Hi, We have a Panasonic DMR-ES20D DVD recorder. We use it mainly for recording programmes we have saved on our sky plus box. It is connected to the sky plus box by scart cable into the AV2 scart connection on the recorder. It has worked fine for quite a while now but it now has a problem. You can start the recording from the sky plus box and all is well for either about ten, fifteen or twenty minutes. Afyer that it stops recording! I've now wasted dozens of discs trying to get this right. You can record from the built in freeview tuner for as long as you want. Any ideas?
4 Suggested Answers
Palmbeach
  • 185 Answers
SOURCE: Total lock up
The reason your dvd recorder keeps self checking is because there is a faulty regulator on the power board.
I have listed full instructions on how to fix this, but you will need to be able to use a soldering iron and exercise care. Alternatively you may be able to pass the instructions to someone who can repair it for you.
Do not listen to anyone telling you the laser is faulty, DVD drive unit is kaput, it requires firmware, software or any other useless upgrade, or that Panasonic will do it for the price of a small car! It is easy to fix..
I won't repeat the instructions here but if you look at my profile and search my DMR E55 solutions you will find it.
The regulator gets very hot during normal operation and it will eventually fail on all DMR E55s after a couple of years or so.
It was probably on its last legs and when you put the lead back in, you probably didn't disconnect the plug from your power socket and this caused a power surge which has finally killed it.
If you know what you're doing it's an easy fix.
It definitely does not need a software reboot.
I would be reluctant to use it again until it has been fixed because if the regulator overheats further, it could short circuit and cause other components to fail which would make the repair more difficult.
To check to see if there is a disc inside, unplug the unit from the mains, remove the two large silver screws, one on each side, then the three black screws on the back of the lid which can then be easily removed.
Next, remove the four small phillips screws that hold the top cover on the dvd drive. This is a large black plastic cover in the middle of the unit. The cover can then be taken off and disc removed if there is one inside. DO NOT TOUCH ANYTHING ELSE. replace the cover and screws, then repair the unit.
Posted on Feb 29, 2008
SOURCE: Need to connect the following: Foxtel
how can i recover my dvdrecorder's HDD?
Posted on Mar 09, 2008
SOURCE: How do you unlock a DMR-ES20D
How can you unlock a Panasonic DMR-ES20D Dvd recorder.
Posted on Dec 25, 2009
How to besto connect this unit to record from Sky plus box
SCART from Sky box to SCART input on Pana. SCART out from Pana to TV to monitor results. The Pana SCARTs should be marked, one for external source such as Sky box, one for TV
Oct 26, 2013 | Panasonic DMR-E65 DVD Recorder
My mother has a Panasonic DMR-ES20D DVD recorder it plays back DVD's ok but has lost all tuned channels. When performing a auto tune it gets to ch 53 and appears to hang with error code U80 in the dis
could be its not digital, so it will not pick up any channels as they are now all digital not terestrial through the aerial like the y used to be. you need a digi box now to plug the recorder into
Dec 11, 2011 | Panasonic DMRES20D DVD Recorder
Diagram to set up the Panasonic DMR EZ47V DVD/Video recorder
Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the LCD . Connect the AV output of the Sky box to the AV input of the Panasonic combo.
Hope it will cover the matter
good luck
Jan 29, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Have DVD recorder (DMR-EZ27EB)How can I record from a satellite program when the DVD recorder is connected to the AV 2 input and the satellite via SKY box is connected to the AV1 input
Connect the sky to the tv using a scart from the one marked tv on the sky box.Connect a scart from the one marked vcr on the sky box to av2 on the dvd.You then select av2 as your record channel on the dvd.
Dec 08, 2009 | Panasonic DMR-E55 DVD Recorder
Panasonic dmr-es20d
Hi there try this link http://www.manualsnguides.com/search.php?cmarque=PANASONIC&modele=DMR%20ES20D
you can get the operational manual of your
Panasonic dmr-es20d
Please rate thanks God bless
Nov 14, 2008 | Panasonic DMR-ES10 DVD Recorder
Connections for DVD Recorder/LCD TV/ SKY PLUS
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Mar 28, 2008 | Panasonic Televison & Video
Connecting TV-DVD recorder-Sky plus
scart from the sky to the dvd recorder. then a scart from each to the tv. Job done.
Jan 18, 2008 | Televison & Video
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
