Question about Microwave Ovens
My Sanyo microwave oven is six months old. The turntable has stopped rotating smoothly. Its motion has suddenly become jerky and noisy at the same time. I have given it to the vendor who sold it to me, for repair. Is it a major fault? I wonder why a brand new oven developed such a s problem. Babul
  • mellattimer Nov 29, 2008
    I have exactly the same problem on my Sharp combi microwave oven. The turntable does not go round but the oven make a ticking sound
  • Microwave Ovens Master
  • 9,098 Answers
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
Since it's less than one year old, it should be fully covered under warranty, as long as the problem is not due to grease or liquid spilled down into the motor.
Posted on Dec 02, 2008
Turntable has jerky motion and makes noise. Oven is 2 months old
Please remove the unit's turntable and clean the tray and turntable.
Mar 31, 2014 | Panasonic NN-H965BF Microwave Oven -...
My turntable does not turn
The turntable motor in the microwave oven needs to be replaced.
Jan 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker XL1800, about six years old. It heats food fine, but there is a terrible grinding sound while it does so, for the entire time it is running. This has been going on for several...
Personally, I would replace the Microwave. It is bound to be below specification by now if it has been used quite a bit.
Then you will know you will be fine for a few years.
Dec 15, 2010 | GE XL1800 1100 Watts Microwave Oven
Model # OGB81201 approx 1 month old. Microwave does not work turntable does not rotate, Convection and grilling apprear to work and turntable rotates when using these features. When i push the quick...
Approximately 1 month old? Should still be under warranty. Before doing anything else, contact the store where you purchased the oven and see if they'll exchange it as defective. If not, they may take the unit in for service there. Failing that, check your owner's manual to see what to do for service.
Feb 27, 2010 | Microwave Ovens
Microwave turntable is jerky rather than smoothly turning... it's a Whirlpool Gold GH8155XMB-0, made in October 2003 ... is there some sort of belt that can be replaced or motor or something? Otherwise,...
first check the roller under the turntable is correctly seated if so pull the drive coupling out from inside the oven and check for damage. If all of the above are OK you will need a replacenet turntable motor
Dec 28, 2009 | Whirlpool MH7140XF Microwave Oven
Oven cooks but turntable will not turn, so it cooks unevenly. How do I reset the keypad so it goes back to normal factory presets, in case I entered something that stops the turntable revolving. Is there...
The manufacturer has set the rotational plate in motion at the same time the microwave tube is energized. They work together as a team. At no time should the plate be idol, unless you remove it completely, and then only the center spindle will turn by itself. It is possible for the rotational spindle in the center of the oven to break, but that is unusual unless some sort of pressure (like stopping it when it was moving) was applied. Also, it has been reported that some individuals tend to put items with too much weight or too large for the oven to manage; thus damaging the rotator. As long as the oven still provides Microwaves to cook your food, it is still OK. Years ago, there were no rotating plates and using the energy was all it took to get the job done. For even cooking, just manually stop the oven at times and turn the food to avoid over heating in one spot.
Jan 14, 2018 | Kenmore 62222 / 62229 1100 Watts Microwave...
LG over the stove model lmvm 1935
In some cases, cleaning them helps. Lubrication is not recommended.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
To order Goldstar / L.G. parts, visit Vance Baldwin Electronics.
Dec 07, 2008 | LG LMVM1935 Convection/Microwave Oven
SANYO EM-D9550. Turntable turns when off but not when cooking.
That's sounds pretty strange!
Since I don't have any service data on Sanyos, I'd have to speculate.
I would guess that one scenario that could cause it would be if the turntable were turned off via the control panel, but there was a switch or switch mount problem.
I would refer you to their support people:
http://sanyoservice.com/
Dec 08, 2007 | Sanyo EM-D1100 1100 Watts Microwave Oven
Noisy turntable
I has this problem with a Sears unit. The repairman simply removed the glass tray, cleaned all the wheels and the 3 toothed driver wheel in the middle and it became quiet. He explained that if any buildup keeps the plate from properly seating on the gear, it gets very noisy.
Mar 25, 2007 | De Dietrich DME112X Microwave Oven
GE Spacemaker XL 1800 Turntable malfunction?
You can find helpful exploded views and buy the replacement turntable motor at http://tinyurl.com/gv383 Need safety tips? See http://tinyurl.com/yzjozk
Jan 14, 2007 | GE JVM2070 Microwave Oven
Microwave Ovens Logo
220 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
