Question about Brother MFC-465CN InkJet Printer
Brother mfc-465cn always restars
I print a print test page but when i saw the "cleaning" status on the printers screen i cancelled it. then it started to restart (on and off) and never stops until i pull out the plug to the outlet. then i open the printer and i saw the print test page half finished. i pull it out and then i plug again the printer, but still it always restarted. help me what is the problem with my printer?
    Problem Solver:
  • 8 Answers
Not sure of the exact problem, but try a reset on it. Press Menu, *, 2, 8, 6, 4 within 2 seconds to get into service mode. Enter 91 to do a reset then 99 to exit. See if that helps and post here!
Posted on Jan 03, 2009
Mfc465cn-cant print test page,error PRINTER BUSY
I suggest You Go to Official Brother Printer Page For You Brother Printer Problem On Below Brother forum URL Link: How do print network configuration page Brother In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Jan 22, 2014 | Brother Any 8 Inks Mfc-465cn Mfc465cn...
I have not been using the Brother MFC 465CN printer for a while. Bought and installed new cartridges, cleaned the print head several times (from the printer menu option). But, nothing is getting printed....
Inkjet printers need to be used frequently to prevent inkdrying out in the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 24, 2011 | Brother MFC-465CN InkJet Printer
I have a printer problem, it is a Brother MFC-465CN. the lcd display screen is showing "Unable to Int. 48" can ou help please
This indicates a problem with the print head.
Clean the print head when needed by doing one of the following:
  • Press the Ink or Ink Management key and then select Cleaning. Or
  • Press the Menu key and then select Ink Management, Cleaning.
These cleaning processes do consume an amount of ink.
Nov 02, 2010 | Brother MFC-465CN InkJet Printer
HOW DO I PRINT ENVELOPES ON A BROTHER MFC-465CN PRINTER? SCREEN TELLS ME THERE IS A PAPER JAM WHEN THERE'S ONLY ONE ENVELOPE IN THE TRAY.
my brother mfc 7860 tells me i have a jam when i print envelopes only- there is no jam and will print the next 'page' fine- have to turn it on and off 4-5 times to get it to print one- any ideas anyone???
Aug 11, 2010 | Brother MFC-465CN InkJet Printer
My brother printer model mfc 465cn, it has ink but the print its not coming out, dont know what to do
try cleaning the carriage assembly. the that the ink is installed at. then do the print alignment at the printer settings.
Jul 02, 2010 | Brother MFC-465CN InkJet Printer
My brother mfc 465CN wont print black only color
Have you tried cleaning the print head? Find the instructions in the troubleshooting and maintainance section of the manual here http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_465cn_EN_1269.PDF
Jun 04, 2010 | Brother MFC-465CN InkJet Printer
Brother MFC-465CN says 'Unable to Print 5A'
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Dec 18, 2009 | Brother MFC-465CN InkJet Printer
Brother MFC-465CN won't prink cyan
You got to re-check back the Ink Cartridge you've buy recently.. Sometime the ink already freeze inside the cartridge bcoz its been really-really-really long time they keep before the usage.. Ive also have experience about problem like this b4, so better re-check/change back the cartridge.. Or If the
printer head is not at the cartridge, it is seperate from the cartridge, you have to check back the printer head also.. normally all the new printer head comes together with the cartridge.. and prefer to use the Original Cartridge more than Pirated Cartridge ok.. Cheap Cartridge always giv a lot of problem, especially like Your problem.. Thats All, Good Luck and Happy Trying..
DEAth-MaN88®
May 08, 2009 | Brother MFC-465CN InkJet Printer
My Brother MFC-465CN is printing text with alignment off and double text.
My Brother printer MFC-465cn is doing the same thing. I have workaround / worked-around it by disabling bi-directional printing. Then print is clear. It's as if the head is shifting an irregular amount on the opposite direction, like the head is loose.
Same for copies. If I use the PC interface to make copies, I can set the copy printing to be mono-directional, then copies are clear.
Sep 05, 2008 | Brother MFC-465CN InkJet Printer
Printer problem
check your ink level your most likely out of ink. make suer your printer is selected as the default printer in orinter settings from control pannel.run a printer head clean up
Mar 09, 2008 | Computers & Internet
Brother MFC-465CN InkJet Printer Logo
293 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
