Question about Cell Phones
I NEED A PHONE FROM YOU - Cell Phones
  • 470 Answers
What kind of phone??? what do you mean my dear??
Posted on Nov 29, 2008
Need to transfer my old phone # to my new phone
Does this particular phone require a SIM card?
Apr 02, 2015 | Motorola Cell Phones
I cant find it on my computer
Please be more specific with your question. If your trying to connect your phone to your computer you will need a usb cable with a mini usb end for your phone. To access your phone you will also need to find the manufacture of your phone on the web and download the specific software onto your computer for your phone. Once you plug your phone in, your computer will recognise the phone and you will have access to anything you need to do. Hope this helps.
Jan 26, 2014 | Dell Computers & Internet
Whats their code?
i cant get you what code you need. either you need unlock code to unlock your phone from your network or you need security code to unlock your phone from security password. if you need security code you need to reset your phone. you can try resetting your phone through codes. its the safe way to reset your phone. if you want the unlock code for your phone you can get it here. Theunlockarena.com
Oct 09, 2011 | Cell Phones
Phone do not work
What you need to do first of all put off the powwer supply i.e the phone battery need to be remove from the phone for some time allow it then put the battery back to the phone phone or it position if possible.
Then put on power of the phone if the problem remain same then it could be that the phone battery will need to be recharge .please note this if the phone battery is well charge and the phone problem remain same then you will have to replace the the phone battery if you are able to get to the phone battery.
Please note if all this instruction has been put to place then the phone will surely need to be rebut that is it need computer soft ware programming to help it program to begging again by any computer phone operators around your local area.
Thanks.
Sep 03, 2011 | O2 Xda Atom
7105t Blackberry is not switching on
when a phone does not come on, there are two area that you will need to check where the fault is from:
the battery,
and
the phone board.
The cell of the battery might be too weak to power the phone, so you need to check if the battery is really charged or the battery on the cell is finally dead and will need to be replaced.
For the phone board, the phone board might be dead and will need to be restored back by flashing the phone.
Flashing the phone will restore back the phone and it will start working normal again.
Have a nice day.
Mar 25, 2010 | T-Mobile BlackBerry 7105t Cellular Phone
It keeps switching off by itself
when a phone keeps switching of by it self, there are two thing that will need to be checked:
The battery,
and
the phone board.
The battery cell might be too weak to power the phone steadily, i will need to be replaced.
The phone board might has lost some memory to cause the phone to switch off.
The phone will need to be flashed to restore the memory lost in the phone.
When flashed the phone can now working properly again.
Take care.
Mar 24, 2010 | Nokia 6500 Slide Cellular Phone
I need a code for mi celphone
Do you need a security unlock code?
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
Nov 25, 2009 | Motorola Mobility i265 Cellular Phone
I need the unlock code for samsung SGH-t469 or master code
Once you unlock the phone, then you can insert a new SIM card in this phone.
Nov 22, 2009 | Samsung Gravity SGH-T459 Cell Phone
Need unlock code, just finished contract and need to unlock nokia 6288 was with '3' ime no. 354558015669426 thankyou
Nov 22, 2009 | Nokia 6288 Cellular Phone
Do you need two phone lines for the fax and phone on this machine? if so do i need a two way plug for the phone?
You do not need 2 lines for a fax/phone. The only trouble is that you will not be able to tell the differance between a phone call and a fax unless your called first. There is a feature call distinctive ringing that should be offered through your phone company. The different types of ring would indicate a phone call or fax. The answer to the 'splitter' is that if you plug in your fax machine directly into the jack, most newer fax have a 2nd plug in the back labeled 'ext', this is where you can plug in a phone for the same number.
Apr 21, 2009 | Lands Phones
Cell Phones Logo
14 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
