, maybe 1 of the watch repair people could, clean the watch or even change the quartz mechanism in the watch.
Jun 22, 2010 | Peugeot 288BK Wrist Watch
My columbia watch doesn't keep time it falls behind. I had a new battery put in yesterday. The watch is less than 7 months old.
It is unusual for a battery to die so soon, (unless it has power hungry features which allow you to drain the battery (e.g. a stop watch feature).
As it it so young is it still under warranty (did you register it?). It should be returned to the maker.
Feb 10, 2010 | Watches
How do you get the back off a men's armitron watch to change the battery? Took it to Walmart and they can't figure it out.
If you don't have a watch repair kit, a small flathead screwdriver or even a butter knife would work. Set the watch face down on a soft material (pillow/towel). Insert the flat tool in the gap between the back and the watch itself. Apply a bit a of pressure the loosen and remove the back. Remove the rubber gasket covering the battery. Then you will want to remove the clip covering the battery (with the flat tool). Once the clip is removed flip it upside down and let the battery fall out
Nov 29, 2009 | Watches
Two weeks after buying the watch it just stopped the jeweler thinks it might be that the second hand is getting stuck
Depends on the kind of watch. If it is a quartz watch it could be the battery.
If it is a mechanical it has a more serious problem. A new watch most likely will not have a problem with a hand touching unless the watch has taken a great fall and the hands are jarred enough to misplace them. Of course this kind of fall will cause other damage.
Seriously, most jewelers don't know what a watch is let alone how it works or what could be wrong with it. Have a watchmaker look at it and they can give you real information.
Hope this helps.
Ken
Yellowstone Watch Inc.
www.yellowstonewatch.com
Nov 01, 2009 | Watches
Resetting sound
Could the jeweler have inadvertently damaged the beeper in the watch when he changed the battery? I'd tell hime the problem, ask him to restore the sound and see what he says ("oops" is a bad sign).
Lenny
Feb 15, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Breitling A1336313 Bentley Gt Racing Watch Logo
307 people viewed this question
Top Breitling Watches Experts
Ansel Alberto
Ansel Alberto
deton8 von Splosion
Are you a Breitling Watch Expert? Answer questions, earn points and help others
