Sky box will not switch on - Televison & Video
    New Friend:
  • 161 Answers
Hi
I know this sounds very obvious, is there power at the wall outlet?.
(In the UK,) has the fuse in plug top blown?.
If both above ok, check fuse inside sky box. IT IS IMPORTANT THAT YOU MAKE SURE THE POWER LEAD IS REMOVED FROM THE SUPPLY. Remove screws from sky box cover and remove top, around where lead enters the unit you should find a glass fuse, if this has blown it should be replaced with identical value fuse as that which was originally fitted, failure to do this will cause ireversable damage.
Good luck
Posted on Nov 29, 2008
I have sky tv and a marantz system, marantz system flashes pcm dig and tv loose signal intermittently, help
Your Sky box might need a firmware refresh. Switch it off at the mains socket. Press and hold down the BACKUP key on the SKY BOX (not the remote). Switch on at the mains and keep the backup key pressed down until the TV shows an info screen that the box is updating.
Allow the box to complete the cycle.
Try your system again.
Sep 02, 2014 | Marantz Audio Players & Recorders
No signal on sky
There may be a problem with your tv setup.Perform the following steps below:
1.Press the standby button on your Sky remote and switch off your Sky box at the mains. Check that the power light on the front of your Sky box is off before proceeding.2.Check your cable connections 3.Switch your Sky box back on at the mains. Wait 4 minutes before pressing the sky button .You may see a message before viewing resumes, on Channel 998.Tthat's it
Dec 09, 2013 | Computers & Internet
I have a Tosumi television connected to standard sky box but every time I turn on television it goes to another channel rather than the connected av channel. Also when I try to use sky controller to...
Always turn on your TV with the Sky box (or any other external device you want to use) turned OFF. When the TV is on, turn on the Sky box by pressing the "Sky" button at the top centre of the remote control. This will ensure that the TV recognises that there is an external input and it will automatically switch to the correct channel. It also ensures that your Sky remote control isn't in TV mode.
If you switch your TV to standby using the Sky remote after watching, the next time you use the Sky remote, it's still in TV mode. This is why your TV channels are jumping around.
Hope this helps.
Oct 21, 2010 | Televison & Video
I have just bought a samsung lcd tv with 1 scart socket. But I have a satellite box and an hdd recorder but I dont know how to connect it all up. Could anyone help. Thank you
The Sky box should connect to the TV using it's TV Scart output.
The HDD recorder then connects to the SKY via the other Scart.
When you turn the HDD recorder on, the SKY box will automatically switch.
You need to put your normal antenna into the HDD recorder and tune it in.
When the Sky is off, you can use the HDD recorder for playback, you can also switch between the 2 when it is on with the Sky remote.
Sep 05, 2009 | Samsung Televison & Video
I have no sky movies or sky sport i have a eurovox and a starview box as im sick in bed and can not go out for the forseable future i really need help. thanks in advance.
i have no sky movies or sky sport i have a eurovox and a starview box as im sick in bed and can not go out for the forseable future i really need help. thanks in advance.
Apr 10, 2009 | StarTech.com StarView SV211K 2-port KVM...
TV locks up the SKYdigibox
unplug tv for 1 mins,re-plug it back in!
Feb 26, 2009 | Televison & Video
No sky sports or sky 1,2,3 on the box starview 2
did you do a factory reset before flashing? do it then flash the box with the firmware. you will need to scan for channels and turn the emu back on after.
Jan 23, 2009 | StarTech.com StarView SV431USB 4-port KVM...
Probem getting sky to work with a new TV
An HD TV connects in the same way as a standard TV.
Connect a scart lead from the TV scart of the Sky box to the TV.
When you switch on the Sky box it should automatically switch the TV to the correct external input.
May 19, 2008 | Televison & Video
Televison & Video Logo
340 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
