I have reset my edimax router as i was having problems with it connecting at night, now i cant get in to the router at all
  • 102 Answers
Unistall it all reboot and reinstall
Posted on Nov 29, 2008
I have a problem installing the router, it cant connect the internet connection. what should i do? i think theres a problem in my edimax unit.
Try this;
1. Reset the router,
2. insert the utp cable from your pc to LAN1 port of your router
3. to access the router, in your internet explorer URL type http:\\192.168.0.1 (if this is the default IP of router)
4. once connected, check if the default username is admin
5. at setup wizard using LAN, use dynamic connectivity then save.
Jun 16, 2011 | Computers & Internet
Dir sirs, my br 6204wlg is in a "read only mode" I cant apply any settings into it, the running time clock always resets itself. and I cant upgrade or downgrade firmware versions. what should...
Hi Sir,
I see that you are able to get in your Edimax Router settings but cannot change or apply any setting to it, I beleive you should try to reset the Router itself. Behind there should be a small Pinhole that you can poke for 2-3 seconds to reset your Router, after resetting the Router try going back in the Routers settings and see if any changes can be applied or done to it.
Please send me a message if ever you may have any questions.
Thanks.
Mar 01, 2011 | Edimax BR-6204WLg Router
Wireless connection trouble
hi
plz chk out the range of the router and give a static ip on the comp in the range of router ipaddresses and then try to reconnect. I am sure you will be connected.
gud luck
thanx and regards
sukhiii
Aug 19, 2009 | Edimax EnduraLINK ER-1124 - 4 Router
Edimax Router BR-6204WG - setting as
I believe I can help.
As I understand you use your Siemens to get to Internet and you like to use another Edimax 6204 WL Router on another floor.
You don't have to change much !
First check if DHCP on your Siemens Router is ENABLED (it should be) !
- RESET your EDIMAX Router (to be sure everything is set by default)
and disconnect any LAN cables from it.
- If you are using Laptop (or desktop with WL adapter), connect it to your EDIMAX by LAN cable.
- Set (if it is not) LAN adapter IP and DNS of your Laptop/Desktop
to 'Obtain an IP address automatically'
If it was seto to some STATIC IP, after this you may need to 'REPAIR' your LAN connection
to get a new IP from your Edimax router
- Open your browser and type http://192.168.2.1
(admin + pass: 1234)
- Go to Wan port and check it. It should be set to Dynamic IP.
- Go to LAN settings and type IP address of the Edimax Router in the same Class
as Siemens Router is. (e.g. if Siemes router is 192.168.1.1 then Edimax should be 192.168.1.2)
- Change the DHCP range too, but be carefull this range should be different from DHCP range on your
Siemens router. (e.g. if Siemens router range is 192.168.1.100 to 192.168.1.200, then you should
set Edimax DHCP range from 192.168.1.201 to 192.168.1.250)
- Now, connect the LAN cable from one of Siemens LAN port to WAN port of your Edimax.
That's it!
Now you may change SSID, Security, Time etc. on your Edimax router, and also try to connect via your Laptop's WL adapter. (also make sure it has no static IP address)
Hope this helped.
Aug 30, 2008 | Edimax BR-6104K Router (br6104k)
Edimax br-6104k
do you have apppoe connection or dhcp? release your ip address (ipconfig/release) set your modem to bridge mode then connect modem and router. try to connect.
marlon
Jan 16, 2008 | Edimax BR-6104K Router (br6104k)
Cant connect on d internet
my case if i direct the cable on single PC its work we have connection but when i use edimax i cant connect...unable to connect.
Dec 09, 2007 | Edimax BR-6104K Router (br6104k)
I cant access my router(EDIMAX BROADBAND ROUTER)
Warning the following instructions are likely to RESET THE ENTIRE CONFIGURATION OF THE ROUTER and you will need to reenter it completely. Do not follow these instructions unless you are prepared to reconfigure your router completely from the factory defaults. I am not sure but be careful or consult with EDIMAX support before proceeding.
note the following is from the http://www.edimax.us/ website follow technical support and click
BR-6104 / 6104W / 6104P
Then
If I forget my password, what can I do?
I hope this helps.
Dec 02, 2007 | Edimax BR-6104KP Router (BR6104KP)
PPPoE over Edimax BR-6104K without a modem
HI,
  Actually in short  "you NEED A MODEM;"
In order to connect your router you need to connect a modem in "bridge mode'( bridge mode is nothing but a configuration on the modem)..
this is a picture of  rear side of a  router,,, you have to connect the modem into the wan port of the router (above),, and in port number 1,2,3,4 you can connect your computers,
Nov 01, 2007 | Edimax BR-6104K Router (br6104k)
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
