Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Saving to USB
Says everything write-protected
  • 55 Answers
firslty rearrange the lock to unlock position on the ubs flash drive then format it with hp format tool and before it you checked it with antivirus programme, then try i think it will solve your problem.
ramesh
Posted on Nov 29, 2008
Every time I try to save something the drive I get a message saying it's write protected.
Make a note of the folder where the file being saved is being written.
Use a file manager (e.g. windows explorer for Windows XP) to check the permissions of the folder. If the folder is perhaps not writeable by the user with which you are logged into the system. Or the folder could be a system protected folder. If the folder (saving location) is on a SC card or an USB drive, check whether the write protect switch of the device is closed, which makes the device readonly.
Sep 20, 2013 | Computers & Internet
Tip
How to Protect Your USB from Receiving Virus
If you want to protect your USB from receiving unwanted files i.e. virus, worm, spy, trojan etc than you are at the right place.
What I'm gonna tell you is that how to setup your registry to stop a computer from saving files to your USB (It'll block all of them)
If you have windows XP with SP2, then you can disable the writing option to USB drives. This trick is very useful if you have virus in your computer and want to copy files from a USB Drive but don’t want to transfer virus to the USB. Follow the given steps to disable the USB writing option:
To edit the computer registry, first you should log onto your computer with administrative rights.
First click on Start button and type “Regedit” in Run option.
Here locate the location to:
HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControl
Here in right side panel, click right to create a key with the name “StorageDevicePolicies”.
Now in left side panel, select “StorageDevicePolicies” key, again right click to create new DWORD value then label it “WriteProtect”. Set its value to “1?. But again to enable writing, set its values to “0?.
Now close the registry editor
Note: If it won't work then restart your pc
Alternative way:
TO TURN ON THE PROTECTION
open notepad and copy and paste the following:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlStorageDevicePolicies]
"WriteProtect"=dword:00000001
Now save the file with the extension ".reg".
Double click on the file you just saved. In the pop-up window click YES and then OK.
That's it your USB is now protected
To TURN PROTECTION OFF:
"WriteProtect"=dword:00000000
That's it your protection is now disabled.
on Jun 27, 2010 | Computers & Internet
How to save text file to USB from Toshiba Excite
Check to be sure that your USB is not "write protected." Are you trying to save this to a jump-drive? It would be good to know what it is (device) that you're trying to save to. You may also have to change the properties of the device you're saving to. Need more info.
Jan 15, 2013 | Toshiba Tablets & eReaders
What does write protected mean
Hi write protected means you cannot save data (or write data) to a disk or memory chip or storage device if it is write protected, it is a function to prevent saving data overtop of other files and damaging etc, which in most devices can be shut on and off fairly easily
Apr 08, 2012 | Electronics - Others
My HP usb drive- v165w cannot be opened, says its write protected and even unable to format the drive, which keeps saying write protected.
Hi. You must have used your usb ext drive from a different computer with a different OS. Try saving your files online and format your ext drive from the former pc you used it with then plug it in the new pc you want to use it with.
^_^
Jun 06, 2010 | Computers & Internet
I cannot remove write protection of my transcend 4GB pen drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Jan 05, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Usb ports not working
buy a new mother board or use recovery media after saving files and clean out usb ports
Jun 13, 2009 | HP Pavilion dv9000z Notebook
My PC could not save file in my flash drive where as folder can.
Maybe the root of the USB drive is protected. If you got any switch for write protection in the USB drive, unlock it and try saving.
Thank you!
Sabharish
Jun 03, 2009 | Dell Dimension 1100 PC Desktop
Cannot remove write protection on sandisk cruzer usb pen.
The memory cards also have a write protection switch to protect data from being deleted or overwritten, just like a floppy disk
Dec 03, 2008 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Saving pictures
The camera has a very limited storage space on itself. It probably isnt saving the pictures on the card because the card is write protected (probably on accident)
just pull out the card and on it is a tiny little switch. just push that into the next position and it is no longer write protected. the write protection is there to prevent you from losing your photos, to put more photos on it you will have to deactive the protection with that switch, its usually white colored
Jun 28, 2008 | Polaroid A515 Digital Camera
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
93 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Alun Cox
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
